[SCM] PostGIS branch master updated. 3.6.0rc2-8-gb96e13bed
Tue Aug 26 01:34:09 PDT 2025
the project "PostGIS".
       via  b96e13bedc3fd6f569f22c85ee70cf1113c30337 (commit)
      from  164b24b6fd8f641ea235331547afe234f1fb0edf (commit)
revisions in full, below.
commit b96e13bedc3fd6f569f22c85ee70cf1113c30337
Author: Sandro Santilli <strk at kbt.io>
Date:   Tue Aug 26 10:33:37 2025 +0200
    Add script to test downgrade protection
diff --git a/utils/check_all_downgrades.sh b/utils/check_all_downgrades.sh
new file mode 100755
index 000000000..b5a766e2a
--- /dev/null
+++ b/utils/check_all_downgrades.sh
@@ -0,0 +1,351 @@
+#!/bin/sh
+EXIT_ON_FIRST_FAILURE=0
+EXTDIR=`pg_config --sharedir`/extension/
+CTBDIR=`pg_config --sharedir`/contrib/
+TMPDIR=/tmp/check_all_upgrades-$$-tmp
+PGVER=`pg_config --version | awk '{print $2}'`
+PGVER_MAJOR=$(echo "${PGVER}" | sed 's/\.[^\.]*//' | sed 's/\(alpha\|beta\|rc\).*//' )
+SKIP_LABEL_REGEXP=
+echo "INFO: PostgreSQL version: ${PGVER} [${PGVER_MAJOR}]"
+MAKE=$(which gmake make | head -1)
+BUILDDIR=$PWD # TODO: allow override ?
+cd $(dirname $0)/..
+SRCDIR=$PWD # TODO: allow override ?
+cd - > /dev/null
+# This is useful to run database queries
+export PGDATABASE=template1
+usage() {
+  echo "Usage: $0 [-s] <to_version>"
+  echo "Options:"
+  echo "\t-s  Stop on first failure"
+  echo "\t--skip <regexp>  Do not run tests with label matching given extended regexp"
+while test -n "$1"; do
+  if test "$1" = "-s"; then
+    EXIT_ON_FIRST_FAILURE=1
+  elif test "$1" = "--skip"; then
+    shift
+    SKIP_LABEL_REGEXP=$1
+  elif test -z "$to_version_param"; then
+    to_version_param="$1"
+  else
+    usage >&2
+    exit 1
+  fi
+  shift
+done
+if test -z "$to_version_param"; then
+  usage >&2
+  exit 1
+fi
+mkdir -p ${TMPDIR}
+cleanup()
+  echo "Cleaning up"
+  rm -rf ${TMPDIR}
+trap 'cleanup' EXIT
+# Return -1, 1 or 0 if the first version
+# is respectively smaller, greater or equal
+# to the second version
+semver_compare()
+  V1=`echo "$1" | tr '.' ' '`
+  V2=$2
+  # echo "V1: $V1" >&2
+  # echo "V2: $V2" >&2
+  for v1 in $V1; do
+    v2=`echo "$V2" | cut -d. -f1`
+    if [ -z "$v2" ]; then
+      echo 1; return;
+    fi
+    V2=`echo "$V2" | cut -d. -sf2-`
+    # echo "v: $v1 - $v2" >&2
+    if expr "$v1" '<' "$v2" > /dev/null; then
+      echo -1; return;
+    fi
+    if expr "$v1" '>' "$v2" > /dev/null; then
+      echo 1; return;
+    fi
+  done
+  if [ -n "$V2" ]; then
+    echo -1; return;
+  fi
+  echo 0; return;
+failed()
+  failures=$((failures+1))
+  if test $EXIT_ON_FIRST_FAILURE != 0; then
+    exit $failures
+  fi
+minimum_postgis_version_for_postgresql_major_version()
+  pgver=$1
+  supportfile=${TMPDIR}/minimum_supported_version_for_postgresql
+  if ! test -e ${supportfile}; then
+    # Source: https://trac.osgeo.org/postgis/wiki/UsersWikiPostgreSQLPostGIS
+    cat > ${supportfile} <<EOF
+9.6:2.3
+10:2.4
+11:2.5
+12:2.5
+13:3.0
+14:3.1
+15:3.2
+16:3.3
+17:3.3
+EOF
+  fi
+  # Drop patch-level number from PostgreSQL version
+  minsupported=`grep ^${pgver}: ${supportfile} | cut -d: -f2`
+  test -n "${minsupported}" || {
+    echo "Cannot determine minimum supported PostGIS version for PostgreSQL major version ${pgver}" >&2
+    exit 1
+  echo "${minsupported}"
+kept_label()
+  label=$1
