[SCM] PostGIS branch master updated. 3.5.0-427-gc8de602d6
Fri Jul 4 13:38:01 PDT 2025
the project "PostGIS".
       via  c8de602d6025adc6c16644d348e90e039dc5629f (commit)
      from  784f21a1fd90246aba1c250a2729ccf2de29b7f1 (commit)
revisions in full, below.
commit c8de602d6025adc6c16644d348e90e039dc5629f
Author: Paul Ramsey <paul.ramsey at snowflake.com>
Date:   Fri Jul 4 13:35:44 2025 -0700
    Add ST_ReclassExact(raster, float8[], float8[]) returns raster
    function to do 1:1 value mapping of rasters. Ordinary reclass
    supports mapping ranges to ranges, which is complex and slow.
    For the case where the mapping is 1:1, this function is 100x
    faster.
diff --git a/NEWS b/NEWS
index f331baa3b..7952cfacb 100644
--- a/NEWS
+++ b/NEWS
@@ -37,3 +37,5 @@ Daniel Nylander (Swedish Team)
   - #5841, Change interrupt handling to remove use of pqsignal to support PG 18 (Paul Ramsey)
   - Add ST_CoverageClean to edge match and gap remove polygonal
     coverages (Paul Ramsey) from GEOS 3.14 (Martin Davis)
+  - Add ST_ReclassExact to quickly remap values in raster (Paul Ramsey)
diff --git a/doc/reference_raster.xml b/doc/reference_raster.xml
index e283dd77c..46efd0632 100644
--- a/doc/reference_raster.xml
+++ b/doc/reference_raster.xml
@@ -5,7 +5,7 @@
   <para><varname>raster</varname> is a PostGIS type for storing and analyzing raster data. </para>
   <para>For loading rasters from raster files please refer to <xref linkend="RT_Loading_Rasters"/></para>
-    <para>Some examples in this reference use a raster table of dummy data,
+    <para>Some examples in this reference use a raster table of dummy data,
     created with the following code:</para>
 <programlisting language="sql">CREATE TABLE dummy_rast(rid integer, rast raster);
 INSERT INTO dummy_rast(rid, rast)
@@ -40,7 +40,7 @@ VALUES (1,
 '41000000007719564100000000000000000000000000000000FFFFFFFF050005000400FDFEFDFEFEFDFEFEFDF9FAFEF' ||
 'EFCF9FBFDFEFEFDFCFAFEFEFE04004E627AADD16076B4F9FE6370A9F5FE59637AB0E54F58617087040046566487A1506CA2E3FA5A6CAFFBFE4D566DA4CB3E454C5665')::raster);</programlisting>
-  <para>The functions below are ones which a user of PostGIS Raster is likely to need.
+  <para>The functions below are ones which a user of PostGIS Raster is likely to need.
   There are other raster support functions which are not of interest to a general
   user.</para>
@@ -12392,13 +12392,13 @@ SELECT ST_MapAlgebraFctNgb(rast, 1,  '8BUI', 4,4,
                 <refsection>
                     <title>Description</title>
-                    <para>Creates a new raster formed by applying a reclassification operation defined by the <varname>reclassexpr</varname> on the input raster (<varname>rast</varname>).
+                    <para>Creates a new raster formed by applying a reclassification operation defined by the <varname>reclassexpr</varname> on the input raster (<varname>rast</varname>).
                     Refer to <xref linkend="reclassarg"/> for the description of reclassification expressions.
-                    If no <varname>band</varname> is specified band 1 is assumed.
+                    If no <varname>band</varname> is specified band 1 is assumed.
                     </para>
-                    <para>The new raster will have the same georeference, width, and height as the original raster.
-                    The bands of the new raster have pixel type of <varname>pixeltype</varname>.
+                    <para>The new raster will have the same georeference, width, and height as the original raster.
+                    The bands of the new raster have pixel type of <varname>pixeltype</varname>.
                     If <varname>reclassargset</varname> is specified then each <varname>reclassarg</varname> defines the type of the target band.
                     Bands not designated are returned unchanged.
