[SCM] PostGIS branch master updated. 3.6.0beta1-18-g00faf0f9c
Sat Aug 9 07:47:53 PDT 2025
the project "PostGIS".
       via  00faf0f9c0ed8e1888c0fab4b4f8fea46c84efe2 (commit)
      from  b624df826190f37b383324c357024b86e2fe8c66 (commit)
revisions in full, below.
commit 00faf0f9c0ed8e1888c0fab4b4f8fea46c84efe2
Author: Denys Kovshun <deniskovshun at gmail.com>
Date:   Sat Aug 9 13:50:41 2025 +0000
    Translated PostGIS Manual using Weblate (Ukrainian)
    Currently translated at 0.2% (12 of 5848 strings)
    Translation: postgis/PostGIS Manual
    Translate-URL: https://weblate.osgeo.org/projects/postgis/postgis-manual/uk/
diff --git a/doc/po/uk/postgis-manual.po b/doc/po/uk/postgis-manual.po
index ed154e0b1..53ffc3d8e 100644
--- a/doc/po/uk/postgis-manual.po
+++ b/doc/po/uk/postgis-manual.po
@@ -1,22 +1,21 @@
 # SOME DESCRIPTIVE TITLE.
-# FIRST AUTHOR <EMAIL at ADDRESS>, YEAR.
+# Denys Kovshun <deniskovshun at gmail.com>, 2025.
 msgid ""
 msgstr ""
 "Project-Id-Version: PACKAGE VERSION\n"
 "Report-Msgid-Bugs-To: https://bugs.kde.org\n"
 "POT-Creation-Date: 2025-07-20 04:11+0000\n"
-"PO-Revision-Date: 2023-10-14 20:23+0000\n"
-"Last-Translator: Anonymous <noreply at weblate.org>\n"
-"Language-Team: Ukrainian <https://weblate.osgeo.org/projects/postgis/postgis-"
-"manual/uk/>\n"
+"PO-Revision-Date: 2025-08-09 14:47+0000\n"
+"Last-Translator: Denys Kovshun <deniskovshun at gmail.com>\n"
+"Language-Team: Ukrainian <https://weblate.osgeo.org/projects/postgis/"
+"postgis-manual/uk/>\n"
 "Language: uk\n"
 "MIME-Version: 1.0\n"
 "Content-Type: text/plain; charset=UTF-8\n"
 "Content-Transfer-Encoding: 8bit\n"
 "Plural-Forms: nplurals=3; plural=n%10==1 && n%100!=11 ? 0 : n%10>=2 && "
 "n%10<=4 && (n%100<10 || n%100>=20) ? 1 : 2;\n"
-"X-Generator: Weblate 5.0\n"
+"X-Generator: Weblate 5.4.3\n"
 #. Tag: chapter
 #, no-c-format
@@ -26,12 +25,12 @@ msgstr ""
 #. Tag: title
 #, no-c-format
 msgid "PostGIS Administration"
-msgstr ""
+msgstr "Адміністрування PostGIS"
 #. Tag: title
 #, no-c-format
 msgid "Configuring raster support"
-msgstr ""
+msgstr "Налаштування підтримки растрових зображень"
 #. Tag: para
 #, no-c-format
@@ -39,6 +38,8 @@ msgid ""
 "If you enabled raster support you may want to read below how to properly "
 "configure it."
 msgstr ""
+"Якщо ви увімкнули підтримку растрових зображень, вам може бути корисно "
+"ознайомитися з тим, як правильно її налаштувати."
