[SCM] PostGIS branch master updated. 3.6.0rc2-13-g74a2b2fd3
git at osgeo.org
git at osgeo.org
Wed Aug 27 03:17:53 PDT 2025
the project "PostGIS".
via 74a2b2fd328dd5e436a63a21172e1add8d36954d (commit)
from 3ea4508d80bef85ddd242230eb12d5c3ec5f08df (commit)
revisions in full, below.
commit 74a2b2fd328dd5e436a63a21172e1add8d36954d
Author: Sandro Santilli <strk at kbt.io>
Date: Tue Aug 26 15:52:11 2025 +0200
Merge check_all_downgrades into check_all_upgrades
References #5977
diff --git a/utils/check_all_downgrades.sh b/utils/check_all_downgrades.sh
deleted file mode 100755
index 45b9c48f4..000000000
--- a/utils/check_all_downgrades.sh
+++ /dev/null
@@ -1,280 +0,0 @@
-#!/bin/sh
-EXIT_ON_FIRST_FAILURE=0
-EXTDIR=`pg_config --sharedir`/extension/
-CTBDIR=`pg_config --sharedir`/contrib/
-TMPDIR=/tmp/check_all_upgrades-$$-tmp
-PGVER=`pg_config --version | awk '{print $2}'`
-PGVER_MAJOR=$(echo "${PGVER}" | sed 's/\.[^\.]*//' | sed 's/\(alpha\|beta\|rc\).*//' )
-SKIP_LABEL_REGEXP=
-MAKE=$(which gmake make | head -1)
-BUILDDIR=$PWD # TODO: allow override ?
-cd $(dirname $0)/..
-SRCDIR=$PWD # TODO: allow override ?
-cd - > /dev/null
-MAKE_ARGS="TESTS=${SRCDIR}/regress/core/regress.sql"
-# This is useful to run database queries
-export PGDATABASE=template1
-usage() {
- echo "Usage: $0 [-s] <to_version>"
- echo "Options:"
- echo "\t-s Stop on first failure"
- echo "\t--skip <regexp> Do not run tests with label matching given extended regexp"
-while test -n "$1"; do
- if test "$1" = "-s"; then
- EXIT_ON_FIRST_FAILURE=1
- elif test "$1" = "--skip"; then
- shift
- SKIP_LABEL_REGEXP=$1
- elif test -z "$to_version_param"; then
- to_version_param="$1"
- else
- usage >&2
- exit 1
- fi
- shift
-done
-if test -z "$to_version_param"; then
- usage >&2
- exit 1
-fi
-mkdir -p ${TMPDIR}
-cleanup()
- echo "Cleaning up"
- rm -rf ${TMPDIR}
-trap 'cleanup' EXIT
-# Return -1, 1 or 0 if the first version
-# is respectively smaller, greater or equal
-# to the second version
-semver_compare()
- V1=`echo "$1" | tr '.' ' '`
- V2=$2
- # echo "V1: $V1" >&2
- # echo "V2: $V2" >&2
- for v1 in $V1; do
- v2=`echo "$V2" | cut -d. -f1`
- if [ -z "$v2" ]; then
- echo 1; return;
- fi
- V2=`echo "$V2" | cut -d. -sf2-`
- # echo "v: $v1 - $v2" >&2
- if expr "$v1" '<' "$v2" > /dev/null; then
- echo -1; return;
- fi
- if expr "$v1" '>' "$v2" > /dev/null; then
- echo 1; return;
- fi
- done
- if [ -n "$V2" ]; then
- echo -1; return;
- fi
- echo 0; return;
-failed()
- failures=$((failures+1))
- if test $EXIT_ON_FIRST_FAILURE != 0; then
- exit $failures
- fi
-minimum_postgis_version_for_postgresql_major_version()
- pgver=$1
- supportfile=${TMPDIR}/minimum_supported_version_for_postgresql
- if ! test -e ${supportfile}; then
- # Source: https://trac.osgeo.org/postgis/wiki/UsersWikiPostgreSQLPostGIS
- cat > ${supportfile} <<EOF
-9.6:2.3
-10:2.4
-11:2.5
-12:2.5
-13:3.0
-14:3.1
-15:3.2
-16:3.3
-17:3.3
-EOF
- fi
- # Drop patch-level number from PostgreSQL version
- minsupported=`grep ^${pgver}: ${supportfile} | cut -d: -f2`
- test -n "${minsupported}" || {
- echo "Cannot determine minimum supported PostGIS version for PostgreSQL major version ${pgver}" >&2
- exit 1
- echo "${minsupported}"
-kept_label()
- label=$1
- if test -n "${SKIP_LABEL_REGEXP}"; then
- if echo "${label}" | egrep -q "${SKIP_LABEL_REGEXP}"; then
- echo "SKIP: $label (matches regexp '${SKIP_LABEL_REGEXP}')"
- return 1;
- fi
- fi
- return 0;
-is_downgrade()
- label=$1
- from=$2
- to=$3