                     </para>
@@ -12494,6 +12494,117 @@ UPDATE wind
                 </refsection>
             </refentry>
+            <refentry xml:id="RT_ST_ReclassExact">
+                <refnamediv>
+                    <refname>ST_ReclassExact</refname>
+                    <refpurpose>Creates a new raster composed of bands reclassified from original, using a 1:1 mapping from values in the original band to new values in the destination band.</refpurpose>
+                </refnamediv>
+                <refsynopsisdiv>
+                    <funcsynopsis>
+                      <funcprototype>
+                            <funcdef>raster <function>ST_ReclassExact</function></funcdef>
+                            <paramdef><type>raster </type> <parameter>rast</parameter></paramdef>
+                            <paramdef><type>double precision[] </type> <parameter>inputvalues</parameter></paramdef>
+                            <paramdef><type>double precision[] </type> <parameter>outputvalues</parameter></paramdef>
+                            <paramdef choice="opt"><type>integer </type> <parameter>bandnumber=1</parameter></paramdef>
+                            <paramdef choice="opt"><type>text </type> <parameter>pixeltype=32BF</parameter></paramdef>
+                            <paramdef choice="opt"><type>double precision </type> <parameter>nodatavalue=NULL</parameter></paramdef>
+                      </funcprototype>
+                    </funcsynopsis>
+                </refsynopsisdiv>
+                <refsection>
+                    <title>Description</title>
+                    defined by the <varname>inputvalues</varname> and
+                    <varname>outputvalues</varname> arrays. Pixel values found in the
+                    input array are mapped to the corresponding value in the output array.
+                    All other pixel values are mapped to the <varname>nodatavalue</varname>.
+                    </para>
+                    <para>The output pixel type defaults to float, but can be specified
+                    using the <varname>pixeltype</varname> parameter.
+                    If no <varname>bandnumber</varname> is specified band 1 is assumed.
+                    </para>
+                    and height as the original raster.
+                    Bands not designated are returned unchanged.
+                    </para>
+                    <para role="availability" conformance="3.6.0">Availability: 3.6.0 </para>
+                </refsection>
+                <refsection>
+                    <title>Example: Basic</title>
+                    <para>Create a small raster and map its pixels to new values.</para>
+                    <programlisting>
+CREATE TABLE reclassexact (
+	id integer,
+	rast raster
+-- Create a raster with just four pixels
+-- [1  2]
+-- [3  4]
+INSERT INTO reclassexact (id, rast)
+SELECT 1, ST_SetValues(
+    ST_AddBand(
+      ST_MakeEmptyRaster(
+        2,    -- width in pixels
+        2,    -- height in pixels
+        0,    -- upper-left x-coordinate
+        0,    -- upper-left y-coordinate
+        1,    -- pixel size in x-direction
+        -1,   -- pixel size in y-direction (negative for north-up)
+        0,    -- skew in x-direction
+        0,    -- skew in y-direction
+        4326  -- SRID (e.g., WGS 84)
+      '32BUI'::text, -- pixel type (e.g., '32BF' for float, '8BUI' for unsigned 8-bit int)
+      0.0,           -- initial value for the band (e.g., 0.0 or a no-data value)
+      -99            -- nodatavalue
+    1, -- band number (usually 1 for single-band rasters)
+    1, -- x origin for setting values (usually 1)
+    1, -- y origin for setting values (usually 1)
+    ARRAY[
+      ARRAY[1, 2],
+      ARRAY[3, 4]
+    ]::double precision[][] -- 2D array of values
+-- Reclass the values to new values
+-- and dump the values of the new raster for display
+WITH rc AS (
+  SELECT ST_ReclassExact(
+    rast,                -- input raster
+    ARRAY[4,3,2,1],      -- input map
