[SCM] PostGIS branch master updated. 3.6.0beta1-25-g1689f7cdc
git at osgeo.org
git at osgeo.org
Tue Aug 12 21:32:06 PDT 2025
the project "PostGIS".
via 1689f7cdca0de3fb9748738b160f35bbdb91a707 (commit)
from a6b12ed5008cb6fce07d43d6bfa64d975c65f657 (commit)
revisions in full, below.
commit 1689f7cdca0de3fb9748738b160f35bbdb91a707
Author: Regina Obe <lr at pcorp.us>
Date: Wed Aug 13 00:29:14 2025 -0400
Developer documentation for our upgrade machinery.
Closes #5961 for PostGIS 3.6.0
diff --git a/doc/developer.txt b/doc/developer.txt
new file mode 100644
index 000000000..f26a973f8
--- /dev/null
+++ b/doc/developer.txt
@@ -0,0 +1,143 @@
+TITLE: PostGIS Developer How-To
+AUTHOR: Name: Regina Obe
+DATE: 2025-08-12
+CATEGORY: Development Docs
+When removing objects impacts upgrade
+There are two types of function removals that impact user upgrades and should be carefully thought thru.
+* SQL Api functions - these are functions that are exposed to the user in the database.
+ They are either SQl, plpgsql, or C backed functions.
+* C Api functions -- these are postgis lib functions that back SQL Api functions
+* Types, Views are also exposed via SQL Api
+Functions internal to postgis that are never exposed and only used within postgis libraries
+can be shuffled around to your hearts content.
+UPGRADING C Api functions
+You should avoid ever removing C Api function in Minor and Micro releases of PostGIS.
+If there is a C Api function that you badly want to remove you need to stub it so the signature still
+exists but throws an error.
+These functions should be removed from whatever file
+they were in and stubbed in a deprecation file. Ideally you should never do this in a micro. Only minor.
+For Major such as when PostGIS 4 comes out we could in theory skip the legacy file and just chuck the function entirely.
+So a function can be stubbed in 3.0.0, but not 3.0.1, though there are cases where you might as long as
+you carefully fix up the SQL signature exposing it. The reason to avoid not doing this in a micro is people often run
+ALTER EXTENSION or SELECt postgis_extensions_upgrade() in a micro.
+ * For the postgis extension, these should go in postgis/postgis_legacy.c the stub will look something like this.
+ POSTGIS_DEPRECATE("2.0.0", postgis_uses_stats)
+ Note the specification of the function it was removed and the name of the function
+ * For postgis_sfcgal, deprecated C api functions should go in sfcgal/postgis_sfcgal_legacy.c
+ * For postgis_raster, raster/rt_pg/rtpg_legacy.c
+ * postgis_topology extension has never had any deprecated functions so there is currently no legacy file for it.
+ If there comes a need to deprecate C functions, then a file topology/postgis_topology_legacy.c will be created to store these.
+ * postgis_tiger_geocoder is all sql and plpgsql so it has no C backing functions.
+Why do we even bother replacing a good function with a function that throws an error? Because of pg_upgrade tool used
+to upgrade PostgreSQL clusters. When pg_upgrade runs, it does not use the regular CREATE EXTENSION routine that loads function definitions from
+a file. Instead it uses a naked CREATE EXTENSION and then tries to load all functions /types /etc/ from the old databases as they existed
+meaning they point at the same .so, .dll, .dylib whatever. When it tries to load these in, it validates the library to make sure said
+functions exist in the library. If these functions don't it will bail and pg_upgrade will fail. It however will do fine
+not complain if the function exists even if all the function knows how to do is throw an error.
+WHY oh WHY does it use old signatures in an old database instead of a fresh CREATE EXTENSION install?
+Primarily because objects are referenced by object identifiers AKA oids in views, tables, you name it, and if you create new function
+from scratch, even if it has the same exact definition as the old, it does not have the same OID.
