[SCM] PostGIS branch master updated. 3.6.0rc2-259-g00bfa7206
git at osgeo.org
git at osgeo.org
Mon Dec 15 22:07:59 PST 2025
the project "PostGIS".
via 00bfa7206e6890cbcb86ca57060bfc7f749df139 (commit)
from 265af64a73582e6cdfed0fea1c69c618eda369ae (commit)
revisions in full, below.
commit 00bfa7206e6890cbcb86ca57060bfc7f749df139
Author: Regina Obe <lr at pcorp.us>
Date: Tue Dec 16 01:06:38 2025 -0500
GARDEN TEST HARNESS IMPROVEMNETS
- Change table and verison to 3.7
- Add Mis-shapen empty polygon to garden References #6028
diff --git a/doc/xsl/postgis_gardentest.sql.xsl b/doc/xsl/postgis_gardentest.sql.xsl
index cb367a6b7..ad9b80801 100644
--- a/doc/xsl/postgis_gardentest.sql.xsl
+++ b/doc/xsl/postgis_gardentest.sql.xsl
@@ -11,9 +11,9 @@
using a garden variety of geometries. Its intent is to flag major crashes.
<xsl:output method="text" />
- <xsl:variable name='testversion'>3.6.0</xsl:variable>
+ <xsl:variable name='testversion'>3.7.0</xsl:variable>
<xsl:variable name='fnexclude14'>AddGeometryColumn DropGeometryColumn DropGeometryTable</xsl:variable>
- <xsl:variable name='fnexclude'>AddGeometryColumn DropGeometryColumn DropGeometryTable CG_Visibility CG_YMonotonePartition ST_AlphaShape ST_OptimalAlphaShape</xsl:variable>
+ <xsl:variable name='fnexclude'>AddGeometryColumn DropGeometryColumn DropGeometryTable</xsl:variable>
<!--This is just a place holder to state functions not supported or tested separately -->
<xsl:variable name='var_srid'>3395</xsl:variable>
@@ -36,7 +36,7 @@
<xsl:variable name='var_matrix'>'FF1FF0102'</xsl:variable>
<xsl:variable name='var_boolean'>false</xsl:variable>
<xsl:variable name='var_geom_name'>the_geom</xsl:variable>
- <xsl:variable name='var_logtable'>postgis_garden_log36</xsl:variable>
+ <xsl:variable name='var_logtable'>postgis_garden_log37</xsl:variable>
<xsl:variable name='var_logupdatesql'>UPDATE <xsl:value-of select="$var_logtable" /> SET log_end = clock_timestamp()
FROM (SELECT logid FROM <xsl:value-of select="$var_logtable" /> ORDER BY logid DESC limit 1) As foo
WHERE <xsl:value-of select="$var_logtable" />.logid = foo.logid AND <xsl:value-of select="$var_logtable" />.log_end IS NULL;</xsl:variable>
@@ -278,6 +278,11 @@ FROM (VALUES ( ST_GeomFromEWKT('SRID=4326;MULTIPOLYGON(((-71.0821 42.3036 2,-71.
UNION ALL SELECT ST_MakePolygon(ST_GeomFromText('LINESTRING(1 2, 1 2,1 2, 1 2, 3 2, 1 2)',4326)) As the_geom
</pgis:gset>
+ <pgis:gset ID="Malformed Polygon 1 ring with 0 points" GeometryType="POLYGON" createtable="true">(SELECT ST_SetSRID('0103000020971300000100000000000000'::GEOMETRY,4326) AS the_geom
+ </pgis:gset>
<pgis:gset ID="Infinite Polygons" GeometryType="POLYGON" createtable="true">(SELECT '0106000020E61000000100000001030000000100000005000000000000000000F07F000000000000F07F000000000000F07F000000000000F07F000000000000F07F000000000000F07F000000000000F07F000000000000F07F000000000000F07F000000000000F07F'::geometry AS the_geom
</pgis:gset>
diff --git a/doc/xsl/raster_gardentest.sql.xsl b/doc/xsl/raster_gardentest.sql.xsl
index 01ed0e637..e89e89951 100644
--- a/doc/xsl/raster_gardentest.sql.xsl
+++ b/doc/xsl/raster_gardentest.sql.xsl
@@ -10,7 +10,7 @@
using a garden variety of rasters. Its intent is to flag major crashes.
<xsl:variable name='fnexclude'>AddRasterColumn AddRasterConstraints DropRasterConstraints DropRasterColumn DropRasterTable</xsl:variable>
<!--This is just a place holder to state functions not supported in 1.3 or tested separately -->
@@ -33,7 +33,7 @@
<xsl:variable name='var_rastercolumn'>'rast'</xsl:variable>
<xsl:variable name='var_rastertable'>'pgis_rgarden_1bb'</xsl:variable>
- <xsl:variable name='var_logtable'>raster_garden_log36</xsl:variable>
+ <xsl:variable name='var_logtable'>raster_garden_log37</xsl:variable>
<xsl:variable name='var_pixeltypes'>{8BUI,1BB}</xsl:variable>
<xsl:variable name='var_pixelvalues'>{255,0}</xsl:variable>
<xsl:variable name='var_algorithm'>'Lanczos'</xsl:variable>
@@ -134,7 +134,7 @@ CREATE TABLE <xsl:value-of select="$var_logtable" />(logid serial PRIMARY KEY, l
DROP TABLE IF EXISTS <xsl:value-of select="$var_logtable" />_output;
CREATE TABLE <xsl:value-of select="$var_logtable" />_output(logid integer PRIMARY KEY, log_output xml);
<xsl:apply-templates select="/db:book/db:chapter[@xml:id='RT_reference']" />
</xsl:template>
<xsl:template match='db:chapter'>
<!-- define a table we call pgis_rgarden_mega that will contain a raster column with a band for all types of pixels we support -->
diff --git a/doc/xsl/sfcgal_gardentest.sql.xsl b/doc/xsl/sfcgal_gardentest.sql.xsl
index 5cd41b796..0e48ecd1c 100644
--- a/doc/xsl/sfcgal_gardentest.sql.xsl
+++ b/doc/xsl/sfcgal_gardentest.sql.xsl
@@ -11,7 +11,7 @@
<xsl:variable name='fnexclude'>CG_Simplify CG_Visibility CG_YMonotonePartition ST_AlphaShape ST_OptimalAlphaShape</xsl:variable>
@@ -36,7 +36,7 @@
Summary of changes:
doc/xsl/postgis_gardentest.sql.xsl | 11 ++++++++---
doc/xsl/raster_gardentest.sql.xsl | 6 +++---
doc/xsl/sfcgal_gardentest.sql.xsl | 4 ++--
3 files changed, 13 insertions(+), 8 deletions(-)
hooks/post-receive
