[SCM] PostGIS branch master updated. 3.6.0rc2-250-gb0dcc8510
Thu Dec 4 12:14:47 PST 2025
the project "PostGIS".
       via  b0dcc8510fd7930752db4e65a9e7f368b63a139c (commit)
      from  e1451a6693ed13774962d168d921be65fb6702f1 (commit)
revisions in full, below.
commit b0dcc8510fd7930752db4e65a9e7f368b63a139c
Author: Darafei Praliaskouski <me at komzpa.net>
Date:   Fri Dec 5 00:14:34 2025 +0400
    [topology] Include representative locations in topology build errors
    Closes #5889
diff --git a/NEWS b/NEWS
index a32a41abc..f4c61cbc6 100644
--- a/NEWS
+++ b/NEWS
@@ -23,7 +23,7 @@ xxxx/xx/xx
  - #4332, Clarify the scope of several Function Reference categories (Darafei Praliaskouski)
  - #4222, [raster] ST_DumpAsPolygons honours PostgreSQL interrupts (Darafei Praliaskouski)
  - #5109, Document the meaning of topology.next_left_edge and topology.next_right_edge links (Darafei Praliaskouski)
+ - #5889, [topology] Include representative locations in topology build errors (Darafei Praliaskouski)
 * Bug Fixes *
diff --git a/liblwgeom/topo/lwgeom_topo.c b/liblwgeom/topo/lwgeom_topo.c
index 3e7cfdc1e..61edd3ef5 100644
--- a/liblwgeom/topo/lwgeom_topo.c
+++ b/liblwgeom/topo/lwgeom_topo.c
@@ -19,11 +19,10 @@
  * Copyright (C) 2015-2024 Sandro Santilli <strk at kbt.io>
+ * Copyright (C) 2025 Darafei Praliaskouski <me at komzpa.net>
 #include "../postgis_config.h"
 //#define POSTGIS_DEBUG_LEVEL 1
@@ -38,6 +37,67 @@
 #include <inttypes.h>
+ * Report a human readable location along with topology errors so callers can
+ * narrow down robustness issues such as #5886/#5889 without further tracing.
+ * Using a point-on-surface keeps the message compact while remaining
+ * representative for any dimensionality of the offending intersection.
+static bool
+_lwt_describe_intersection_point(const GEOSGeometry *g1, const GEOSGeometry *g2, char *buf, size_t bufsize)
+	unsigned int n = 0;
+	POINT2D pt;
+	GEOSGeometry *isect;
+	GEOSGeometry *surface_pt;
+	const GEOSCoordSequence *seq;
+	isect = GEOSIntersection(g1, g2);
+	if (!isect)
+		return false;
+	surface_pt = GEOSPointOnSurface(isect);
+	GEOSGeom_destroy(isect);
+	if (!surface_pt)
+		return false;
+	seq = GEOSGeom_getCoordSeq(surface_pt);
+	if (!seq)
+		GEOSGeom_destroy(surface_pt);
+		return false;
+	if (!GEOSCoordSeq_getSize(seq, &n) || !n)
+		return false;
+	if (!GEOSCoordSeq_getX(seq, 0, &pt.x) || !GEOSCoordSeq_getY(seq, 0, &pt.y))
+		return false;
+	snprintf(buf, bufsize, " at POINT(%.15g %.15g)", pt.x, pt.y);
+	return true;
+static bool
+_lwt_describe_point(const LWPOINT *pt, char *buf, size_t bufsize)
+	POINT2D p;
+	if (!pt || !pt->point || !pt->point->npoints)
+		return false;
+	getPoint2d_p(pt->point, 0, &p);
+	snprintf(buf, bufsize, " at POINT(%.15g %.15g)", p.x, p.y);
+	return true;
  * Backend iface
@@ -527,6 +587,8 @@ _lwt_AddIsoNode( LWT_TOPOLOGY* topo, LWT_ELEMID face,
                 LWPOINT* pt, int skipISOChecks, int checkFace )
   LWT_ELEMID foundInFace = -1;
+  char locinfo[128] = "";
+  const char *locsuffix = _lwt_describe_point(pt, locinfo, sizeof(locinfo)) ? locinfo : "";
   if ( lwpoint_is_empty(pt) )
@@ -539,13 +601,13 @@ _lwt_AddIsoNode( LWT_TOPOLOGY* topo, LWT_ELEMID face,
     if ( lwt_be_ExistsCoincidentNode(topo, pt) ) /*x*/
-      lwerror("SQL/MM Spatial exception - coincident node");
-      return -1;
+	    lwerror("SQL/MM Spatial exception - coincident node%s", locsuffix);
