[SCM] PostGIS branch master updated. 3.6.0beta1-26-ge1d09a8cb
Tue Aug 12 22:06:21 PDT 2025
the project "PostGIS".
       via  e1d09a8cba3905b15f4937dee76e4e5710c1ded7 (commit)
      from  1689f7cdca0de3fb9748738b160f35bbdb91a707 (commit)
revisions in full, below.
commit e1d09a8cba3905b15f4937dee76e4e5710c1ded7
Author: Regina Obe <lr at pcorp.us>
Date:   Wed Aug 13 01:06:08 2025 -0400
    Fix some typos, References #5961
diff --git a/doc/developer.txt b/doc/developer.txt
index f26a973f8..580ebe79e 100644
--- a/doc/developer.txt
+++ b/doc/developer.txt
@@ -37,14 +37,14 @@ they were in and stubbed in a deprecation file. Ideally you should never do this
 For Major such as when PostGIS 4 comes out we could in theory skip the legacy file and just chuck the function entirely.
 So a function can be stubbed in 3.0.0, but not 3.0.1, though there are cases where you might as long as
-you carefully fix up the SQL signature exposing it. The reason to avoid not doing this in a micro is people often run
-ALTER EXTENSION or SELECt postgis_extensions_upgrade() in a micro.
+you carefully fix up the SQL signature exposing it. The reason to avoid not doing this in a micro is people often do not
+run ALTER EXTENSION or SELECT postgis_extensions_upgrade() in a micro, so taking these out will break production code.
     * For the postgis extension, these should go in postgis/postgis_legacy.c the stub will look something like this.
         POSTGIS_DEPRECATE("2.0.0", postgis_uses_stats)
-      Note the specification of the function it was removed and the name of the function
+      Note the specification of the version it was removed and the name of the function
     * For postgis_sfcgal, deprecated C api functions should go in sfcgal/postgis_sfcgal_legacy.c
     * For postgis_raster, raster/rt_pg/rtpg_legacy.c
Summary of changes:
 doc/developer.txt | 6 +++---
 1 file changed, 3 insertions(+), 3 deletions(-)
hooks/post-receive
