[SCM] PostGIS branch master updated. 3.6.0rc2-2-g8444a216d
Mon Aug 25 01:12:41 PDT 2025
the project "PostGIS".
       via  8444a216d419863da8f33cbe39cc449af95a5b7a (commit)
      from  bd43da702878b6012a31e1f028e2cb5dfebef6bd (commit)
revisions in full, below.
commit 8444a216d419863da8f33cbe39cc449af95a5b7a
Author: Sandro Santilli <strk at kbt.io>
Date:   Mon Aug 25 10:12:27 2025 +0200
    Add script to produce line for Trac CI page
diff --git a/utils/ci-trac-line.sh b/utils/ci-trac-line.sh
new file mode 100755
index 000000000..7f88b3823
--- /dev/null
+++ b/utils/ci-trac-line.sh
@@ -0,0 +1,23 @@
+#!/bin/sh
+VER=master
+if test -n "$1"; then
+  VER=$1
+fi
+cat <<EOF
+||= '''${VER}''' =|| \\
+|| [[Image(https://debbie.postgis.net/buildStatus/icon?job=PostGIS_Make_Dist%2Flabel%3Ddebbie&build=last:\${params.reference=refs/heads/stable-${VER}}, link=https://debbie.postgis.net/view/PostGIS/job/PostGIS_Make_Dist/label=debbie/)]] || \\
+|| [[Image(https://debbie.postgis.net/buildStatus/icon?job=PostGIS_${VER}, link=https://debbie.postgis.net/view/PostGIS/job/PostGIS_${VER}/, alt=status, height="20", title='PG 12-17(branch), GDAL 3.5, GEOS 3.13')]] || \\
+|| [[Image(https://winnie.postgis.net/buildStatus/icon?job=PostGIS_${VER}, link=https://winnie.postgis.net/view/PostGIS/job/PostGIS_${VER}/, alt=status, height="20", title='PG 12-17, GDAL 3.7.1, GEOS 3.13 64-bit')]] || \\
+|| [[Image(https://dronie.osgeo.org/api/badges/postgis/postgis/status.svg?ref=refs/heads/stable-${VER}, link=https://dronie.osgeo.org/postgis/postgis?branch=stable-${VER}, alt=status)]] || \\
+|| [[Image(https://github.com/postgis/postgis/actions/workflows/ci.yml/badge.svg?branch=stable-${VER}, link=https://github.com/postgis/postgis/actions?query=branch%3Astable-${VER}, alt=status, height="20")]] || \\
+|| [[Image(https://woodie.osgeo.org/api/badges/postgis/postgis/status.svg?branch=stable-${VER}, link=https://woodie.osgeo.org/postgis/postgis?branch=stable-${VER}, alt=status)]] || \\
+|| [[Image(https://debbie.postgis.net/buildStatus/icon?job=PostGIS_Worker_Run/label=bessie&build=last:\${params.reference=refs/heads/stable-${VER}}, link=https://debbie.postgis.net/view/PostGIS/job/PostGIS_Worker_Run/label=bessie, alt=status, height="20", title='PG 10.1(branch), GDAL 2.1 branch, GEOS 3.6')]] || \\
+|| [[Image(https://debbie.postgis.net/buildStatus/icon?job=PostGIS_Worker_Run/label=bessie32&build=last:\${params.reference=refs/heads/stable-${VER}}, link=https://debbie.postgis.net/view/PostGIS/job/PostGIS_Worker_Run/label=bessie32, alt=status, height="20", title='PG 10.1(branch), GDAL 2.1 branch, GEOS 3.6')]] || \\
+|| [[Image(https://debbie.postgis.net/buildStatus/icon?job=PostGIS_Worker_Run/label=berrie&build=last:\${params.reference=refs/heads/stable-${VER}}, link=https://debbie.postgis.net/view/PostGIS/job/PostGIS_Worker_Run/label=berrie, alt=status, height="20", title='PG 12(branch), GDAL 2.4.0 branch, GEOS 3.7.1')]] || \\
+|| [[Image(https://debbie.postgis.net/buildStatus/icon?job=PostGIS_Worker_Run/label=berrie64&build=last:\${params.reference=refs/heads/stable-${VER}}, link=https://debbie.postgis.net/view/PostGIS/job/PostGIS_Worker_Run/label=berrie64?build=last:\${params.reference=refs/heads/stable-${VER}, alt=status, height="20", title='PG 12(branch), GDAL 2.4.0 branch, GEOS 3.7.1')]] || \\
+|| [[Image(https://api.cirrus-ci.com/github/postgis/postgis.svg?branch=stable-${VER}, link=https://cirrus-ci.com/github/postgis/postgis, alt=status, height="20", title='PG 13(branch), GDAL 3.5 branch, GEOS 3.12')]] || \\
+|| [[Image(https://gitlab.com/postgis/postgis/badges/stable-${VER}/pipeline.svg, link=https://gitlab.com/postgis/postgis/-/commits/stable-${VER}, alt=status, height="20", title='32/64 bit trixie, PG 15, GDAL 2.4.0, GEOS 3.7.1, PROJ 5.2.0')]] ||
+EOF
Summary of changes:
 utils/ci-trac-line.sh | 23 +++++++++++++++++++++++
 1 file changed, 23 insertions(+)
 create mode 100755 utils/ci-trac-line.sh
hooks/post-receive
