[SCM] PostGIS branch master updated. 3.6.0rc1-34-g343ff652c
git at osgeo.org
git at osgeo.org
Sun Aug 24 23:59:22 PDT 2025
the project "PostGIS".
via 343ff652c1fae9a4864b364d1053fce480130ce7 (commit)
from 02baae6a4da8ce753d0a851d6a8253b54313d046 (commit)
revisions in full, below.
commit 343ff652c1fae9a4864b364d1053fce480130ce7
Author: Weblate <noreply at weblate.org>
Date: Mon Aug 25 06:55:02 2025 +0000
Update translation files
Updated by "Update PO files to match POT (msgmerge)" hook in Weblate.
Translation: postgis/PostGIS Manual
Translate-URL: https://weblate.osgeo.org/projects/postgis/postgis-manual/
diff --git a/doc/po/da/postgis-manual.po b/doc/po/da/postgis-manual.po
index 8e70095f0..8e36760b3 100644
--- a/doc/po/da/postgis-manual.po
+++ b/doc/po/da/postgis-manual.po
@@ -6705,9 +6705,12 @@ msgstr ""
#. Tag: para
#, no-c-format
-msgid ""
-"Disable topology support. There is no corresponding library as all logic "
-"needed for topology is in postgis-&last_release_version; library."
+msgid "Disables tiger geocoder support."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "Compile without topology support."
msgstr ""
#. Tag: para
@@ -35210,12 +35213,12 @@ msgstr ""
#. Tag: title
#, no-c-format
-msgid "PostGIS 3.6.0"
+msgid "PostGIS 3.6.0rc2"
msgstr ""
#. Tag: para
#, no-c-format
-msgid "2025/xx/xx"
+msgid "2025/08/25"
msgstr ""
#. Tag: para
diff --git a/doc/po/de/postgis-manual.po b/doc/po/de/postgis-manual.po
index 39975d941..3f1825b58 100644
--- a/doc/po/de/postgis-manual.po
+++ b/doc/po/de/postgis-manual.po
@@ -8963,13 +8963,13 @@ msgstr "Ohne Rasterunterstützung kompilieren."
#. Tag: para
#, no-c-format
-msgid ""
+msgstr ""
+#. Tag: para
+#, no-c-format
msgstr ""
-"Ausschalten der Topologie Unterstützung. Es existiert keine entsprechende "
-"Bibliothek, da sich die gesamte benötigte Logik in der postgis-"
-"&last_release_version; Bibliothek befindet."
#. Tag: para
#, no-c-format
@@ -45938,12 +45938,12 @@ msgstr "Anmerkungen zur Release"
#. Tag: title
#, no-c-format
msgstr ""
#. Tag: para
#, no-c-format
-msgid "2025/xx/xx"
+msgid "2025/08/25"
msgstr ""
#. Tag: para
@@ -52674,6 +52674,15 @@ msgstr "2.5/3D-Unterstützung"
msgid "Supports geography"
msgstr "Unterstützt Geographie"
+#, no-c-format
+#~ msgid ""
+#~ "Disable topology support. There is no corresponding library as all logic "
+#~ "needed for topology is in postgis-&last_release_version; library."
+#~ msgstr ""
+#~ "Ausschalten der Topologie Unterstützung. Es existiert keine entsprechende "
+#~ "Bibliothek, da sich die gesamte benötigte Logik in der postgis-"
+#~ "&last_release_version; Bibliothek befindet."
#, fuzzy, no-c-format
#~ msgid ""
#~ "PostgreSQL &min_postgres_version; - &max_postgres_version;. A complete "
diff --git a/doc/po/es/postgis-manual.po b/doc/po/es/postgis-manual.po
index 71e054c47..f18e0e63a 100644
--- a/doc/po/es/postgis-manual.po
+++ b/doc/po/es/postgis-manual.po
@@ -7573,9 +7573,12 @@ msgstr ""
#. Tag: para
#, no-c-format
-msgid ""
+msgstr ""
+#. Tag: para
+#, no-c-format
msgstr ""
#. Tag: para
@@ -37349,12 +37352,12 @@ msgstr "Notas de la versión"
#. Tag: title
#, no-c-format
msgstr ""
#. Tag: para
#, no-c-format
-msgid "2025/xx/xx"
+msgid "2025/08/25"
msgstr ""
#. Tag: para
diff --git a/doc/po/fr/postgis-manual.po b/doc/po/fr/postgis-manual.po
index 7c2aaba22..b05ca0f2b 100644
--- a/doc/po/fr/postgis-manual.po
+++ b/doc/po/fr/postgis-manual.po
@@ -8924,13 +8924,13 @@ msgstr "Compilation sans support des raster."
