[PostGIS] #5965: PG19 compile is spitting out warnings about PG_GSERIALIZED_DATUM_NEEDS_DETOAST
PostGIS trac at osgeo.org
Fri Aug 15 22:17:09 PDT 2025
 Reporter:  robe     |      Owner:  robe
     Type:  defect   |     Status:  assigned
 Priority:  blocker  |  Milestone:  PostGIS 3.7.0
Component:  postgis  |    Version:  master
 Keywords:           |
 GHA latest/latest is set to throw errors on warnings.  latest/garden is
 regressing fine since it just compiles and runs garden test, but
 latest/latest is complaining since August 8th about
 ../libpgcommon/lwgeom_pg.h:93:30: note: in definition of macro
 'PG_GSERIALIZED_DATUM_NEEDS_DETOAST'
    93 |         (VARATT_IS_EXTENDED((datum)) ||
 VARATT_IS_EXTERNAL((datum)) || VARATT_IS_COMPRESSED((datum)))
 ../libpgcommon/lwgeom_pg.h:95:44: note: in expansion of macro
 'PG_GETARG_DATUM'
    95 |         PG_GSERIALIZED_DATUM_NEEDS_DETOAST(PG_GETARG_DATUM(varno))
 lwgeom_ogc.c:103:29: note: in expansion of macro
 'PG_GETARG_GSERIALIZED_HEADER'
   103 |         GSERIALIZED *geom = PG_GETARG_GSERIALIZED_HEADER(0);
 In file included from ../libpgcommon/lwgeom_pg.h:30:
 /usr/local/pgsql/include/server/varatt.h:410:32: note: expected 'const
 void *' but argument is of type 'Datum' {aka 'long unsigned int'}
   410 | VARATT_IS_EXTENDED(const void *PTR)
 /usr/local/pgsql/include/server/fmgr.h:268:50: error: passing argument 1
 of 'VARATT_IS_EXTERNAL' makes pointer from integer without a cast [-Werror
 =int-conversion]
   268 | #define PG_GETARG_DATUM(n)       (fcinfo->args[n].value)
 ../libpgcommon/lwgeom_pg.h:93:61: note: in definition of macro
 'PG_GETARG_DATUM'
 /usr/local/pgsql/include/server/varatt.h:354:32: note: expected 'const
   354 | VARATT_IS_EXTERNAL(const void *PTR)
 of 'VARATT_IS_COMPRESSED' makes pointer from integer without a cast
 [-Werror=int-conversion]
 ../libpgcommon/lwgeom_pg.h:93:94: note: in definition of macro
 'PG_GETARG_DATUM'
 /usr/local/pgsql/include/server/varatt.h:347:34: note: expected 'const
   347 | VARATT_IS_COMPRESSED(const void *PTR)
 lwgeom_ogc.c: In function 'LWGEOM_getTYPE':
 of 'VARATT_IS_EXTENDED' makes pointer from integer without a cast [-Werror
 =int-conversion]
 'PG_GETARG_DATUM'
 lwgeom_ogc.c:129:16: note: in expansion of macro
   129 |         gser = PG_GETARG_GSERIALIZED_HEADER(0);
 =int-conversion]
 'PG_GETARG_DATUM'
 'PG_GETARG_DATUM'
 lwgeom_ogc.c: In function 'geometry_geometrytype':
 =int-conversion]
 'PG_GETARG_DATUM'
 lwgeom_ogc.c:204:16: note: in expansion of macro
   204 |         gser = PG_GETARG_GSERIALIZED_HEADER(0);
 =int-conversion]
 'PG_GETARG_DATUM'
 'PG_GETARG_DATUM'
 echo "COMMIT;" >> postgis_upgrade.sql
 In file included from lwgeom_functions_basic.c:36:
 lwgeom_functions_basic.c: In function 'LWGEOM_zmflag':
 =int-conversion]
 'PG_GETARG_DATUM'
 lwgeom_functions_basic.c:1981:27: note: in expansion of macro
  1981 |         GSERIALIZED *in = PG_GETARG_GSERIALIZED_HEADER(0);
 /usr/local/pgsql/include/server/utils/expandeddatum.h:47,
                  from /usr/local/pgsql/include/server/utils/array.h:65,
                  from lwgeom_functions_basic.c:28:
 =int-conversion]
 'PG_GETARG_DATUM'
 'PG_GETARG_DATUM'
 lwgeom_functions_basic.c: In function 'LWGEOM_hasz':
 =int-conversion]
 'PG_GETARG_DATUM'
 lwgeom_functions_basic.c:1995:27: note: in expansion of macro
  1995 |         GSERIALIZED *in = PG_GETARG_GSERIALIZED_HEADER(0);
 =int-conversion]
 'PG_GETARG_DATUM'
 'PG_GETARG_DATUM'
 lwgeom_functions_basic.c: In function 'LWGEOM_hasm':
 =int-conversion]
 'PG_GETARG_DATUM'
 lwgeom_functions_basic.c:2002:27: note: in expansion of macro
  2002 |         GSERIALIZED *in = PG_GETARG_GSERIALIZED_HEADER(0);
 I'm going to take latest/latest out of running since we are already
 testing PG18.  I think it's a little too early to start worrying about
 PG19. We can worry about PG19 after we release PostGIS 3.6.0
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5965>
