[PostGIS] #5971: Error building from tar ball
trac at osgeo.org
Thu Aug 21 07:54:03 PDT 2025
Reporter: robe | Owner: robe
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 3.6.0
Component: tiger geocoder | Version: master
Keywords: |
MobilityDb folks after fix #5969 that they aren't getting that error
anymore, but still getting
---- Making all in liblwgeom
make[1]: Entering directory '/home/esteban/src/postgis-3.6.0rc1/liblwgeom'
make[1]: Nothing to be done for 'all'.
make[1]: Leaving directory '/home/esteban/src/postgis-3.6.0rc1/liblwgeom'
---- Making all in deps
make[1]: Entering directory '/home/esteban/src/postgis-3.6.0rc1/deps'
make -C wagyu libwagyu.la
make -C ryu libryu.la
make -C flatgeobuf libflatgeobuf.la
make[2]: Entering directory '/home/esteban/src/postgis-3.6.0rc1/deps/ryu'
make[2]: 'libryu.la' is up to date.
make[2]: Leaving directory '/home/esteban/src/postgis-3.6.0rc1/deps/ryu'
'/home/esteban/src/postgis-3.6.0rc1/deps/flatgeobuf'
make[2]: 'libflatgeobuf.la' is up to date.
'/home/esteban/src/postgis-3.6.0rc1/deps/wagyu'
make[2]: 'libwagyu.la' is up to date.
make[2]: Leaving directory '/home/esteban/src/postgis-3.6.0rc1/deps/wagyu'
make[1]: Leaving directory '/home/esteban/src/postgis-3.6.0rc1/deps'
---- Making all in libpgcommon
'/home/esteban/src/postgis-3.6.0rc1/libpgcommon'
---- Making all in postgis
make[1]: Entering directory '/home/esteban/src/postgis-3.6.0rc1/postgis'
make[1]: Leaving directory '/home/esteban/src/postgis-3.6.0rc1/postgis'
---- Making all in regress
make[1]: Entering directory '/home/esteban/src/postgis-3.6.0rc1/regress'
make[1]: Leaving directory '/home/esteban/src/postgis-3.6.0rc1/regress'
---- Making all in doc
make[1]: Entering directory '/home/esteban/src/postgis-3.6.0rc1/doc'
make[1]: Leaving directory '/home/esteban/src/postgis-3.6.0rc1/doc'
---- Making all in loader
make[1]: Entering directory '/home/esteban/src/postgis-3.6.0rc1/loader'
make[1]: Leaving directory '/home/esteban/src/postgis-3.6.0rc1/loader'
---- Making all in utils
make[1]: Entering directory '/home/esteban/src/postgis-3.6.0rc1/utils'
make[1]: Leaving directory '/home/esteban/src/postgis-3.6.0rc1/utils'
---- Making all in extensions
'/home/esteban/src/postgis-3.6.0rc1/extensions'
for DIR in postgis postgis_tiger_geocoder; do \
echo "---- Making all in ${DIR}"; \
make -C "${DIR}" all || exit 1; \
done
'/home/esteban/src/postgis-3.6.0rc1/extensions/postgis'
make[2]: Nothing to be done for 'all'.
---- Making all in postgis_tiger_geocoder
'/home/esteban/src/postgis-3.6.0rc1/extensions/postgis_tiger_geocoder'
mkdir -p expected
make[2]: *** No rule to make target
'../../extras/tiger_geocoder/utility/utmzone.sql', needed by
'sql/tiger_geocoder.sql.in'. Stop.
make[2]: *** Waiting for unfinished jobs....
make[1]: *** [Makefile:36: all] Error 1
make[1]: Leaving directory '/home/esteban/src/postgis-3.6.0rc1/extensions'
make: *** [GNUmakefile:36: all] Error 1
esteban at P-ULB-PF59GXL3:~/src/postgis-3.6.0rc1$
I have to investigate what the issue is here. I think someone else was
complaining about a sequencing issue so might be about that.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5971>
