[SCM] PostGIS branch stable-3.5 updated. 3.5.3-25-g3fddeb479
Thu Jul 3 09:35:58 PDT 2025
the project "PostGIS".
The branch, stable-3.5 has been updated
       via  3fddeb47969fe6337694549035c3d4c0776cc4ab (commit)
       via  02839b684ecd8d555fce6ff21fa7f30533e614d4 (commit)
       via  9a31e3bfb4b3af576f2247cf7243e5c0e6ce70bd (commit)
       via  dcf7c2085ce0e6d6dea114920387e452852a48a2 (commit)
      from  f3fc45595528bbf5172855730991eadc3e25b367 (commit)
revisions in full, below.
commit 3fddeb47969fe6337694549035c3d4c0776cc4ab
Author: Regina Obe <lr at pcorp.us>
Date:   Thu Jul 3 12:35:40 2025 -0400
    GHA testing replace latest with pg18-geosmain
diff --git a/.github/workflows/ci.yml b/.github/workflows/ci.yml
index 7c042da6d..120c7f25d 100644
--- a/.github/workflows/ci.yml
+++ b/.github/workflows/ci.yml
@@ -29,7 +29,7 @@ jobs:
         #- { tag: pg13-geos39-gdal31-proj71, mode: usan_gcc }
         - { tag: pg13-clang-geos39-gdal31-proj71, mode: usan_clang }
         # Run tests with different dependency combinations
-        - { tag: latest, mode: tests }
+        - { tag: pg18-geosmain-gdal311-proj96, mode: tests }
         - { tag: pg17-geos313-gdal39-proj94, mode: garden }
         - { tag: pg13-geos38-gdal31-proj71, mode: tests }
         - { tag: pg12-geos38-gdal30-proj611, mode: tests }
commit 02839b684ecd8d555fce6ff21fa7f30533e614d4
Date:   Thu Jul 3 12:20:34 2025 -0400
    Get rid of pg version conditional for geojson so works on PG 19
diff --git a/postgis/lwgeom_out_geojson.c b/postgis/lwgeom_out_geojson.c
index f3fa046df..67c1cafa6 100644
--- a/postgis/lwgeom_out_geojson.c
+++ b/postgis/lwgeom_out_geojson.c
@@ -32,7 +32,6 @@
 #include "lwgeom_log.h"
 #include "liblwgeom.h"
-#if POSTGIS_PGSQL_VERSION < 190
 typedef enum					/* type categories for datum_to_json */
 	JSONTYPE_NULL,				/* null, so we didn't bother to identify */
@@ -47,7 +46,6 @@ typedef enum					/* type categories for datum_to_json */
 	JSONTYPE_CAST,				/* something with an explicit cast to JSON */
 	JSONTYPE_OTHER				/* all else */
 } JsonTypeCategory;
-#endif
 static void array_dim_to_json(StringInfo result, int dim, int ndims, int *dims,
 				  Datum *vals, bool *nulls, int *valcount,
@@ -69,11 +67,11 @@ static void composite_to_json(Datum composite, StringInfo result,
 static void datum_to_json(Datum val, bool is_null, StringInfo result,
 						  JsonTypeCategory tcategory, Oid outfuncoid,
 						  bool key_scalar);
 static void json_categorize_type(Oid typoid,
 								 JsonTypeCategory *tcategory,
 								 Oid *outfuncoid);
-#endif
 static char * postgis_JsonEncodeDateTime(char *buf, Datum value, Oid typid);
 static int postgis_time2tm(TimeADT time, struct pg_tm *tm, fsec_t *fsec);
 static int postgis_timetz2tm(TimeTzADT *time, struct pg_tm *tm, fsec_t *fsec, int *tzp);
@@ -283,7 +281,6 @@ composite_to_geojson(FunctionCallInfo fcinfo,
  * output function OID.  If the returned category is JSONTYPE_CAST, we
  * return the OID of the type->JSON cast function instead.
 static void
@@ -376,7 +373,6 @@ json_categorize_type(Oid typoid,
 			break;
-#endif
  * Turn a Datum into JSON text, appending the string to "result".
commit 9a31e3bfb4b3af576f2247cf7243e5c0e6ce70bd
Date:   Thu Jul 3 12:17:59 2025 -0400
    News and Credits
    References #5935 for PostGIS 3.5.4
diff --git a/NEWS b/NEWS
index f63f98657..8f8616fcf 100644
--- a/NEWS
+++ b/NEWS
@@ -15,6 +15,8 @@ PostgreSQL 12-18 required. GEOS 3.8+ required. Proj 6.1+ required.
