[SCM] PostGIS branch master updated. 3.6.0beta1-17-gb624df826
Fri Aug 8 16:07:13 PDT 2025
the project "PostGIS".
       via  b624df826190f37b383324c357024b86e2fe8c66 (commit)
      from  523c7a6f08ce79495f0e4c403615b3fd88e12430 (commit)
revisions in full, below.
commit b624df826190f37b383324c357024b86e2fe8c66
Author: Regina Obe <lr at pcorp.us>
Date:   Fri Aug 8 18:45:59 2025 -0400
    Drop stst_approxquantile(raster, double precision) signature
    Closes #5498 for PostGIS 3.6.0
diff --git a/NEWS b/NEWS
index b9105175a..711eef38a 100644
--- a/NEWS
+++ b/NEWS
@@ -28,6 +28,8 @@ Dapeng Wang, Zuo Chenwei from HighGo (Chinese Team)
  - #3110, GT-242, [topology] numerous topology functions that accepted integer
           replaced with bigint versions to support both integer and bigint inputs
           (Ayo Adesugba, U.S. Census Bureau)
+ - #5498 Drop st_approxquantile(raster, double precision), wasn't usable as it triggered
+    is not unique error when used (Regina Obe)
 * New Features *
diff --git a/raster/rt_pg/rtpostgis.sql.in b/raster/rt_pg/rtpostgis.sql.in
index 9760723d2..3b2a2d4c4 100644
--- a/raster/rt_pg/rtpostgis.sql.in
+++ b/raster/rt_pg/rtpostgis.sql.in
@@ -1122,11 +1122,6 @@ CREATE OR REPLACE FUNCTION st_approxquantile(rast raster, exclude_nodata_value b
 	AS $$ SELECT ( @extschema at ._ST_quantile($1, 1, $2, 0.1, ARRAY[$3]::double precision[])).value $$
 	LANGUAGE 'sql' IMMUTABLE PARALLEL SAFE;
-CREATE OR REPLACE FUNCTION st_approxquantile(rast raster, quantile double precision)
-	RETURNS double precision
-	AS $$ SELECT ( @extschema at ._ST_quantile($1, 1, TRUE, 0.1, ARRAY[$2]::double precision[])).value $$
-	LANGUAGE 'sql' IMMUTABLE PARALLEL SAFE;
 -- ST_ValueCount and ST_ValuePercent
diff --git a/raster/rt_pg/rtpostgis_drop.sql.in b/raster/rt_pg/rtpostgis_drop.sql.in
index 33f5ad92c..156f085df 100644
--- a/raster/rt_pg/rtpostgis_drop.sql.in
+++ b/raster/rt_pg/rtpostgis_drop.sql.in
@@ -135,11 +135,10 @@ SELECT _postgis_drop_function_by_identity('st_approxquantile', 'rastertable text
 SELECT _postgis_drop_function_by_identity('st_approxquantile', 'rastertable text, rastercolumn text, exclude_nodata_value boolean, quantile double precision','3.0');
 SELECT _postgis_drop_function_by_identity('st_approxquantile', 'rastertable text, rastercolumn text, quantile double precision','3.0');
 SELECT _postgis_drop_function_by_identity('st_value','rast raster, band integer, pt geometry, exclude_nodata_value boolean');
 SELECT _postgis_drop_function_by_signature('st_gdalopenoptions(text[])');
 SELECT _postgis_drop_function_by_identity('st_clip','rast raster, geom geometry, nodataval float8[], crop boolean', '3.5');
+SELECT _postgis_drop_function_by_identity('st_approxquantile', 'rast raster, quantile double precision','3.6');
Summary of changes:
 NEWS                               | 2 ++
 raster/rt_pg/rtpostgis.sql.in      | 5 -----
 raster/rt_pg/rtpostgis_drop.sql.in | 3 +--
 3 files changed, 3 insertions(+), 7 deletions(-)
hooks/post-receive
