[SCM] PostGIS branch master updated. 3.6.0rc2-9-gba3c19f9e
Tue Aug 26 02:59:45 PDT 2025
the project "PostGIS".
       via  ba3c19f9e35d16e5a20954a4e63d6e50bb145f0f (commit)
      from  b96e13bedc3fd6f569f22c85ee70cf1113c30337 (commit)
revisions in full, below.
commit ba3c19f9e35d16e5a20954a4e63d6e50bb145f0f
Author: Sandro Santilli <strk at kbt.io>
Date:   Tue Aug 26 11:55:00 2025 +0200
    Have downgrades be also tested with standard conforming strings off
    Confirms bug #5977
diff --git a/utils/check_all_downgrades.sh b/utils/check_all_downgrades.sh
index b5a766e2a..a437cace5 100755
--- a/utils/check_all_downgrades.sh
+++ b/utils/check_all_downgrades.sh
@@ -15,6 +15,8 @@ cd $(dirname $0)/..
 SRCDIR=$PWD # TODO: allow override ?
 cd - > /dev/null
+MAKE_ARGS="TESTS=${SRCDIR}/regress/core/regress.sql"
 # This is useful to run database queries
 export PGDATABASE=template1
@@ -161,41 +163,29 @@ is_downgrade()
   return 0
-check_path()
+check_downgrade()
   RUNTESTFLAGS="-v --extension --upgrade-path=${UPGRADE_PATH} ${USERTESTFLAGS}" \
   ${MAKE} -C ${REGDIR} check ${MAKE_ARGS} > ${TMPDIR}/log 2>&1
   if test $? = 0; then
-    echo "FAIL: ${test_label} did not error out"
-    cat ${TMPDIR}/log
+    echo "FAIL: ${test_label} did not error out:"
+    tail ${TMPDIR}/log
     failed
   else
     ERR=$( grep 'Downgrade .* forbidden' ${TMPDIR}/log )
     test -n "$ERR" && {
       echo "PASS: ${test_label} gave $ERR"
-      echo "FAIL: ${test_label} gave some other error"
-      cat ${TMPDIR}/log
+      echo "FAIL: ${test_label} gave some other error:"
       failed
   fi
-report_missing_versions()
-  if test -n "${MISSING_EXT_UPGRADES}"; then
-    echo "INFO: missing downgrade scripts: ${MISSING_EXT_UPGRADES}"
-    echo "HINT: use 'postgis install-extension-upgrades' to install them"
-  fi
-  cleanup
 to_version=$to_version_param
 if expr $to_version : ':auto' >/dev/null; then
   to_version=`psql -XAtc "select default_version from pg_available_extensions where name = 'postgis'"` || exit 1
-  MISSING_EXT_UPGRADES=
-  trap report_missing_versions EXIT
 elif expr $to_version : '.*!$' >/dev/null; then
   to_version=$(echo "${to_version}" | sed 's/\!$//')
 fi
@@ -223,14 +213,6 @@ echo "INFO: installed extensions: $INSTALLED_EXTENSIONS"
 USERTESTFLAGS=${RUNTESTFLAGS}
-# Make use of all public functions defined by source version
-# and use double-upgrade
-USERTESTFLAGS="\
-  ${USERTESTFLAGS} \
-  --before-upgrade-script ${SRCDIR}/regress/hooks/use-all-functions.sql \
-  --after-upgrade-script ${SRCDIR}/regress/hooks/hook-after-upgrade.sql \
 for EXT in ${INSTALLED_EXTENSIONS}; do #{
   if test "${EXT}" = "postgis"; then
     REGDIR=${BUILDDIR}/regress
@@ -244,7 +226,7 @@ for EXT in ${INSTALLED_EXTENSIONS}; do #{
     echo "SKIP: don't know where to find regress tests for extension ${EXT}"
   fi
-  # Check extension->extension upgrades
+  # Check extension->extension downgrades
   files=`'ls' ${EXT}--* | grep -v -- '--.*--' | sed "s/^${EXT}--\(.*\)\.sql/\1/"`
   for fname in $files; do
     from_version="$fname"