+	    return -1;
     if ( lwt_be_ExistsEdgeIntersectingPoint(topo, pt) ) /*x*/
-      lwerror("SQL/MM Spatial exception - edge crosses node.");
-      return -1;
+	    lwerror("SQL/MM Spatial exception - edge crosses node.%s", locsuffix);
+	    return -1;
@@ -634,21 +696,33 @@ _lwt_CheckEdgeCrossing( LWT_TOPOLOGY* topo,
   for ( i=0; i<num_nodes; ++i )
-    const POINT2D *pt;
-    LWT_ISO_NODE* node = &(nodes[i]);
-    if ( node->node_id == start_node ) continue;
-    if ( node->node_id == end_node ) continue;
-    /* check if the edge contains this node (not on boundary) */
-    /* ST_RelateMatch(rec.relate, 'T********') */
-    pt = getPoint2d_cp(node->geom->point, 0);
-    int contains = ptarray_contains_point_partial(geom->points, pt, LW_FALSE, NULL) == LW_BOUNDARY;
-    if ( contains )
-      GEOSGeom_destroy(edgegg);
-      _lwt_release_nodes(nodes, num_nodes);
-      lwerror("SQL/MM Spatial exception - geometry crosses a node");
-      return -1;
+	  POINT2D p;
+	  LWT_ISO_NODE *node = &(nodes[i]);
+	  if (node->node_id == start_node)
+		  continue;
+	  if (node->node_id == end_node)
+		  continue;
+	  /* check if the edge contains this node (not on boundary) */
+	  /* ST_RelateMatch(rec.relate, 'T********') */
+	  if (!node->geom || !node->geom->point || !node->geom->point->npoints)
+		  GEOSGeom_destroy(edgegg);
+		  _lwt_release_nodes(nodes, num_nodes);
+		  lwerror("SQL/MM Spatial exception - geometry crosses a node");
+		  return -1;
+	  getPoint2d_p(node->geom->point, 0, &p);
+	  int contains = ptarray_contains_point_partial(geom->points, &p, LW_FALSE, NULL) == LW_BOUNDARY;
+	  if (contains)
+		  snprintf(locinfo, sizeof(locinfo), " at POINT(%.15g %.15g)", p.x, p.y);
+		  lwerror("SQL/MM Spatial exception - geometry crosses a node%s", locinfo);
+		  return -1;
   if ( nodes ) _lwt_release_nodes(nodes, num_nodes);
                /* may be NULL if num_nodes == 0 */
@@ -691,12 +765,12 @@ _lwt_CheckEdgeCrossing( LWT_TOPOLOGY* topo,
     /* check if the edge has a non-boundary-boundary intersection with our edge */
     relate = GEOSRelateBoundaryNodeRule(eegg, edgegg, 2);
-    GEOSGeom_destroy(eegg);
     if ( ! relate ) {
-      _lwt_release_edges(edges, num_edges);
-      lwerror("GEOSRelateBoundaryNodeRule error: %s", lwgeom_geos_errmsg);
-      return -1;
+	    GEOSGeom_destroy(eegg);
+	    _lwt_release_edges(edges, num_edges);
+	    lwerror("GEOSRelateBoundaryNodeRule error: %s", lwgeom_geos_errmsg);
+	    return -1;
     LWDEBUGF(2, "Edge %" LWTFMT_ELEMID " relate pattern is %s", edge_id, relate);
@@ -705,87 +779,130 @@ _lwt_CheckEdgeCrossing( LWT_TOPOLOGY* topo,
     if ( match ) {
       /* error or no interior intersection */
       GEOSFree(relate);
       if ( match == 2 ) {
         lwerror("GEOSRelatePatternMatch error: %s", lwgeom_geos_errmsg);
         return -1;
-      else continue; /* no interior intersection */
+      continue; /* no interior intersection */
     match = GEOSRelatePatternMatch(relate, "1FFF*FFF2");
     if ( match ) {
-      GEOSFree(relate);
-      if ( match == 2 ) {
-        lwerror("GEOSRelatePatternMatch error: %s", lwgeom_geos_errmsg);
-      } else {
-        lwerror("SQL/MM Spatial exception - coincident edge %" LWTFMT_ELEMID,
-                edge_id);
+	    const char *locsuffix = match == 2        ? ""
+				    : _lwt_describe_intersection_point(edgegg, eegg, locinfo, sizeof(locinfo)) ? locinfo