#. Tag: para
#, no-c-format
-msgid ""
+msgstr ""
+#. Tag: para
+#, no-c-format
msgstr ""
-"Désactive le support des topologies. Il n'y a pas de bibliothèque "
-"correspondante car toute la logique requise pour les topologies est incluse "
-"dans postgis-&last_release_version;."
#. Tag: para
#, no-c-format
@@ -45926,13 +45926,13 @@ msgstr "Notes de version"
#. Tag: title
#, no-c-format
-msgstr "PostGIS 3.6.0"
+msgstr ""
#. Tag: para
#, no-c-format
-msgid "2025/xx/xx"
-msgstr "2025/xx/xx"
+msgid "2025/08/25"
+msgstr ""
#. Tag: para
#, no-c-format
@@ -52688,6 +52688,23 @@ msgstr "Support 2.5/3D"
msgstr "Prise en charge du type geography"
+#, no-c-format
+#~ msgid ""
+#~ msgstr ""
+#~ "Désactive le support des topologies. Il n'y a pas de bibliothèque "
+#~ "correspondante car toute la logique requise pour les topologies est "
+#~ "incluse dans postgis-&last_release_version;."
+#, no-c-format
+#~ msgid "PostGIS 3.6.0"
+#~ msgstr "PostGIS 3.6.0"
+#, no-c-format
+#~ msgid "2025/xx/xx"
+#~ msgstr "2025/xx/xx"
#, no-c-format
#~ msgid ""
diff --git a/doc/po/it_IT/postgis-manual.po b/doc/po/it_IT/postgis-manual.po
index 24bb24853..e5c5afa57 100644
--- a/doc/po/it_IT/postgis-manual.po
+++ b/doc/po/it_IT/postgis-manual.po
@@ -7539,13 +7539,13 @@ msgstr "Compilazione senza supporto raster."
#. Tag: para
#, no-c-format
-msgid ""
+msgstr ""
+#. Tag: para
+#, no-c-format
msgstr ""
-"Disabilita il supporto per la topologia. Non esiste una libreria "
-"corrispondente, poiché tutta la logica necessaria per la topologia si trova "
-"nella libreria postgis-&last_release_version;."
#. Tag: para
#, no-c-format
@@ -37904,12 +37904,12 @@ msgstr ""
#. Tag: title
#, no-c-format
msgstr ""
#. Tag: para
#, no-c-format
-msgid "2025/xx/xx"
+msgid "2025/08/25"
msgstr ""
#. Tag: para
@@ -43163,6 +43163,15 @@ msgstr "Supporta il 2.5/3D"
msgstr "Supporta il tipo geography"
+#, no-c-format
+#~ msgid ""
+#~ msgstr ""
+#~ "Disabilita il supporto per la topologia. Non esiste una libreria "
+#~ "corrispondente, poiché tutta la logica necessaria per la topologia si "
+#~ "trova nella libreria postgis-&last_release_version;."
#, no-c-format
#~ msgid ""
diff --git a/doc/po/ja/postgis-manual.po b/doc/po/ja/postgis-manual.po
index 5dede142f..ce5137d17 100644
--- a/doc/po/ja/postgis-manual.po
+++ b/doc/po/ja/postgis-manual.po
@@ -8571,13 +8571,13 @@ msgstr "ラスタ機能なしでコンパイルします。"
#. Tag: para
#, no-c-format
-msgid ""
+msgstr ""
+#. Tag: para
+#, no-c-format
msgstr ""
-"トポロジ対応を無くしてコンパイルします。トポロジに必要なロジックは全て"
-"postgis-&last_release_version;ライブラリ内に作られるので、関連ライブラリはあ"
-"りません。"
#. Tag: para
#, no-c-format
@@ -43774,13 +43774,13 @@ msgstr "リリースノート"
#. Tag: title
#, no-c-format
+msgstr ""
#. Tag: para
#, no-c-format
-msgid "2025/xx/xx"
+msgid "2025/08/25"
+msgstr ""
#. Tag: para
#, no-c-format
@@ -50168,6 +50168,23 @@ msgstr "2.5次元/3次元対応"
msgstr "ジオグラフィ対応"
+#, no-c-format
+#~ msgid ""
+#~ msgstr ""
+#~ "トポロジ対応を無くしてコンパイルします。トポロジに必要なロジックは全て"
+#~ "postgis-&last_release_version;ライブラリ内に作られるので、関連ライブラリは"
+#~ "ありません。"
+#, no-c-format
+#, no-c-format
#, no-c-format
#~ msgid "PostGIS 3.6.0rc1"
#~ msgstr "PostGIS 3.6.0rc1"
diff --git a/doc/po/ka/postgis-manual.po b/doc/po/ka/postgis-manual.po