- #echo "XXXX is_downgrade: upgrade_path=${upgrade_path}"
- #echo "XXXX is_downgrade: from=${from}"
- #echo "XXXX is_downgrade: to=${to}"
- # only consider versions newer than ${to}
- cmp=`semver_compare "${from}" "${to}"`
- #echo "INFO: semver_compare ${from} ${to} returned $cmp"
- if test $cmp -le 0; then
- echo "SKIP: $label ($to is not newer than $from)"
- return 1
- fi
- cmp=`semver_compare "${PGIS_MIN_VERSION}" "${from}"`
- if test $cmp -gt 0; then
- echo "SKIP: $label ($from older than ${PGIS_MIN_VERSION}, which is required to run in PostgreSQL ${PGVER})"
- return 1
- fi
- return 0
-check_downgrade()
- RUNTESTFLAGS="-v --extension --upgrade-path=${UPGRADE_PATH} ${USERTESTFLAGS}" \
- ${MAKE} -C ${REGDIR} check ${MAKE_ARGS} > ${TMPDIR}/log 2>&1
- if test $? = 0; then
- echo "FAIL: ${test_label} did not error out:"
- tail ${TMPDIR}/log
- failed
- else
- ERR=$( grep 'ERROR:.*Downgrade .* forbidden' ${TMPDIR}/log )
- test -n "$ERR" && {
- echo "PASS: ${test_label} gave $ERR"
- echo "FAIL: ${test_label} gave some other error:"
- failed
- fi
-to_version=$to_version_param
-if expr $to_version : ':auto' >/dev/null; then
- ARGS=
- ARGS="${ARGS} --skip ${SKIP_LABEL_REGEXP}"
- fi
- ARGS="${ARGS} -s"
- fi
- for version in $(
- psql -XAtc "select version from pg_available_extension_versions where name = 'postgis' and version ~ '^[0-9]'"
- ); do
- $0 ${ARGS} ${version} || failed
- done
- exit $failures
-fi
-echo "INFO: PostgreSQL version: ${PGVER} [${PGVER_MAJOR}]"
-PGIS_MIN_VERSION=`minimum_postgis_version_for_postgresql_major_version "${PGVER_MAJOR}"`
-echo "INFO: minimum PostGIS version supporting PostgreSQL ${PGVER_MAJOR}: ${PGIS_MIN_VERSION}"
-cd $EXTDIR
-failures=0
-INSTALLED_EXTENSIONS=postgis
-if test -f postgis_topology--${to_version}.sql; then
- INSTALLED_EXTENSIONS="$INSTALLED_EXTENSIONS postgis_topology"
-fi
-if test -f postgis_raster--${to_version}.sql; then
- INSTALLED_EXTENSIONS="$INSTALLED_EXTENSIONS postgis_raster"
-fi
-if test -f postgis_sfcgal--${to_version}.sql; then
- INSTALLED_EXTENSIONS="$INSTALLED_EXTENSIONS postgis_sfcgal"
-fi
-echo "INFO: installed extensions: $INSTALLED_EXTENSIONS"
-USERTESTFLAGS=${RUNTESTFLAGS}
-for EXT in ${INSTALLED_EXTENSIONS}; do #{
- if test "${EXT}" = "postgis"; then
- REGDIR=${BUILDDIR}/regress
- elif test "${EXT}" = "postgis_topology"; then
- REGDIR=${BUILDDIR}/topology/test
- elif test "${EXT}" = "postgis_raster"; then
- REGDIR=${BUILDDIR}/raster/test/regress
- elif test "${EXT}" = "postgis_sfcgal"; then
- REGDIR=${BUILDDIR}/sfcgal/regress
- else
- echo "SKIP: don't know where to find regress tests for extension ${EXT}"
- fi
- # Check extension->extension downgrades
- files=`'ls' ${EXT}--* | grep -v -- '--.*--' | sed "s/^${EXT}--\(.*\)\.sql/\1/"`
- for fname in $files; do
- from_version="$fname"
- if test "$from_version" = "unpackaged"; then
- # We deal with unpackaged tests separately
- continue;
- fi
- UPGRADE_PATH="${from_version}--${to_version_param}"
- test_label="${EXT} extension downgrade ${UPGRADE_PATH}"
- if expr $to_version_param : ':auto' >/dev/null; then
- test_label="${test_label} ($to_version)"
- fi
- kept_label "${test_label}" || continue
- is_downgrade "${test_label}" ${from_version} ${to_version} || continue
- path=$( psql -XAtc "
- SELECT path
- FROM pg_catalog.pg_extension_update_paths('${EXT}')
- WHERE source = '${from_version}'
- AND target = '${to_version}'
- " ) || exit 1
- if test -z "${path}"; then
