[SCM] PostGIS branch master updated. 3.6.0rc2-253-g9389d7fca
Mon Dec 8 20:47:54 PST 2025
the project "PostGIS".
       via  9389d7fcad80c4187d29e7f6de85e7fac4a1fe22 (commit)
      from  944e4b714db5a98e39713039ef520d3a45250ce7 (commit)
revisions in full, below.
commit 9389d7fcad80c4187d29e7f6de85e7fac4a1fe22
Author: Teramoto Ikuhiro <teramoto.ikuhiro576 at naro.go.jp>
Date:   Tue Dec 9 02:57:29 2025 +0000
    Translated PostGIS Manual using Weblate (Japanese)
    Currently translated at 99.8% (5886 of 5893 strings)
    Translation: postgis/PostGIS Manual
    Translate-URL: https://weblate.osgeo.org/projects/postgis/postgis-manual/ja/
diff --git a/doc/po/ja/postgis-manual.po b/doc/po/ja/postgis-manual.po
index 47360239f..67431cd71 100644
--- a/doc/po/ja/postgis-manual.po
+++ b/doc/po/ja/postgis-manual.po
@@ -10,7 +10,7 @@ msgstr ""
 "Project-Id-Version: postgis 3.5\n"
 "Report-Msgid-Bugs-To: https://bugs.kde.org\n"
 "POT-Creation-Date: 2025-11-13 16:23+0000\n"
-"PO-Revision-Date: 2025-12-08 06:47+0000\n"
+"PO-Revision-Date: 2025-12-09 04:47+0000\n"
 "Last-Translator: Teramoto Ikuhiro <teramoto.ikuhiro576 at naro.go.jp>\n"
 "Language-Team: Japanese <https://weblate.osgeo.org/projects/postgis/"
 "postgis-manual/ja/>\n"
@@ -3978,7 +3978,7 @@ msgstr ""
 "ギュアオプション --without-topology を指定することで、無効にできます。"
 #. Tag: title
-#, fuzzy, no-c-format
+#, no-c-format
 msgid "Topology Primitive Tables"
 msgstr "トポロジープリミティブテーブル"
@@ -5619,15 +5619,15 @@ msgstr ""
 #. Tag: para
+#, no-c-format
 msgid ""
 "The number of newly created edges (either covering space previously "
 "uncovered or resulting from split of existing edges) may be limited by the "
 "<varname>max_edges</varname> parameter."
 msgstr ""
-"新規生成されたエッジの数 (覆っていなかった空間を覆うエッジか、既存エッジの分"
-"割から得られた結果)は <varname>max_edges</varname>パラメータで制限されること"
-"があります。"
+"新規生成されるエッジ "
+"(及んでいなかった範囲の空間に及ぶか、既存エッジの分割から得られた結果)の数は "
+"<varname>max_edges</varname>パラメータで制限されます。"
 #. Tag: para
 #, no-c-format
Summary of changes:
 doc/po/ja/postgis-manual.po | 12 ++++++------
 1 file changed, 6 insertions(+), 6 deletions(-)
hooks/post-receive