+	    GEOSFree(relate);
+	    if (match == 2)
+		    lwerror("GEOSRelatePatternMatch error: %s", lwgeom_geos_errmsg);
+	    else
+		    lwerror("SQL/MM Spatial exception - coincident edge %" LWTFMT_ELEMID "%s", edge_id, locsuffix);
       return -1;
     match = GEOSRelatePatternMatch(relate, "1********");
     if ( match ) {
-      GEOSFree(relate);
-      } else {
-        lwerror("Spatial exception - geometry intersects edge %"
-                LWTFMT_ELEMID, edge_id);
+	    GEOSFree(relate);
+	    if (match == 2)
+	    else
+		    lwerror("Spatial exception - geometry intersects edge %" LWTFMT_ELEMID "%s", edge_id, locsuffix);
       return -1;
     match = GEOSRelatePatternMatch(relate, "T********");
     if ( match ) {
-      GEOSFree(relate);
-      } else {
-        lwerror("SQL/MM Spatial exception - geometry crosses edge %"
+	    GEOSFree(relate);
+	    if (match == 2)
+	    else
+		    lwerror(
+			"SQL/MM Spatial exception - geometry crosses edge %" LWTFMT_ELEMID "%s", edge_id, locsuffix);
       return -1;
     match = GEOSRelatePatternMatch(relate, "*T*******");
     if ( match ) {
-      GEOSFree(relate);
-      } else {
-        lwerror("Spatial exception - geometry boundary touches interior of edge %"
+	    GEOSFree(relate);
+	    if (match == 2)
+	    else
+		    lwerror("Spatial exception - geometry boundary touches interior of edge %" LWTFMT_ELEMID "%s",
+			    edge_id,
+			    locsuffix);
       return -1;
     match = GEOSRelatePatternMatch(relate, "***T*****");
     if ( match ) {
-      GEOSFree(relate);
-      } else {
-        lwerror("Spatial exception - boundary of edge %" LWTFMT_ELEMID" touches interior of geometry", edge_id);
+	    GEOSFree(relate);
+	    if (match == 2)
+	    else
+		    lwerror("Spatial exception - boundary of edge %" LWTFMT_ELEMID " touches interior of geometry%s",
+			    edge_id,
+			    locsuffix);
       return -1;
     LWDEBUGF(2, "Edge %" LWTFMT_ELEMID " analysis completed, it does no harm", edge_id);
     GEOSFree(relate);
   LWDEBUGF(1, "No edge crossing detected among the %llu candidate edges", num_edges);
   if ( edges ) _lwt_release_edges(edges, num_edges);
diff --git a/topology/test/regress/sqlmm_expected b/topology/test/regress/sqlmm_expected
index e62599aac..8cf854a19 100644
--- a/topology/test/regress/sqlmm_expected
+++ b/topology/test/regress/sqlmm_expected
@@ -9,15 +9,15 @@ ERROR:  SQL/MM Spatial exception - null argument
 4
 5
 6
-ERROR:  SQL/MM Spatial exception - coincident node
+ERROR:  SQL/MM Spatial exception - coincident node at POINT(0 0)
+ERROR:  SQL/MM Spatial exception - coincident node at POINT(10 0)
 7
 8
 ERROR:  SQL/MM Spatial exception - not within face
 ERROR:  SQL/MM Spatial exception - invalid point
 -- ST_AddIsoEdge ------------------------
@@ -28,14 +28,14 @@ ERROR:  SQL/MM Spatial exception - curve not simple
 ERROR:  SQL/MM Spatial exception - non-existent node
 ERROR:  SQL/MM Spatial exception - end node not geometry end point.
 ERROR:  SQL/MM Spatial exception - start node not geometry start point.
-ERROR:  SQL/MM Spatial exception - geometry crosses a node
+ERROR:  SQL/MM Spatial exception - geometry crosses a node at POINT(5 0)
 1
 2
 ERROR:  SQL/MM Spatial exception - not isolated node
 -- ST_AddIsoNode(2) ------------------------
-ERROR:  SQL/MM Spatial exception - edge crosses node.
