[PostGIS] #5862: TopoGeo_add* silently corrupt topology: edge crosses edge, mixed face labeling in ring
PostGIS trac at osgeo.org
Tue Apr 29 00:01:12 PDT 2025
labeling in ring
  Reporter:  Lars Aksel Opsahl  |      Owner:  strk
      Type:  defect             |     Status:  closed
  Priority:  high               |  Milestone:  PostGIS 3.5.3
 Component:  topology           |    Version:  3.4.x
Resolution:  fixed              |   Keywords:  robustness
Comment (by strk):
 Replying to [comment:16 strk]:
 > Maybe a function like `ST_SnappableItems(geom_to_test,
 snap_target_points, snap_tolerance)` could return locations from
 `geom_to_test` so they could be also printed on a map to help users deal
 with the problem
 See #5890
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5862#comment:21>