@@ -267,84 +249,20 @@ for EXT in ${INSTALLED_EXTENSIONS}; do #{
     " ) || exit 1
     if test -z "${path}"; then
       echo "SKIP: ${test_label} (no downgrade path from ${from_version} to ${to_version} known by postgresql)"
-      MISSING_EXT_UPGRADES="${from_version} ${MISSING_EXT_UPGRADES}"
       continue
     fi
     echo "Testing ${test_label}"
-    check_path
-  done
+    check_downgrade
-  if ! kept_label "unpackaged"; then
-    echo "SKIP: ${EXT} script-based upgrades (disabled by commandline)"
-    continue;
-  fi
-  # Check unpackaged->extension upgrades
-  for majmin in `'ls' -d ${CTBDIR}/postgis-* | sed 's/.*postgis-//'`; do
-    UPGRADE_PATH="unpackaged${majmin}--${to_version_param}"
-    test_label="${EXT} extension downgrade ${UPGRADE_PATH}"
-    if expr $to_version_param : ':auto' >/dev/null; then
-      test_label="${test_label} ($to_version)"
-    fi
-    kept_label "${test_label}" || continue
-    is_downgrade "${test_label}" ${majmin} ${to_version} || continue
-    path=$( psql -XAtc "
-        SELECT path
-        FROM pg_catalog.pg_extension_update_paths('${EXT}')
-        WHERE source = 'unpackaged'
-        AND target = '${to_version}'
-    " ) || exit 1
-    if test -z "${path}"; then
-      echo "SKIP: ${test_label} (no downgrade path from unpackaged to ${to_version} known by postgresql)"
-      continue
-    fi
+    test_label="${test_label} with standard-conforming-strings off"
-    check_path
+    USERTESTFLAGS="\
+      ${USERTESTFLAGS} \
+      --before-upgrade-script ${SRCDIR}/regress/hooks/standard-conforming-strings-off.sql \
+    " check_downgrade
   done
-  # Check unpackaged->unpackaged upgrades (if target version == current version)
-#  CURRENTVERSION=`grep '^POSTGIS_' ${SRCDIR}/Version.config | cut -d= -f2 | paste -sd '.'`
-  CURRENTVERSION=$(grep '^POSTGIS_' ${SRCDIR}/Version.config | cut -d= -f2 | tr '\n' '.' | sed 's/\.$//')
-  if test "${to_version}" != "${CURRENTVERSION}"; then #{
-    echo "SKIP: ${EXT} script-based upgrades (${to_version_param} [${to_version}] does not match built version ${CURRENTVERSION})"
-    continue
-  fi #}
-  do #{
-    UPGRADE_PATH="unpackaged${majmin}--:auto"
-    test_label="${EXT} script soft downgrade ${UPGRADE_PATH}"
-    fi
-    compatible_upgrade "${test_label}" ${majmin} ${to_version} || continue
-    if kept_label "${test_label}"; then #{
-      echo "Testing ${test_label}"
-      RUNTESTFLAGS="-v --upgrade-path=${UPGRADE_PATH} ${USERTESTFLAGS}" \
-      ${MAKE} -C ${REGDIR} check ${MAKE_ARGS} && {
-        echo "PASS: ${test_label}"
-        echo "FAIL: ${test_label}"
-        failed
-    fi #}
-    test_label="${EXT} script hard downgrade ${UPGRADE_PATH}"
-      RUNTESTFLAGS="-v --dumprestore --upgrade-path=${UPGRADE_PATH} ${USERTESTFLAGS}" \
-        failed
-    fi #}
-  done #}
+  # TODO: Check unpackaged->unpackaged downgrades (if target version == current version)
 done #}
Summary of changes:
 utils/check_all_downgrades.sh | 112 ++++++------------------------------------
 1 file changed, 15 insertions(+), 97 deletions(-)
hooks/post-receive