index 90da0b029..a96be6d2b 100644
--- a/doc/po/ka/postgis-manual.po
+++ b/doc/po/ka/postgis-manual.po
@@ -6688,9 +6688,12 @@ msgstr ""
#. Tag: para
#, no-c-format
-msgid ""
+msgstr ""
+#. Tag: para
+#, no-c-format
msgstr ""
#. Tag: para
@@ -35193,12 +35196,12 @@ msgstr "გამოცემის შენიშვნები"
#. Tag: title
#, no-c-format
msgstr ""
#. Tag: para
#, no-c-format
-msgid "2025/xx/xx"
+msgid "2025/08/25"
msgstr ""
#. Tag: para
diff --git a/doc/po/ko_KR/postgis-manual.po b/doc/po/ko_KR/postgis-manual.po
index aeabddf78..be9e4da14 100644
--- a/doc/po/ko_KR/postgis-manual.po
+++ b/doc/po/ko_KR/postgis-manual.po
@@ -7882,9 +7882,12 @@ msgstr "래스터 지원 설치"
#. Tag: para
#, no-c-format
-msgid ""
+msgstr ""
+#. Tag: para
+#, no-c-format
msgstr ""
#. Tag: para
@@ -39687,12 +39690,12 @@ msgstr ""
#. Tag: title
#, no-c-format
msgstr ""
#. Tag: para
#, no-c-format
-msgid "2025/xx/xx"
+msgid "2025/08/25"
msgstr ""
#. Tag: para
diff --git a/doc/po/pl/postgis-manual.po b/doc/po/pl/postgis-manual.po
index 69bbaf917..e76b450e0 100644
--- a/doc/po/pl/postgis-manual.po
+++ b/doc/po/pl/postgis-manual.po
@@ -6713,9 +6713,12 @@ msgstr ""
#. Tag: para
#, no-c-format
-msgid ""
+msgstr ""
+#. Tag: para
+#, no-c-format
msgstr ""
#. Tag: para
@@ -35387,12 +35390,12 @@ msgstr ""
#. Tag: title
#, no-c-format
msgstr ""
#. Tag: para
#, no-c-format
-msgid "2025/xx/xx"
+msgid "2025/08/25"
msgstr ""
#. Tag: para
diff --git a/doc/po/pt_BR/postgis-manual.po b/doc/po/pt_BR/postgis-manual.po
index 69d45602c..61310f97a 100644
--- a/doc/po/pt_BR/postgis-manual.po
+++ b/doc/po/pt_BR/postgis-manual.po
@@ -7953,9 +7953,12 @@ msgstr "Instalar suporte a raster"
#. Tag: para
#, no-c-format
-msgid ""
+msgstr ""
+#. Tag: para
+#, no-c-format
msgstr ""
#. Tag: para
@@ -40101,12 +40104,12 @@ msgstr "Notas de Lançamento"
#. Tag: title
#, no-c-format
msgstr ""
#. Tag: para
#, no-c-format
-msgid "2025/xx/xx"
+msgid "2025/08/25"
msgstr ""
#. Tag: para
diff --git a/doc/po/ro/postgis-manual.po b/doc/po/ro/postgis-manual.po
index a17d0ffca..c8a191e17 100644
--- a/doc/po/ro/postgis-manual.po
+++ b/doc/po/ro/postgis-manual.po
@@ -6723,9 +6723,12 @@ msgstr ""
#. Tag: para
#, no-c-format
-msgid ""
+msgstr ""
+#. Tag: para
+#, no-c-format
msgstr ""
#. Tag: para
@@ -35228,12 +35231,12 @@ msgstr ""
#. Tag: title
#, no-c-format
msgstr ""
#. Tag: para
#, no-c-format
-msgid "2025/xx/xx"
+msgid "2025/08/25"
msgstr ""
#. Tag: para
diff --git a/doc/po/ru/postgis-manual.po b/doc/po/ru/postgis-manual.po
index 8129dd350..898f65657 100644
--- a/doc/po/ru/postgis-manual.po
+++ b/doc/po/ru/postgis-manual.po
@@ -6719,9 +6719,12 @@ msgstr ""
#. Tag: para
#, no-c-format
-msgid ""
+msgstr ""
+#. Tag: para
+#, no-c-format
msgstr ""
#. Tag: para
@@ -35245,12 +35248,12 @@ msgstr "Замечания к версии"
#. Tag: title
#, no-c-format
msgstr ""
#. Tag: para
#, no-c-format
-msgid "2025/xx/xx"
+msgid "2025/08/25"
msgstr ""
#. Tag: para
diff --git a/doc/po/sv/postgis-manual.po b/doc/po/sv/postgis-manual.po
index 9ccf44564..8f9b908a7 100644
--- a/doc/po/sv/postgis-manual.po
+++ b/doc/po/sv/postgis-manual.po
@@ -8755,13 +8755,13 @@ msgstr "Kompilera utan stöd för raster."