 #. Tag: para
 #, no-c-format
@@ -50,16 +51,24 @@ msgid ""
 "For PostGIS 2.2, you can use the more cross-platform approach of setting the "
 "corresponding <xref linkend=\"PostGIS_GUC\"/>."
 msgstr ""
+"Починаючи з PostGIS 2.1.3, растри поза базою даних та всі драйвери растрів "
+"за замовчуванням вимкнені. Щоб знову ввімкнути їх, потрібно встановити такі "
+"змінні середовища <varname>POSTGIS_GDAL_ENABLED_DRIVERS</varname> та "
+"<varname>POSTGIS_ENABLE_OUTDB_RASTERS</varname> у середовищі сервера. Для "
+"PostGIS 2.2 можна використовувати більш кросплатформний підхід, встановивши "
+"відповідний <xref linkend=\"PostGIS_GUC\"/>."
 #. Tag: para
 #, no-c-format
 msgid "If you want to enable offline raster:"
-msgstr ""
+msgstr "Якщо ви хочете увімкнути офлайн-растр:"
 #. Tag: para
 #, no-c-format
 msgid "Any other setting or no setting at all will disable out of db rasters."
 msgstr ""
+"Будь-яке інше налаштування або відсутність налаштувань призведе до вимкнення "
+"растрів поза базою даних."
 #. Tag: para
 #, no-c-format
@@ -67,6 +76,8 @@ msgid ""
 "In order to enable all GDAL drivers available in your GDAL install, set this "
 "environment variable as follows"
 msgstr ""
+"Щоб увімкнути всі драйвери GDAL, доступні у вашій інсталяції GDAL, "
+"встановіть цю змінну середовища наступним чином"
 #. Tag: para
 #, no-c-format
@@ -74,11 +85,13 @@ msgid ""
 "If you want to only enable specific drivers, set your environment variable "
 "as follows:"
 msgstr ""
+"Якщо ви хочете ввімкнути лише певні драйвери, встановіть змінну середовища "
+"наступним чином:"
 #. Tag: para
 #, no-c-format
 msgid "If you are on windows, do not quote the driver list"
-msgstr ""
+msgstr "Якщо ви використовуєте Windows, не вказуйте список драйверів"
 #. Tag: para
 #, no-c-format
@@ -89,6 +102,11 @@ msgid ""
 "<replaceable>main</replaceable>/environment</filename> where 10 refers to "
 "version of PostgreSQL and main refers to the cluster."
 msgstr ""
+"Налаштування змінних середовища залежить від операційної системи. Для "
+"PostgreSQL, встановленого на Ubuntu або Debian за допомогою apt-postgresql, "
+"найкращим способом є редагування файлу <filename>/etc/postgresql/"
+"<replaceable>10</replaceable>/<replaceable>main</replaceable>/environment</"
+"filename>, де 10 означає версію PostgreSQL, а main — кластер."
 #. Tag: para
 #, no-c-format
@@ -100,6 +118,13 @@ msgid ""
 "clicking <emphasis>Advanced System Settings ->Advanced->Environment "
 "Variables</emphasis> and adding new system variables."
 msgstr ""
+"У Windows, якщо ви працюєте як служба, ви можете встановити через системні "
+"змінні, до яких у Windows 7 можна дістатися, клацнувши правою кнопкою миші "
+"на «Комп'ютер» > «Властивості» > «Додаткові параметри системи» або в "
+"провіднику, перейшовши до <varname>Панель керування\\Усі елементи панелі "
+"керування\\Система</varname>. Потім натисніть <emphasis>Додаткові параметри "
+"системи ->Додатково->Змінні середовища</emphasis> і додайте нові "
+"системні змінні."
 #. Tag: para
 #, no-c-format
@@ -107,6 +132,8 @@ msgid ""
 "After you set the environment variables, you'll need to restart your "
 "PostgreSQL service for the changes to take effect."
 msgstr ""
+"Після встановлення змінних середовища необхідно перезапустити службу "
+"PostgreSQL, щоб зміни набули чинності."
 #. Tag: title
 #, no-c-format
Summary of changes:
 doc/po/uk/postgis-manual.po | 49 +++++++++++++++++++++++++++++++++++----------
 1 file changed, 38 insertions(+), 11 deletions(-)
hooks/post-receive