+ERROR:  SQL/MM Spatial exception - edge crosses node. at POINT(5 9.5)
 -- ST_RemoveIsoEdge ---------------------
 #3351.1|4|
 #3351.1|5|
diff --git a/topology/test/regress/st_addedgemodface_expected b/topology/test/regress/st_addedgemodface_expected
index 26e39df63..d55e6ce19 100644
--- a/topology/test/regress/st_addedgemodface_expected
+++ b/topology/test/regress/st_addedgemodface_expected
@@ -1,16 +1,16 @@
+ERROR:  SQL/MM Spatial exception - geometry crosses a node at POINT(41 40)
 ERROR:  Invalid edge (no two distinct vertices exist)
-ERROR:  SQL/MM Spatial exception - coincident edge 8
-ERROR:  SQL/MM Spatial exception - geometry crosses edge 5
-ERROR:  SQL/MM Spatial exception - geometry crosses edge 4
-ERROR:  Spatial exception - geometry intersects edge 4
+ERROR:  SQL/MM Spatial exception - coincident edge 8 at POINT(35 22)
+ERROR:  SQL/MM Spatial exception - geometry crosses edge 5 at POINT(48.0714285714286 41.9285714285714)
+ERROR:  SQL/MM Spatial exception - geometry crosses edge 4 at POINT(45 32)
+ERROR:  Spatial exception - geometry intersects edge 4 at POINT(36 38)
 L1
 L2
 T1|E7|8|-19|0|10
diff --git a/topology/test/regress/st_addedgenewfaces_expected b/topology/test/regress/st_addedgenewfaces_expected
index 9f14187a6..bb2a7a572 100644
--- a/topology/test/regress/st_addedgenewfaces_expected
+++ b/topology/test/regress/st_addedgenewfaces_expected
@@ -1,16 +1,16 @@
 L1
 L2
 T1|E7|8|-19|0|11
diff --git a/topology/test/regress/st_addisoedge_expected b/topology/test/regress/st_addisoedge_expected
index f1ae4f023..46d9f9916 100644
--- a/topology/test/regress/st_addisoedge_expected
+++ b/topology/test/regress/st_addisoedge_expected
@@ -15,7 +15,7 @@ ERROR:  SQL/MM Spatial exception - curve not simple
 E1
 E2
 N1|
@@ -29,5 +29,5 @@ ERROR:  SQL/MM Spatial exception - not isolated node
 ERROR:  Closed edges would not be isolated, try ST_AddEdgeNewFaces
-ERROR:  SQL/MM Spatial exception - geometry crosses edge 2
+ERROR:  SQL/MM Spatial exception - geometry crosses edge 2 at POINT(10 3.33333333333333)
 Topology 'tt' dropped
diff --git a/topology/test/regress/st_addisonode_expected b/topology/test/regress/st_addisonode_expected
index 31f74e5a6..6a7093778 100644
--- a/topology/test/regress/st_addisonode_expected
+++ b/topology/test/regress/st_addisonode_expected
@@ -7,10 +7,10 @@ ERROR:  SQL/MM Spatial exception - invalid topology name
+ERROR:  SQL/MM Spatial exception - coincident node at POINT(21 22)
+ERROR:  SQL/MM Spatial exception - edge crosses node. at POINT(28 14)
 T1|23|5
 T2|24|0
 T3|25|9
diff --git a/topology/test/regress/st_changeedgegeom_expected b/topology/test/regress/st_changeedgegeom_expected
index bfb094b73..c4dd61a06 100644
--- a/topology/test/regress/st_changeedgegeom_expected
+++ b/topology/test/regress/st_changeedgegeom_expected
@@ -1,11 +1,11 @@
 T1|Edge 25 changed
+ERROR:  SQL/MM Spatial exception - geometry crosses a node at POINT(20 37)
 ERROR:  SQL/MM Spatial exception - non-existent edge 666
-ERROR:  SQL/MM Spatial exception - geometry crosses edge 1
+ERROR:  SQL/MM Spatial exception - geometry crosses edge 1 at POINT(11.8 38)
 T2|Edge 5 changed
 T3|Edge 5 changed
 T4|Edge 26 changed
diff --git a/topology/test/regress/topology_error_location.sql b/topology/test/regress/topology_error_location.sql
new file mode 100644
index 000000000..37c199e4e
--- /dev/null
+++ b/topology/test/regress/topology_error_location.sql
@@ -0,0 +1,38 @@
+-- Ensure prior runs do not leak topologies or noisy notices
+SET client_min_messages TO NOTICE;
+DO $$
+BEGIN
+  PERFORM topology.DropTopology('err_loc');
+EXCEPTION WHEN OTHERS THEN
+  -- Topology may not exist yet; ignore.