+  if test -n "${SKIP_LABEL_REGEXP}"; then
+    if echo "${label}" | egrep -q "${SKIP_LABEL_REGEXP}"; then
+      echo "SKIP: $label (matches regexp '${SKIP_LABEL_REGEXP}')"
+      return 1;
+    fi
+  fi
+  return 0;
+is_downgrade()
+  label=$1
+  from=$2
+  to=$3
+  #echo "XXXX is_downgrade: upgrade_path=${upgrade_path}"
+  #echo "XXXX is_downgrade: from=${from}"
+  #echo "XXXX is_downgrade: to=${to}"
+  # only consider versions newer than ${to}
+  cmp=`semver_compare "${from}" "${to}"`
+  #echo "INFO: semver_compare ${from} ${to} returned $cmp"
+  if test $cmp -le 0; then
+    echo "SKIP: $label ($to is not newer than $from)"
+    return 1
+  fi
+  cmp=`semver_compare "${PGIS_MIN_VERSION}" "${from}"`
+  if test $cmp -gt 0; then
+    echo "SKIP: $label ($from older than ${PGIS_MIN_VERSION}, which is required to run in PostgreSQL ${PGVER})"
+    return 1
+  fi
+  return 0
+check_path()
+  RUNTESTFLAGS="-v --extension --upgrade-path=${UPGRADE_PATH} ${USERTESTFLAGS}" \
+  ${MAKE} -C ${REGDIR} check ${MAKE_ARGS} > ${TMPDIR}/log 2>&1
+  if test $? = 0; then
+    echo "FAIL: ${test_label} did not error out"
+    cat ${TMPDIR}/log
+    failed
+  else
+    ERR=$( grep 'Downgrade .* forbidden' ${TMPDIR}/log )
+    test -n "$ERR" && {
+      echo "PASS: ${test_label} gave $ERR"
+      echo "FAIL: ${test_label} gave some other error"
+      cat ${TMPDIR}/log
+      failed
+  fi
+report_missing_versions()
+  if test -n "${MISSING_EXT_UPGRADES}"; then
+    echo "INFO: missing downgrade scripts: ${MISSING_EXT_UPGRADES}"
+    echo "HINT: use 'postgis install-extension-upgrades' to install them"
+  fi
+  cleanup
+to_version=$to_version_param
+if expr $to_version : ':auto' >/dev/null; then
+  to_version=`psql -XAtc "select default_version from pg_available_extensions where name = 'postgis'"` || exit 1
+  MISSING_EXT_UPGRADES=
+  trap report_missing_versions EXIT
+elif expr $to_version : '.*!$' >/dev/null; then
+  to_version=$(echo "${to_version}" | sed 's/\!$//')
+fi
+PGIS_MIN_VERSION=`minimum_postgis_version_for_postgresql_major_version "${PGVER_MAJOR}"`
+echo "INFO: minimum PostGIS version supporting PostgreSQL ${PGVER_MAJOR}: ${PGIS_MIN_VERSION}"
+cd $EXTDIR
+failures=0
+INSTALLED_EXTENSIONS=postgis
+if test -f postgis_topology--${to_version}.sql; then
+  INSTALLED_EXTENSIONS="$INSTALLED_EXTENSIONS postgis_topology"
+fi
+if test -f postgis_raster--${to_version}.sql; then
+  INSTALLED_EXTENSIONS="$INSTALLED_EXTENSIONS postgis_raster"
+fi
+if test -f postgis_sfcgal--${to_version}.sql; then
+  INSTALLED_EXTENSIONS="$INSTALLED_EXTENSIONS postgis_sfcgal"
+fi
+echo "INFO: installed extensions: $INSTALLED_EXTENSIONS"
+USERTESTFLAGS=${RUNTESTFLAGS}
+# Make use of all public functions defined by source version
+# and use double-upgrade
+USERTESTFLAGS="\
+  ${USERTESTFLAGS} \
+  --before-upgrade-script ${SRCDIR}/regress/hooks/use-all-functions.sql \
+  --after-upgrade-script ${SRCDIR}/regress/hooks/hook-after-upgrade.sql \
+for EXT in ${INSTALLED_EXTENSIONS}; do #{
+  if test "${EXT}" = "postgis"; then
+    REGDIR=${BUILDDIR}/regress
+  elif test "${EXT}" = "postgis_topology"; then
+    REGDIR=${BUILDDIR}/topology/test
+  elif test "${EXT}" = "postgis_raster"; then
+    REGDIR=${BUILDDIR}/raster/test/regress
+  elif test "${EXT}" = "postgis_sfcgal"; then
+    REGDIR=${BUILDDIR}/sfcgal/regress