+    ARRAY[14,13,12,11],  -- output map
+    1,                   -- band number to remap
+    '32BUI'              -- output raster pixtype
+    ) AS rast
+  FROM reclassexact
+  WHERE id = 1
+SELECT 'rce-1', (ST_DumpValues(rc.rast)).*
+FROM rc;
+                    </programlisting>
+                </refsection>
+                <refsection>
+                    <title>See Also</title>
+                    <para>
+                        <xref linkend="RT_ST_Reclass"/>,
+                        <xref linkend="RT_ST_AddBand"/>,
+                        <xref linkend="RT_ST_Band"/>,
+                        <xref linkend="RT_ST_MakeEmptyRaster"/>
+                    </para>
+                </refsection>
+            </refentry>
             <refentry xml:id="RT_ST_Union">
                 <refnamediv>
                     <refname>ST_Union</refname>
diff --git a/raster/rt_core/librtcore.h b/raster/rt_core/librtcore.h
index beced79c4..399f9d8e2 100644
--- a/raster/rt_core/librtcore.h
+++ b/raster/rt_core/librtcore.h
@@ -154,6 +154,7 @@ typedef struct rt_quantile_t* rt_quantile;
 typedef struct rt_valuecount_t* rt_valuecount;
 typedef struct rt_gdaldriver_t* rt_gdaldriver;
 typedef struct rt_reclassexpr_t* rt_reclassexpr;
+typedef struct rt_reclassmap_t* rt_reclassmap;
 typedef struct rt_iterator_t* rt_iterator;
 typedef struct rt_iterator_arg_t* rt_iterator_arg;
@@ -435,6 +436,18 @@ rt_band rt_band_new_inline(
 	uint8_t* data
+ * Fill in the cells of a band with a starting value
+ * frequently used to init with nodata value
+ * @param band      : band to initialize
+ * @param initval   : value to initialize with
+void rt_band_init_value(
+	rt_band band,
+	double initval
  * Create an out-db rt_band
@@ -997,6 +1010,20 @@ rt_band rt_band_reclass(
 	rt_reclassexpr *exprset, int exprcount
+ * Returns new band with values reclassified
+ * @param srcband : the band who's values will be reclassified
+ * @param map : the src and dst values to remapping
+ * @param hasnodata : indicates if the band has a nodata value
+ * @param nodataval : nodata value for the new band
+ * @return a new rt_band or NULL on error
+rt_band rt_band_reclass_exact(
+	rt_band srcband, rt_reclassmap map,
+	uint32_t hasnodata, double nodataval
 /*- rt_raster --------------------------------------------------------*/
@@ -2582,6 +2609,20 @@ struct rt_reclassexpr_t {
 	} src, dst;
+/* src/dst mapping for rt_classmap */
+struct rt_classpair_t {
+	double src;
+	double dst;
+/* exact reclassification expression */
+struct rt_reclassmap_t {
+	uint32_t count;
+	rt_pixtype srctype;
+	rt_pixtype dsttype;
+	struct rt_classpair_t *pairs;
 /* raster iterator */
 struct rt_iterator_t {
 	rt_raster raster;
diff --git a/raster/rt_core/rt_band.c b/raster/rt_core/rt_band.c
index f633bc822..4578609a2 100644
--- a/raster/rt_core/rt_band.c
+++ b/raster/rt_core/rt_band.c
@@ -101,6 +101,157 @@ rt_band_new_inline(
 	return band;
+void
+rt_band_init_value(
+	rt_band band,
+	double initval
+	assert(band != NULL);
+	assert(band->data.mem != NULL);
+	rt_pixtype pixtype = band->pixtype;
+	uint32_t width = band->width;
+	uint32_t height = band->height;
+	uint32_t numval = width * height;
+	void *mem = band->data.mem;
+	size_t memsize = numval * rt_pixtype_size(pixtype);
+	/* initialize to nodataval */
+	int32_t checkvalint = 0;
+	uint32_t checkvaluint = 0;
+	double checkvaldouble = 0;
+	float checkvalfloat = 0;
+	/* initialize to zero */
+	if (FLT_EQ(initval, 0.0)) {
+		memset(mem, 0, memsize);
+		return;
+	switch (pixtype) {
+		case PT_1BB:
+			uint8_t *ptr = mem;
+			uint8_t clamped_initval = rt_util_clamp_to_1BB(initval);
+			for (uint32_t i = 0; i < numval; i++)
+				ptr[i] = clamped_initval;
+			checkvalint = ptr[0];
+			break;
+		case PT_2BUI:
+			uint8_t clamped_initval = rt_util_clamp_to_2BUI(initval);
+			break;
+		case PT_4BUI:
+			uint8_t clamped_initval = rt_util_clamp_to_4BUI(initval);
+			break;
+		case PT_8BSI:
+			int8_t *ptr = mem;
+			int8_t clamped_initval = rt_util_clamp_to_8BSI(initval);
+			break;
