[SCM] PostGIS branch master updated. 3.5.0-420-g26806523b
Thu Jul 3 09:48:54 PDT 2025
the project "PostGIS".
       via  26806523b3b496da267df50d7c81cfe75ef8c316 (commit)
       via  404c1593e0ddeb8b32babe3934586e1fefe5eba5 (commit)
       via  9d24c9def45a87fcdd5fcaa62c552e64be5ec58a (commit)
      from  8acbf176099084371012c2652f993b6c840c44fd (commit)
revisions in full, below.
commit 26806523b3b496da267df50d7c81cfe75ef8c316
Author: Regina Obe <lr at pcorp.us>
Date:   Thu Jul 3 12:48:31 2025 -0400
    Add Laurențiu Nicola to credits
diff --git a/doc/introduction.xml b/doc/introduction.xml
index 65affd04b..91034b489 100644
--- a/doc/introduction.xml
+++ b/doc/introduction.xml
@@ -290,6 +290,7 @@
 					<member>Kashif Rasul</member>
 					<member>Klaus Foerster</member>
 					<member>Kris Jurka</member>
+					<member>Laurențiu Nicola</member>
 					<member>Laurenz Albe</member>
 					<member>Lars Roessiger</member>
 					<member>Leo Hsu</member>
commit 404c1593e0ddeb8b32babe3934586e1fefe5eba5
Date:   Thu Jul 3 12:46:00 2025 -0400
    GHA workflow, add pg18 testing because latest is now following pg19
diff --git a/.github/workflows/ci.yml b/.github/workflows/ci.yml
index 45bba0dc3..3b8ce4911 100644
--- a/.github/workflows/ci.yml
+++ b/.github/workflows/ci.yml
@@ -17,6 +17,7 @@ jobs:
       matrix:
         ci:
         # Use the last stable releases to run more tests
+        - { tag: pg18-geosmain-gdal311-proj96, mode: tests }
         - { tag: pg17-geos313-gdal39-proj94, mode: coverage }
         # - { tag: pg17-geos313-gdal39-proj94, mode: garden }
         - { tag: pg16-geos312-gdal37-proj921, mode: coverage }
commit 9d24c9def45a87fcdd5fcaa62c552e64be5ec58a
Date:   Thu Jul 3 12:42:52 2025 -0400
    Fix geosjson building on pg19, missed some spots on last commit
diff --git a/postgis/lwgeom_out_geojson.c b/postgis/lwgeom_out_geojson.c
index e918c7565..411f7c068 100644
--- a/postgis/lwgeom_out_geojson.c
+++ b/postgis/lwgeom_out_geojson.c
@@ -69,7 +69,7 @@ static void composite_to_json(Datum composite, StringInfo result,
 static void datum_to_json(Datum val, bool is_null, StringInfo result,
 						  JsonTypeCategory tcategory, Oid outfuncoid,
 						  bool key_scalar);
-#if POSTGIS_PGSQL_VERSION < 190
+#if POSTGIS_PGSQL_VERSION < 200
 static void json_categorize_type(Oid typoid,
 								 JsonTypeCategory *tcategory,
 								 Oid *outfuncoid);
@@ -283,7 +283,7 @@ composite_to_geojson(FunctionCallInfo fcinfo,
  * output function OID.  If the returned category is JSONTYPE_CAST, we
  * return the OID of the type->JSON cast function instead.
 static void
Summary of changes:
 .github/workflows/ci.yml     | 1 +
 doc/introduction.xml         | 1 +
 postgis/lwgeom_out_geojson.c | 4 ++--
 3 files changed, 4 insertions(+), 2 deletions(-)
hooks/post-receive