+  else
+    echo "SKIP: don't know where to find regress tests for extension ${EXT}"
+  fi
+  # Check extension->extension upgrades
+  files=`'ls' ${EXT}--* | grep -v -- '--.*--' | sed "s/^${EXT}--\(.*\)\.sql/\1/"`
+  for fname in $files; do
+    from_version="$fname"
+    if test "$from_version" = "unpackaged"; then
+      # We deal with unpackaged tests separately
+      continue;
+    fi
+    UPGRADE_PATH="${from_version}--${to_version_param}"
+    test_label="${EXT} extension downgrade ${UPGRADE_PATH}"
+    if expr $to_version_param : ':auto' >/dev/null; then
+      test_label="${test_label} ($to_version)"
+    fi
+    kept_label "${test_label}" || continue
+    is_downgrade "${test_label}" ${from_version} ${to_version} || continue
+    path=$( psql -XAtc "
+        SELECT path
+        FROM pg_catalog.pg_extension_update_paths('${EXT}')
+        WHERE source = '${from_version}'
+        AND target = '${to_version}'
+    " ) || exit 1
+    if test -z "${path}"; then
+      echo "SKIP: ${test_label} (no downgrade path from ${from_version} to ${to_version} known by postgresql)"
+      MISSING_EXT_UPGRADES="${from_version} ${MISSING_EXT_UPGRADES}"
+      continue
+    fi
+    echo "Testing ${test_label}"
+    check_path
+  done
+  if ! kept_label "unpackaged"; then
+    echo "SKIP: ${EXT} script-based upgrades (disabled by commandline)"
+    continue;
+  fi
+  # Check unpackaged->extension upgrades
+  for majmin in `'ls' -d ${CTBDIR}/postgis-* | sed 's/.*postgis-//'`; do
+    UPGRADE_PATH="unpackaged${majmin}--${to_version_param}"
+    fi
+    is_downgrade "${test_label}" ${majmin} ${to_version} || continue
+        SELECT path
+        WHERE source = 'unpackaged'
+    " ) || exit 1
+      echo "SKIP: ${test_label} (no downgrade path from unpackaged to ${to_version} known by postgresql)"
+      continue
+    fi
+    check_path
+  done
+  # Check unpackaged->unpackaged upgrades (if target version == current version)
+#  CURRENTVERSION=`grep '^POSTGIS_' ${SRCDIR}/Version.config | cut -d= -f2 | paste -sd '.'`
+  CURRENTVERSION=$(grep '^POSTGIS_' ${SRCDIR}/Version.config | cut -d= -f2 | tr '\n' '.' | sed 's/\.$//')
+  if test "${to_version}" != "${CURRENTVERSION}"; then #{
+    echo "SKIP: ${EXT} script-based upgrades (${to_version_param} [${to_version}] does not match built version ${CURRENTVERSION})"
+    continue
+  fi #}
+  do #{
+    UPGRADE_PATH="unpackaged${majmin}--:auto"
+    test_label="${EXT} script soft downgrade ${UPGRADE_PATH}"
+    fi
+    compatible_upgrade "${test_label}" ${majmin} ${to_version} || continue
+    if kept_label "${test_label}"; then #{
+      RUNTESTFLAGS="-v --upgrade-path=${UPGRADE_PATH} ${USERTESTFLAGS}" \
+      ${MAKE} -C ${REGDIR} check ${MAKE_ARGS} && {
+        echo "PASS: ${test_label}"
+        echo "FAIL: ${test_label}"
+        failed
+    fi #}
+    test_label="${EXT} script hard downgrade ${UPGRADE_PATH}"
+      RUNTESTFLAGS="-v --dumprestore --upgrade-path=${UPGRADE_PATH} ${USERTESTFLAGS}" \
+        failed
+    fi #}
+  done #}
+done #}
+exit $failures
Summary of changes:
 ...eck_all_upgrades.sh => check_all_downgrades.sh} | 66 ++++++++++++----------
 1 file changed, 37 insertions(+), 29 deletions(-)
 copy utils/{check_all_upgrades.sh => check_all_downgrades.sh} (85%)
hooks/post-receive
