[PostGIS] #5890: Functions to detect/fix off-grid topology vertices
trac at osgeo.org
Mon Apr 28 09:36:24 PDT 2025
Reporter: strk | Owner: strk
Type: enhancement | Status: new
Priority: medium | Milestone: PostGIS 3.6.0
Component: topology | Version: master
Keywords: |
As per https://trac.osgeo.org/postgis/ticket/5862#comment:16 we'd need a
function that is able to find vertices in topology primitives that do not
fall on the topology precision grid.
Presence of such off-grid vertices would make it impossible to use
"precise" overlay operations.
The function could go along with a topology.MakePrecise function aiming at
snapping each vertex to the given precision grid, and checking that the
result is still valid.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5890>
