[PostGIS] #5964: debbie can't build PG19 with meson
PostGIS trac at osgeo.org
Fri Aug 15 22:08:21 PDT 2025
  Reporter:  robe          |      Owner:  robe
      Type:  defect        |     Status:  closed
  Priority:  medium        |  Milestone:  Website Management, Bots
 Component:  QA/buildbots  |    Version:  master
Resolution:  fixed         |   Keywords:
Changes (by robe):
 * resolution:   => fixed
 * status:  new => closed
Comment:
 I changed to install meson from pip instead of apt install meson.
 This seems to be working as it got past that spot and looks to be
 compiling.
 So to install did this:
 su jenkins
 pip3 install --user meson #gets installed in /var/lib/jenkins/.local/bin
 Then as part of the postgresql build script I have at top.
 export PATH=${PATH}:/var/lib/jenkins/.local/bin
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5964#comment:1>