 - #5909, ST_ValueCount crashes on empty table (Paul Ramsey)
 - #5917, ST_Relate becomes unresponsive (Paul Ramsey)
 - #5923, CG_ExtrudeStraightSkeleton crashes on empty polygon (Loïc Bartoletti)
+- #5935, Require GDAL 2.4 for postgis_raster
+         and switch to GDALGetDataTypeSizeBytes (Laurențiu Nicola)
 PostGIS 3.5.3
diff --git a/doc/introduction.xml b/doc/introduction.xml
index 26bfec40f..1f0e2ba18 100644
--- a/doc/introduction.xml
+++ b/doc/introduction.xml
@@ -289,6 +289,7 @@
 					<member>Kashif Rasul</member>
 					<member>Klaus Foerster</member>
 					<member>Kris Jurka</member>
+					<member>Laurențiu Nicola</member>
 					<member>Laurenz Albe</member>
 					<member>Lars Roessiger</member>
 					<member>Leo Hsu</member>
commit dcf7c2085ce0e6d6dea114920387e452852a48a2
Date:   Thu Jul 3 12:02:46 2025 -0400
    Require GDAL 2.4 for postgis_raster and switch to GDALGetDataTypeSizeBytes
    Credit: Laurențiu Nicola
    Closes #5935 for PostGIS 3.5.4
diff --git a/configure.ac b/configure.ac
index ed5d17255..a60828c9d 100644
--- a/configure.ac
+++ b/configure.ac
@@ -1581,8 +1581,8 @@ if test "x$with_raster" != "xno"; then
 	LIBGDAL_DEPLIBS_LDFLAGS=""
 	dnl GDAL version constants, update here
-	GDAL_MIN_VERSION=2.0.0
-	GDAL_MIN_VERSION_NUMBER=180 dnl TODO: Use GDAL version calculation MAJOR*1000+MINOR*100+REV*10+BUILD
+	GDAL_MIN_VERSION=2.4.0
+	GDAL_MIN_VERSION_NUMBER=240 dnl TODO: Use GDAL version calculation MAJOR*1000+MINOR*100+REV*10+BUILD
 	AC_ARG_WITH(
 		[gdalconfig],
diff --git a/raster/rt_core/rt_raster.c b/raster/rt_core/rt_raster.c
index ca055cf6c..6e6fd3dbc 100644
--- a/raster/rt_core/rt_raster.c
+++ b/raster/rt_core/rt_raster.c
@@ -2402,7 +2402,7 @@ rt_raster_from_gdal_dataset(GDALDatasetH ds) {
 		/* pixtype */
 		gdpixtype = GDALGetRasterDataType(gdband);
-		RASTER_DEBUGF(4, "gdpixtype, size = %s, %d", GDALGetDataTypeName(gdpixtype), GDALGetDataTypeSize(gdpixtype) / 8);
+		RASTER_DEBUGF(4, "gdpixtype, size = %s, %d", GDALGetDataTypeName(gdpixtype), GDALGetDataTypeSizeBytes(gdpixtype));
 		pt = rt_util_gdal_datatype_to_pixtype(gdpixtype);
 		if (pt == PT_END) {
 			rterror("rt_raster_from_gdal_dataset: Unknown pixel type for GDAL band");
diff --git a/raster/rt_pg/rtpg_gdal.c b/raster/rt_pg/rtpg_gdal.c
index 039ea61d5..c3bc5f3ee 100644
--- a/raster/rt_pg/rtpg_gdal.c
+++ b/raster/rt_pg/rtpg_gdal.c
@@ -719,7 +719,7 @@ Datum RASTER_InterpolateRaster(PG_FUNCTION_ARGS)
 	in_band_height = rt_band_get_height(in_band);
 	in_band_pixtype = rt_band_get_pixtype(in_band);
 	in_band_gdaltype = rt_util_pixtype_to_gdal_datatype(in_band_pixtype);
-	in_band_gdaltype_size = GDALGetDataTypeSize(in_band_gdaltype) / 8;
+	in_band_gdaltype_size = GDALGetDataTypeSizeBytes(in_band_gdaltype);
 	/* Quickly copy options struct into local memory context, so we */
 	/* don't have malloc'ed memory lying around */
Summary of changes:
 .github/workflows/ci.yml     | 2 +-
 NEWS                         | 2 ++
 configure.ac                 | 4 ++--
 doc/introduction.xml         | 1 +
 postgis/lwgeom_out_geojson.c | 8 ++------
 raster/rt_core/rt_raster.c   | 2 +-
 raster/rt_pg/rtpg_gdal.c     | 2 +-
 7 files changed, 10 insertions(+), 11 deletions(-)
hooks/post-receive
