[SCM] PostGIS branch master updated. 3.5.0-294-g67756f36b
Mon Apr 28 05:03:33 PDT 2025
the project "PostGIS".
       via  67756f36be35c77709a7e1e0d09361ad51c8f006 (commit)
      from  05e8b482bfd4eb4e985d86d17a3cf13234515d00 (commit)
revisions in full, below.
commit 67756f36be35c77709a7e1e0d09361ad51c8f006
Author: Loïc Bartoletti <loic.bartoletti at oslandia.com>
Date:   Fri Apr 25 07:48:22 2025 +0200
    tests(CG_Visibility): reinstate and fix Visibility segment in polygon
diff --git a/sfcgal/regress/tests.mk.in b/sfcgal/regress/tests.mk.in
index fd5bef62b..d160823d3 100644
--- a/sfcgal/regress/tests.mk.in
+++ b/sfcgal/regress/tests.mk.in
@@ -25,7 +25,11 @@ endif
 ifeq ($(shell expr "$(POSTGIS_SFCGAL_VERSION)" ">=" 10500),1)
 	TESTS += \
 		$(top_srcdir)/sfcgal/regress/partition.sql \
-		$(top_srcdir)/sfcgal/regress/extrudestraigthskeleton.sql \
+		$(top_srcdir)/sfcgal/regress/extrudestraigthskeleton.sql
+endif
+ifeq ($(shell expr "$(POSTGIS_SFCGAL_VERSION)" ">=" 10501),1)
+	TESTS += \
 		$(top_srcdir)/sfcgal/regress/visibility.sql
 endif
diff --git a/sfcgal/regress/visibility.sql b/sfcgal/regress/visibility.sql
index 91b04bfc7..392bd40dd 100644
--- a/sfcgal/regress/visibility.sql
+++ b/sfcgal/regress/visibility.sql
@@ -1,4 +1,4 @@
 SELECT 'Visibility point in polygon', ST_AsText(CG_Visibility('POLYGON((0.0 4.0,0.0 0.0,3.0 2.0,4.0 0.0,4.0 4.0,1.0 2.0,0.0 4.0))', 'POINT(0.5 2.0)'), 2);
 SELECT 'Visibility point in polygon with hole', ST_AsText(CG_Visibility('POLYGON((0.0 4.0,0.0 0.0,3.0 2.0,4.0 0.0,4.0 4.0,1.0 2.0,0.0 4.0),(0.2 1.8,0.9 1.8,0.7 1.2,0.2 1.8))', 'POINT(0.5 2.0)'), 2);
---SELECT 'Visibility segment in polygon', ST_AsText(CG_Visibility('POLYGON((0.0 4.0,0.0 0.0,3.0 2.0,4.0 0.0,4.0 4.0,1.0 2.0,0.0 4.0))', 'POINT(1.0 2.0)', 'POINT(4.0 4.0)'), 2);
+SELECT 'Visibility segment in polygon', ST_AsText(CG_Visibility('POLYGON((0.0 4.0,0.0 0.0,3.0 2.0,4.0 0.0,4.0 4.0,1.0 2.0,0.0 4.0))', 'POINT(1.0 2.0)', 'POINT(4.0 4.0)'), 2);
 SELECT 'Visibility segment in polygon with hole', ST_AsText(CG_Visibility('POLYGON((1.0 2.0,12.0 3.0,19.0 -2.0,12.0 6.0,14.0 14.0,9.0 5.0,1.0 2.0),(8.0 3.0,8.0 4.0,10.0 3.0,8.0 3.0),(10.0 6.0,11.0 7.0,11.0 6.0,10.0 6.0))', 'POINT(19.0 -2.0)', 'POINT(12.0 6.0)'), 2);
diff --git a/sfcgal/regress/visibility_expected b/sfcgal/regress/visibility_expected
index 7ecc5da92..b0bc3172b 100644
--- a/sfcgal/regress/visibility_expected
+++ b/sfcgal/regress/visibility_expected
@@ -1,3 +1,4 @@
 Visibility point in polygon|POLYGON((3 2,1 2,0 4,0 0,3 2))
 Visibility point in polygon with hole|POLYGON((0 1.67,0.2 1.8,0.9 1.8,1.93 1.29,3 2,1 2,0 4,0 1.67))
+Visibility segment in polygon|POLYGON((4 0,4 4,1 2,0 1.33,0 0,3 2,4 0))
 Visibility segment in polygon with hole|POLYGON((19 -2,12 6,14 14,10.43 7.57,11 7,11 6,10 6,9.56 6,9 5,1 2,4.67 2.33,8 4,10 3,9.87 2.81,12 3,19 -2))
Summary of changes:
 sfcgal/regress/tests.mk.in         | 6 +++++-
 sfcgal/regress/visibility.sql      | 2 +-
 sfcgal/regress/visibility_expected | 1 +
 3 files changed, 7 insertions(+), 2 deletions(-)
hooks/post-receive
