[SCM] PostGIS branch master updated. 3.6.0rc1-33-g02baae6a4
Sun Aug 24 23:54:41 PDT 2025
the project "PostGIS".
       via  02baae6a4da8ce753d0a851d6a8253b54313d046 (commit)
      from  b7ca6ec2229b825e0af8c367930b857f39bcb07c (commit)
revisions in full, below.
commit 02baae6a4da8ce753d0a851d6a8253b54313d046
Author: Regina Obe <lr at pcorp.us>
Date:   Mon Aug 25 02:54:04 2025 -0400
    Flip version to PostGIS 3.6.0rc2
diff --git a/NEWS b/NEWS
index be2c04e53..2f934aa88 100644
--- a/NEWS
+++ b/NEWS
@@ -1,5 +1,5 @@
 PostGIS 3.6.0rc2
-2025/08/xx
+2025/08/25
 This version requires PostgreSQL 12-18beta3, GEOS 3.8 or higher, and Proj 6.1+.
 To take advantage of all features, GEOS 3.14+ is needed.
 To take advantage of all SFCGAL features, SFCGAL 2.2+ is needed.
@@ -45,9 +45,9 @@ Denys Kovshun (Ukrainian Team)
     to schema qualify dependent extensions, switch to use typmod for tiger tables
     (Regina Obe)
-* Deprecated / Removed signatures *
+* Deprecated / Removed signatures *
- - #3110, GT-242, [topology] numerous topology functions that accepted integer
+ - #3110, GT-242, [topology] numerous topology functions that accepted integer
           replaced with bigint versions to support both integer and bigint inputs
           (Ayo Adesugba, U.S. Census Bureau)
  - #5498 Drop st_approxquantile(raster, double precision), wasn't usable as it triggered
diff --git a/README.postgis b/README.postgis
index 51a1dff89..65494b7a9 100644
--- a/README.postgis
+++ b/README.postgis
@@ -1,8 +1,8 @@
 PostGIS - Geographic Information Systems Extensions to PostgreSQL
-:Version: 3.6.0rc1
-:Date: 2025-08-18
+:Version: 3.6.0rc2
+:Date: 2025-08-25
 :Website: https://postgis.net
 This distribution contains a module which implements GIS simple features, ties
diff --git a/Version.config b/Version.config
index cf6d63e9f..d6a12d87d 100644
--- a/Version.config
+++ b/Version.config
@@ -5,7 +5,7 @@
 POSTGIS_MAJOR_VERSION=3
 POSTGIS_MINOR_VERSION=6
-POSTGIS_MICRO_VERSION=0dev
+POSTGIS_MICRO_VERSION=0rc2
 # Liblwgeom interface versioning, reset to 0:0:0 (cur:age:rev)
 # when changing POSTGIS_MINOR_VERSION
diff --git a/doc/po/templates/postgis-manual.pot b/doc/po/templates/postgis-manual.pot
index 1f5a6c2ed..c8d019da2 100644
--- a/doc/po/templates/postgis-manual.pot
+++ b/doc/po/templates/postgis-manual.pot
@@ -6686,9 +6686,12 @@ msgstr ""
 #. Tag: para
 #, no-c-format
-msgid ""
-"Disable topology support. There is no corresponding library as all logic "
-"needed for topology is in postgis-&last_release_version; library."
+msgid "Disables tiger geocoder support."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "Compile without topology support."
 msgstr ""
 #. Tag: para
@@ -35191,12 +35194,12 @@ msgstr ""
 #. Tag: title
 #, no-c-format
-msgid "PostGIS 3.6.0"
+msgid "PostGIS 3.6.0rc2"
 msgstr ""
 #. Tag: para
 #, no-c-format
-msgid "2025/xx/xx"
+msgid "2025/08/25"
 msgstr ""
 #. Tag: para
diff --git a/doc/release_notes.xml b/doc/release_notes.xml
index d80ae0656..9fa7182f7 100644
--- a/doc/release_notes.xml
+++ b/doc/release_notes.xml
@@ -3,8 +3,8 @@
   <title>Appendix</title>
     <subtitle>Release Notes</subtitle>
         <section>
-            <title>PostGIS 3.6.0</title>
-            <para>2025/xx/xx</para>
+            <title>PostGIS 3.6.0rc2</title>
+            <para>2025/08/25</para>
                         <para>This version requires PostgreSQL 12-18beta3, GEOS 3.8 or higher, and Proj 6.1+.
             To take advantage of all SFCGAL features, SFCGAL 2.2+ is needed.</para>
diff --git a/extensions/upgradeable_versions.mk b/extensions/upgradeable_versions.mk
index 2eba06641..5b22ffb90 100644
--- a/extensions/upgradeable_versions.mk
+++ b/extensions/upgradeable_versions.mk
@@ -114,4 +114,5 @@ UPGRADEABLE_VERSIONS = \
 	3.5.3 \
 	3.6.0alpha1 \
 	3.6.0beta1 \
-	3.6.0rc1
+	3.6.0rc1 \
+	3.6.0dev
Summary of changes:
 NEWS                                |  6 +++---
 README.postgis                      |  4 ++--
 Version.config                      |  2 +-
 doc/po/templates/postgis-manual.pot | 13 ++++++++-----
 doc/release_notes.xml               |  4 ++--
 extensions/upgradeable_versions.mk  |  3 ++-
 6 files changed, 18 insertions(+), 14 deletions(-)
hooks/post-receive