+END;
+$$ LANGUAGE plpgsql;
+SELECT 'created', topology.CreateTopology('err_loc', 0, 0) > 0;
+SELECT 'n1', topology.ST_AddIsoNode('err_loc', NULL::integer, ST_GeomFromText('POINT(0 0)', 0));
+SELECT 'n2', topology.ST_AddIsoNode('err_loc', NULL::integer, ST_GeomFromText('POINT(10 0)', 0));
+SELECT 'n3', topology.ST_AddIsoNode('err_loc', NULL::integer, ST_GeomFromText('POINT(5 -5)', 0));
+SELECT 'n4', topology.ST_AddIsoNode('err_loc', NULL::integer, ST_GeomFromText('POINT(5 5)', 0));
+DO $$
+BEGIN
+  PERFORM topology.ST_AddIsoNode('err_loc', NULL::integer, ST_GeomFromText('POINT(0 0)', 0));
+  RAISE NOTICE 'duplicate node: %', regexp_replace(SQLERRM, E'^.*: ', '');
+END;
+SELECT 'base_edge', topology.ST_AddEdgeModFace('err_loc', 1, 2, ST_GeomFromText('LINESTRING(0 0, 10 0)', 0));
+DO $$
+BEGIN
+  PERFORM topology.ST_AddEdgeModFace('err_loc', 3, 4, ST_GeomFromText('LINESTRING(5 -5, 5 5)', 0));
+  RAISE NOTICE 'crossing edge: %', regexp_replace(SQLERRM, E'^.*: ', '');
+END;
+SET client_min_messages TO WARNING;
+SELECT 'dropped', topology.DropTopology('err_loc') IS NOT NULL;
+RESET client_min_messages;
diff --git a/topology/test/regress/topology_error_location_expected b/topology/test/regress/topology_error_location_expected
index 000000000..85bd4abe3
--- /dev/null
+++ b/topology/test/regress/topology_error_location_expected
@@ -0,0 +1,9 @@
+created|t
+n1|1
+n2|2
+n3|3
+n4|4
+NOTICE:  duplicate node: SQL/MM Spatial exception - coincident node at POINT(0 0)
+base_edge|1
+NOTICE:  crossing edge: SQL/MM Spatial exception - geometry crosses edge 1 at POINT(5 0)
+dropped|t
diff --git a/topology/test/tests.mk b/topology/test/tests.mk
index 0b0ab3ff9..ba1d2e204 100644
--- a/topology/test/tests.mk
+++ b/topology/test/tests.mk
@@ -88,6 +88,7 @@ TESTS += \
 	$(top_srcdir)/topology/test/regress/topogeometry_srid.sql \
 	$(top_srcdir)/topology/test/regress/topogeometry_type.sql \
 	$(top_srcdir)/topology/test/regress/topojson.sql \
+	$(top_srcdir)/topology/test/regress/topology_error_location.sql \
 	$(top_srcdir)/topology/test/regress/topologysummary.sql \
 	$(top_srcdir)/topology/test/regress/totaltopologysize.sql \
 	$(top_srcdir)/topology/test/regress/totopogeom.sql \
Summary of changes:
 NEWS                                               |   2 +-
 liblwgeom/topo/lwgeom_topo.c                       | 259 +++++++++++++++------
 topology/test/regress/sqlmm_expected               |  14 +-
 topology/test/regress/st_addedgemodface_expected   |  10 +-
 topology/test/regress/st_addedgenewfaces_expected  |  10 +-
 topology/test/regress/st_addisoedge_expected       |   4 +-
 topology/test/regress/st_addisonode_expected       |   8 +-
 topology/test/regress/st_changeedgegeom_expected   |   4 +-
 topology/test/regress/topology_error_location.sql  |  38 +++
 .../test/regress/topology_error_location_expected  |   9 +
 topology/test/tests.mk                             |   1 +
 11 files changed, 262 insertions(+), 97 deletions(-)
 create mode 100644 topology/test/regress/topology_error_location.sql
 create mode 100644 topology/test/regress/topology_error_location_expected
hooks/post-receive
