[SCM] PostGIS branch master updated. 3.6.0rc2-254-g5c0716b54
Mon Dec 8 22:47:50 PST 2025
the project "PostGIS".
       via  5c0716b54e25714bfbb2d46125d48fb9f1ac7e99 (commit)
      from  9389d7fcad80c4187d29e7f6de85e7fac4a1fe22 (commit)
revisions in full, below.
commit 5c0716b54e25714bfbb2d46125d48fb9f1ac7e99
Author: Teramoto Ikuhiro <teramoto.ikuhiro576 at naro.go.jp>
Date:   Tue Dec 9 05:19:00 2025 +0000
    Translated PostGIS Manual using Weblate (Japanese)
    Currently translated at 99.8% (5886 of 5893 strings)
    Translation: postgis/PostGIS Manual
    Translate-URL: https://weblate.osgeo.org/projects/postgis/postgis-manual/ja/
diff --git a/doc/po/ja/postgis-manual.po b/doc/po/ja/postgis-manual.po
index 67431cd71..06435efcf 100644
--- a/doc/po/ja/postgis-manual.po
+++ b/doc/po/ja/postgis-manual.po
@@ -10,7 +10,7 @@ msgstr ""
 "Project-Id-Version: postgis 3.5\n"
 "Report-Msgid-Bugs-To: https://bugs.kde.org\n"
 "POT-Creation-Date: 2025-11-13 16:23+0000\n"
-"PO-Revision-Date: 2025-12-09 04:47+0000\n"
+"PO-Revision-Date: 2025-12-09 06:47+0000\n"
 "Last-Translator: Teramoto Ikuhiro <teramoto.ikuhiro576 at naro.go.jp>\n"
 "Language-Team: Japanese <https://weblate.osgeo.org/projects/postgis/"
 "postgis-manual/ja/>\n"
@@ -16428,33 +16428,34 @@ msgid ""
 "<parameter>overlapMergeStrategy</parameter> specifies how overlaps are "
 "merged into a parent polygon:"
 msgstr ""
-"<parameter>overlapMergeStrategy</parameter>でどれぐらいのオーバーラップまで親"
-"ポリゴンとしてマージするかが指定されます:"
+"<parameter>overlapMergeStrategy</parameter>で、どれぐらいオーバーラップしてい"
+"るポリゴンを親ポリゴンにマージするかが指定されます:"
 #. Tag: para
 #, fuzzy, no-c-format
 msgid ""
 "<code>MERGE_LONGEST_BORDER</code> - merges into polygon with longest common "
 "border"
-msgstr "<code>MERGE_LONGEST_BORDER</code> - 最長共有境界でマージします"
+msgstr "<code>MERGE_LONGEST_BORDER</code> - 共有境界が最長のポリゴンにマージします"
 #. Tag: para
 msgid "<code>MERGE_MAX_AREA</code> - merges into polygon with maximum area"
-msgstr "<code>MERGE_MAX_AREA</code> - 最大面積でマージします"
+msgstr "<code>MERGE_MAX_AREA</code> - 最大面積のポリゴンにマージします"
 #. Tag: para
 msgid "<code>MERGE_MIN_AREA</code> - merges into polygon with minimum area"
-msgstr "<code>MERGE_MIN_AREA</code> - 最小面積でマージします"
+msgstr "<code>MERGE_MIN_AREA</code> - 最小面積のポリゴンにマージします"
 #. Tag: para
 msgid ""
 "<code>MERGE_MIN_INDEX</code> - merges into polygon with smallest input index "
 "(defined by order of input polygons)"
-msgstr "<code>MERGE_MIN_INDEX</code> - 入力インデックス "
-"(入力ポリゴンの順番で決まります)の最小値でマージします"
+msgstr ""
+"<code>MERGE_MIN_INDEX</code> - 入力インデックス "
+"(入力ポリゴンの順番で決まります)の最小値を持つポリゴンにマージします"
 #. Tag: para
 #, no-c-format
Summary of changes:
 doc/po/ja/postgis-manual.po | 17 +++++++++--------
 1 file changed, 9 insertions(+), 8 deletions(-)
hooks/post-receive
