[SCM] PostGIS branch master updated. 3.6.0rc2-12-g3ea4508d8
git at osgeo.org
git at osgeo.org
Tue Aug 26 03:51:19 PDT 2025
the project "PostGIS".
via 3ea4508d80bef85ddd242230eb12d5c3ec5f08df (commit)
from fb9111a1aa5ad3c24e022f0daeb9f34bc95aaa45 (commit)
revisions in full, below.
commit 3ea4508d80bef85ddd242230eb12d5c3ec5f08df
Author: Sandro Santilli <strk at kbt.io>
Date: Tue Aug 26 12:50:16 2025 +0200
Have check_all_downgrades.sh :auto check all versions as targets
It shows how 3.3.5 downgrades are unprotected, for example, while
3.3.6dev are...
diff --git a/utils/check_all_downgrades.sh b/utils/check_all_downgrades.sh
index d7f002227..45b9c48f4 100755
--- a/utils/check_all_downgrades.sh
+++ b/utils/check_all_downgrades.sh
@@ -7,7 +7,6 @@ TMPDIR=/tmp/check_all_upgrades-$$-tmp
PGVER=`pg_config --version | awk '{print $2}'`
PGVER_MAJOR=$(echo "${PGVER}" | sed 's/\.[^\.]*//' | sed 's/\(alpha\|beta\|rc\).*//' )
SKIP_LABEL_REGEXP=
-echo "INFO: PostgreSQL version: ${PGVER} [${PGVER_MAJOR}]"
MAKE=$(which gmake make | head -1)
BUILDDIR=$PWD # TODO: allow override ?
@@ -183,14 +182,26 @@ check_downgrade()
fi
to_version=$to_version_param
if expr $to_version : ':auto' >/dev/null; then
- to_version=`psql -XAtc "select default_version from pg_available_extensions where name = 'postgis'"` || exit 1
-elif expr $to_version : '.*!$' >/dev/null; then
- to_version=$(echo "${to_version}" | sed 's/\!$//')
+ ARGS=
+ if test -n "${SKIP_LABEL_REGEXP}"; then
+ ARGS="${ARGS} --skip ${SKIP_LABEL_REGEXP}"
+ fi
+ if test $EXIT_ON_FIRST_FAILURE != 0; then
+ ARGS="${ARGS} -s"
+ fi
+ for version in $(
+ psql -XAtc "select version from pg_available_extension_versions where name = 'postgis' and version ~ '^[0-9]'"
+ ); do
+ $0 ${ARGS} ${version} || failed
+ done
+ exit $failures
fi
+echo "INFO: PostgreSQL version: ${PGVER} [${PGVER_MAJOR}]"
PGIS_MIN_VERSION=`minimum_postgis_version_for_postgresql_major_version "${PGVER_MAJOR}"`
echo "INFO: minimum PostGIS version supporting PostgreSQL ${PGVER_MAJOR}: ${PGIS_MIN_VERSION}"
Summary of changes:
utils/check_all_downgrades.sh | 19 +++++++++++++++----
1 file changed, 15 insertions(+), 4 deletions(-)
hooks/post-receive
