[SCM] PostGIS branch master updated. 3.6.0rc2-3-gd1306d73e
Mon Aug 25 01:18:41 PDT 2025
the project "PostGIS".
       via  d1306d73e4ca1d1c9ffef3cde56a9e1bfe8eb363 (commit)
      from  8444a216d419863da8f33cbe39cc449af95a5b7a (commit)
revisions in full, below.
commit d1306d73e4ca1d1c9ffef3cde56a9e1bfe8eb363
Author: Sandro Santilli <strk at kbt.io>
Date:   Mon Aug 25 10:18:32 2025 +0200
    Add inaf badge
diff --git a/utils/ci-trac-line.sh b/utils/ci-trac-line.sh
index 7f88b3823..9c3006245 100755
--- a/utils/ci-trac-line.sh
+++ b/utils/ci-trac-line.sh
@@ -19,5 +19,6 @@ cat <<EOF
 || [[Image(https://debbie.postgis.net/buildStatus/icon?job=PostGIS_Worker_Run/label=berrie&build=last:\${params.reference=refs/heads/stable-${VER}}, link=https://debbie.postgis.net/view/PostGIS/job/PostGIS_Worker_Run/label=berrie, alt=status, height="20", title='PG 12(branch), GDAL 2.4.0 branch, GEOS 3.7.1')]] || \\
 || [[Image(https://debbie.postgis.net/buildStatus/icon?job=PostGIS_Worker_Run/label=berrie64&build=last:\${params.reference=refs/heads/stable-${VER}}, link=https://debbie.postgis.net/view/PostGIS/job/PostGIS_Worker_Run/label=berrie64?build=last:\${params.reference=refs/heads/stable-${VER}, alt=status, height="20", title='PG 12(branch), GDAL 2.4.0 branch, GEOS 3.7.1')]] || \\
 || [[Image(https://api.cirrus-ci.com/github/postgis/postgis.svg?branch=stable-${VER}, link=https://cirrus-ci.com/github/postgis/postgis, alt=status, height="20", title='PG 13(branch), GDAL 3.5 branch, GEOS 3.12')]] || \\
-|| [[Image(https://gitlab.com/postgis/postgis/badges/stable-${VER}/pipeline.svg, link=https://gitlab.com/postgis/postgis/-/commits/stable-${VER}, alt=status, height="20", title='32/64 bit trixie, PG 15, GDAL 2.4.0, GEOS 3.7.1, PROJ 5.2.0')]] ||
+|| [[Image(https://gitlab.com/postgis/postgis/badges/stable-${VER}/pipeline.svg, link=https://gitlab.com/postgis/postgis/-/commits/stable-${VER}, alt=status, height="20", title='32/64 bit trixie, PG 15, GDAL 2.4.0, GEOS 3.7.1, PROJ 5.2.0')]] || \\
+|| [[Image(https://www.ict.inaf.it/gitlab/postgis/postgis/badges/master/pipeline.svg?ref=refs/heads/${VER}, link=https://www.ict.inaf.it/gitlab/postgis/postgis/-/commits/${VER}, alt=inaf/${VER})]] ||
 EOF
Summary of changes:
 utils/ci-trac-line.sh | 3 ++-
 1 file changed, 2 insertions(+), 1 deletion(-)
hooks/post-receive