+As such all db internal references would be broken
+if you try to overlay the old def structures onto the new extension install.
+So this whole care of legacy functions is to appease pg_upgrade.
+UPGRADING SQL Api functions
+For most SQL Api functions, nothing special needs to be done beyond
+noting a CHANGED in version or AVAILABILITY in the respective .sql.in files.
+The SQL Api definitions are found in following places:
+* postgis extension, postgis/postgis_sql.in, geography.sql.in, postgis.bin.sql.in, or postgis_spgist.sql.in
+* postgis_raster extension raster/rt_pg/rtpostgis.sql.in
+* postgis_sfcgal extension sfcgal/sfcgal.sql.in
+* postgis_topology - topology/sql/*.sql.in
+We use perl scripts to stitch together these various SQL and
+read meta comments to determine what to do during an upgrade.
+The utils/create_upgrade.pl is the script that is tasked with creating upgrade scripts.
+The various notes you put in .sql.in files take the following form and precede the function/type/etc definition:
+* -- Availability: Is only informational 2.0.0 where 2.0.0 represents the version it was introduced in.
+* -- Changed: Is only informational. You'll often see an Availability comment followed by a changed comment.
+ e.g.
+ -- Availability: 0.1.0
+ -- Changed: 2.0.0 use gserialized selectivity estimators
+* -- Replaces: is both informational and also instructs the perl upgrade script to protect the user from some upgrade pains.
+ You use Replaces instead of just a simple Changed, if you are changing inputs to the function or changing
+ outputs of the function. So any change to the api
+ Such a comment would look something like:
+ -- Availability: 2.1.0
+ -- Changed: 3.1.0 - add zvalue=0.0 parameter
+ -- Replaces ST_Force3D(geometry) deprecated in 3.1.0
+ When utils/create_upgrade.pl script comes across a Replaces clause, the perl script will change the statement to do the following
+ 1) Finds the old definition
+ 2) renames the old definition to ST_Force3D_deprecated_by_postgis_310
+ 3) Installs the new version of the function.
+ 4) At the end of the upgrade script, it will try to drop the function. If the old function is bound
+ to user objects, it will leave the old function alone and warn the user as part of the upgrade, that they have objects bound to an old signature.
+ Why do we do this? Because all objects are bound by oids and not names. So if a user has a view or materialized view, it will be bound to
+ ST_Force3D_deprecated_by_postgis_310 and not the new ST_Force3D. We can't drop things bound to user objects without executing a
+ DROP ... CASCADE, which will destroy user objects.
+For some objects such as types and casts, comments are not sufficient to get create_upgrade.pl to do the right thing.
+In these cases you need to do this work yourself as needed.
+Case in point, if you are removing a signature and have no replacement for it. You just want to drop it.
+In these cases you'll put code in the before_upgrade.sql or after_upgrade.sql corresponding to the extension you are changing.
+* postgis extension - postgis/postgis_before_upgrade.sql , postgis/postgis_after_upgrade.sql
+* postgis_sfcgal - sfcgal/sfcgal_before_upgrade.sql.in, sfcgal/sfcgal_after_upgrade.sql.in
+* postgis_topology - sfcgal/topology_before_upgrade.sql.in, sfcgal/topology_after_upgrade.sql.in
+Helper function calls you'll find in these scripts are the following and are defined in postgis/common_before_upgrade.sql and dropped in
+postgis/common_after_upgrade.sql
+* _postgis_drop_function_by_signature
+* _postgis_drop_function_by_identity
+# these ones are new in 3.6.0 to handle the very delicate major upgrade of topology
+* _postgis_drop_cast_by_types
+* _postgis_add_column_to_table
Summary of changes:
doc/developer.txt | 143 ++++++++++++++++++++++++++++++++++++++++++++++++++++++
1 file changed, 143 insertions(+)
create mode 100644 doc/developer.txt
hooks/post-receive