- echo "SKIP: ${test_label} (no downgrade path from ${from_version} to ${to_version} known by postgresql)"
- continue
- fi
- echo "Testing ${test_label}"
- check_downgrade
- test_label="${test_label} with standard-conforming-strings off"
- USERTESTFLAGS="\
- ${USERTESTFLAGS} \
- --before-upgrade-script ${SRCDIR}/regress/hooks/standard-conforming-strings-off.sql \
- " check_downgrade
- done
- # TODO: Check unpackaged->unpackaged downgrades (if target version == current version)
-done #}
-exit $failures
diff --git a/utils/check_all_upgrades.sh b/utils/check_all_upgrades.sh
index 0670ab65d..04471616d 100755
--- a/utils/check_all_upgrades.sh
+++ b/utils/check_all_upgrades.sh
@@ -135,6 +135,21 @@ kept_label()
return 0;
+# Usage: compatible_from <label> <from>
+compatible_from()
+ label=$1
+ from=$2
+ cmp=`semver_compare "${PGIS_MIN_VERSION}" "${from}"`
+ if test $cmp -gt 0; then
+ echo "SKIP: $label ($from older than ${PGIS_MIN_VERSION}, which is required to run in PostgreSQL ${PGVER})"
+ return 1
+ fi
+ return 0
+# Usage: compatible_upgrade <label> <from> <to>
compatible_upgrade()
label=$1
@@ -152,13 +167,32 @@ compatible_upgrade()
return 1
fi
+ if compatible_from $label $from; then
+ return 0
+ else
return 1
fi
- return 0
+check_downgrade()
+ RUNTESTFLAGS="-v --extension --upgrade-path=${UPGRADE_PATH} ${USERTESTFLAGS}" \
+ ${MAKE} -C ${REGDIR} check "TESTS=${SRCDIR}/regress/core/regress.sql" ${MAKE_ARGS} > ${TMPDIR}/log 2>&1
+ if test $? = 0; then
+ echo "FAIL: ${test_label} did not error out:"
+ tail ${TMPDIR}/log
+ failed
+ else
+ ERR=$( grep 'ERROR:.*Downgrade .* forbidden' ${TMPDIR}/log )
+ test -n "$ERR" && {
+ echo "PASS: ${test_label} gave $ERR"
+ echo "FAIL: ${test_label} gave some other error:"
+ failed
+ fi
report_missing_versions()
@@ -233,12 +267,26 @@ for EXT in ${INSTALLED_EXTENSIONS}; do #{
continue;
fi
- test_label="${EXT} extension upgrade ${UPGRADE_PATH}"
+ cmp=`semver_compare "${from_version}" "${to_version}"`
+ #echo "INFO: semver_compare ${from} ${to} returned $cmp"
+ if test $cmp -eq 0; then
+ echo "SKIP: ${from_version} -> ${to_version} (we won't test same-version upgrade/downgrade here)"
+ continue;
+ fi
+ if test $cmp -lt 0; then
+ test_label="${EXT} extension upgrade ${UPGRADE_PATH}"
+ else
+ test_label="${EXT} extension downgrade ${UPGRADE_PATH}"
+ fi
fi
- compatible_upgrade "${test_label}" ${from_version} ${to_version} || continue
SELECT path
@@ -250,14 +298,30 @@ for EXT in ${INSTALLED_EXTENSIONS}; do #{
MISSING_EXT_UPGRADES="${from_version} ${MISSING_EXT_UPGRADES}"
continue
fi
+ compatible_from "${test_label}" ${from_version} || continue
- ${MAKE} -C ${REGDIR} check ${MAKE_ARGS} && {
- echo "PASS: ${test_label}"
- echo "FAIL: ${test_label}"
- failed
+ if expr "${test_label}" : '^.*upgrade' > /dev/null; then
+ ${MAKE} -C ${REGDIR} check ${MAKE_ARGS} && {
+ echo "PASS: ${test_label}"
+ echo "FAIL: ${test_label}"
+ failed
+ else
+ check_downgrade
+ test_label="${test_label} with standard-conforming-strings off"
+ echo "Testing ${test_label}"
+ USERTESTFLAGS="\
+ ${USERTESTFLAGS} \
+ --before-upgrade-script ${SRCDIR}/regress/hooks/standard-conforming-strings-off.sql \
+ " check_downgrade
+ fi
done
if ! kept_label "unpackaged"; then
Summary of changes:
utils/check_all_downgrades.sh | 280 ------------------------------------------
utils/check_all_upgrades.sh | 90 ++++++++++++--
2 files changed, 77 insertions(+), 293 deletions(-)
delete mode 100755 utils/check_all_downgrades.sh
hooks/post-receive