#. Tag: para
#, no-c-format
-msgid ""
+msgstr ""
+#. Tag: para
+#, no-c-format
msgstr ""
-"Inaktivera stöd för topologi. Det finns inget motsvarande bibliotek eftersom "
-"all logik som behövs för topologi finns i biblioteket postgis-"
-"&last_release_version;."
#. Tag: para
#, no-c-format
@@ -45000,12 +45000,12 @@ msgstr "Anteckningar för release"
#. Tag: title
#, no-c-format
msgstr ""
#. Tag: para
#, no-c-format
-msgid "2025/xx/xx"
+msgid "2025/08/25"
msgstr ""
#. Tag: para
@@ -51581,6 +51581,15 @@ msgstr "2.5/3D-stöd"
msgstr "Stödjer geografi"
+#, no-c-format
+#~ msgid ""
+#~ msgstr ""
+#~ "Inaktivera stöd för topologi. Det finns inget motsvarande bibliotek "
+#~ "eftersom all logik som behövs för topologi finns i biblioteket postgis-"
+#~ "&last_release_version;."
#, no-c-format
#~ msgid "PostGIS 3.6.0beta1"
#~ msgstr "PostGIS 3.6.0beta1"
diff --git a/doc/po/zh_Hans/postgis-manual.po b/doc/po/zh_Hans/postgis-manual.po
index 3fef68a87..2dd2635a3 100644
--- a/doc/po/zh_Hans/postgis-manual.po
+++ b/doc/po/zh_Hans/postgis-manual.po
@@ -7988,12 +7988,13 @@ msgstr "在没有栅格功能的情况下进行编译。"
#. Tag: para
#, no-c-format
-msgid ""
+msgstr ""
+#. Tag: para
+#, no-c-format
msgstr ""
-"在没有拓扑支持的情况下进行编译。 拓扑所需的所有逻辑都是在postgis-"
-"&last_release_version; 库中创建的,因此没有关联的库。"
#. Tag: para
#, no-c-format
@@ -41401,13 +41402,13 @@ msgstr "发行说明"
#. Tag: title
#, no-c-format
+msgstr ""
#. Tag: para
#, no-c-format
-msgid "2025/xx/xx"
+msgid "2025/08/25"
+msgstr ""
#. Tag: para
#, no-c-format
@@ -47357,6 +47358,22 @@ msgstr "2.5/3D 支持"
msgstr "支持地理"
+#, no-c-format
+#~ msgid ""
+#~ msgstr ""
+#~ "在没有拓扑支持的情况下进行编译。 拓扑所需的所有逻辑都是在postgis-"
+#~ "&last_release_version; 库中创建的,因此没有关联的库。"
+#, no-c-format
+#, no-c-format
#, no-c-format
#~ msgid "Add ST_ReclassExact to quickly remap values in raster (Paul Ramsey)"
#~ msgstr "新增 ST_ReclassExact,用于快速重映射栅格中的值(Paul Ramsey 提供)"
Summary of changes:
doc/po/da/postgis-manual.po | 13 ++++++++-----
doc/po/de/postgis-manual.po | 25 +++++++++++++++++--------
doc/po/es/postgis-manual.po | 13 ++++++++-----
doc/po/fr/postgis-manual.po | 37 +++++++++++++++++++++++++++----------
doc/po/it_IT/postgis-manual.po | 25 +++++++++++++++++--------
doc/po/ja/postgis-manual.po | 37 +++++++++++++++++++++++++++----------
doc/po/ka/postgis-manual.po | 13 ++++++++-----
doc/po/ko_KR/postgis-manual.po | 13 ++++++++-----
doc/po/pl/postgis-manual.po | 13 ++++++++-----
doc/po/pt_BR/postgis-manual.po | 13 ++++++++-----
doc/po/ro/postgis-manual.po | 13 ++++++++-----
doc/po/ru/postgis-manual.po | 13 ++++++++-----
doc/po/sv/postgis-manual.po | 25 +++++++++++++++++--------
doc/po/zh_Hans/postgis-manual.po | 35 ++++++++++++++++++++++++++---------
14 files changed, 195 insertions(+), 93 deletions(-)
hooks/post-receive