+		case PT_8BUI:
+			uint8_t clamped_initval = rt_util_clamp_to_8BUI(initval);
+			break;
+		case PT_16BSI:
+			int16_t *ptr = mem;
+			int16_t clamped_initval = rt_util_clamp_to_16BSI(initval);
+			break;
+		case PT_16BUI:
+			uint16_t *ptr = mem;
+			uint16_t clamped_initval = rt_util_clamp_to_16BUI(initval);
+			break;
+		case PT_32BSI:
+			int32_t *ptr = mem;
+			int32_t clamped_initval = rt_util_clamp_to_32BSI(initval);
+			break;
+		case PT_32BUI:
+			uint32_t *ptr = mem;
+			uint32_t clamped_initval = rt_util_clamp_to_32BUI(initval);
+			checkvaluint = ptr[0];
+			break;
+		case PT_32BF:
+			float *ptr = mem;
+			float clamped_initval = rt_util_clamp_to_32F(initval);
+			checkvalfloat = ptr[0];
+			break;
+		case PT_64BF:
+			double *ptr = mem;
+				ptr[i] = initval;
+			checkvaldouble = ptr[0];
+			break;
+		default:
+			rterror("%s: Unknown pixeltype %d", __func__, pixtype);
+			return;
+	/* Overflow checking */
+	rt_util_dbl_trunc_warning(
+		initval,
+		checkvalint, checkvaluint,
+		checkvalfloat, checkvaldouble,
+		pixtype
+	return;
@@ -2080,4 +2231,3 @@ rt_band_corrected_clamped_value(
 	return ES_NONE;
diff --git a/raster/rt_core/rt_mapalgebra.c b/raster/rt_core/rt_mapalgebra.c
index 4d34520a0..ec56a5ada 100644
--- a/raster/rt_core/rt_mapalgebra.c
+++ b/raster/rt_core/rt_mapalgebra.c
@@ -34,6 +34,25 @@
 * rt_band_reclass()
+static inline double
+rt_band_reclass_round_integer(rt_pixtype pixtype, double nv)
+		case PT_1BB:
+		case PT_2BUI:
+		case PT_4BUI:
+		case PT_8BSI:
+		case PT_8BUI:
+		case PT_16BSI:
+		case PT_16BUI:
+		case PT_32BSI:
+		case PT_32BUI:
+			return round(nv);
+		default:
+			return nv;
@@ -94,134 +113,6 @@ rt_band_reclass(
 		return 0;
-	/* initialize to zero */
-	if (!hasnodata) {
-		memset(mem, 0, memsize);
-	/* initialize to nodataval */
-	else {
-		int32_t checkvalint = 0;
-		uint32_t checkvaluint = 0;
-		double checkvaldouble = 0;
-		float checkvalfloat = 0;
-		switch (pixtype) {
-			case PT_1BB:
-				uint8_t *ptr = mem;
-				uint8_t clamped_initval = rt_util_clamp_to_1BB(nodataval);
-				for (i = 0; i < numval; i++)
-					ptr[i] = clamped_initval;
-				checkvalint = ptr[0];
-				break;
-			case PT_2BUI:
-				uint8_t clamped_initval = rt_util_clamp_to_2BUI(nodataval);
-				break;
-			case PT_4BUI:
-				uint8_t clamped_initval = rt_util_clamp_to_4BUI(nodataval);
-				break;
-			case PT_8BSI:
-				int8_t *ptr = mem;
-				int8_t clamped_initval = rt_util_clamp_to_8BSI(nodataval);
-				break;
-			case PT_8BUI:
-				uint8_t clamped_initval = rt_util_clamp_to_8BUI(nodataval);
-				break;
-			case PT_16BSI:
-				int16_t *ptr = mem;
-				int16_t clamped_initval = rt_util_clamp_to_16BSI(nodataval);
-				break;
-			case PT_16BUI:
-				uint16_t *ptr = mem;
-				uint16_t clamped_initval = rt_util_clamp_to_16BUI(nodataval);
-				break;
-			case PT_32BSI:
-				int32_t *ptr = mem;
-				int32_t clamped_initval = rt_util_clamp_to_32BSI(nodataval);
-				break;
-			case PT_32BUI:
-				uint32_t *ptr = mem;
-				uint32_t clamped_initval = rt_util_clamp_to_32BUI(nodataval);
-				checkvaluint = ptr[0];
-				break;
-			case PT_32BF:
-				float *ptr = mem;
-				float clamped_initval = rt_util_clamp_to_32F(nodataval);
-				checkvalfloat = ptr[0];
-				break;
-			case PT_64BF:
-				double *ptr = mem;
-					ptr[i] = nodataval;
-				checkvaldouble = ptr[0];
-				break;
-			default:
-				rterror("rt_band_reclass: Unknown pixeltype %d", pixtype);
-				rtdealloc(mem);
-				return 0;
-		/* Overflow checking */
-		rt_util_dbl_trunc_warning(
-			nodataval,
-			checkvalint, checkvaluint,
-			checkvalfloat, checkvaldouble,
-			pixtype
-	RASTER_DEBUGF(3, "rt_band_reclass: width = %d height = %d", width, height);
 	band = rt_band_new_inline(width, height, pixtype, hasnodata, nodataval, mem);
 	if (!band) {
 		rterror("rt_band_reclass: Could not create new band");
@@ -229,6 +120,8 @@ rt_band_reclass(
 		return 0;
 	rt_band_set_ownsdata_flag(band, 1); /* we DO own this data!!! */
+	rt_band_init_value(band, hasnodata ? nodataval : 0.0);
 	RASTER_DEBUGF(3, "rt_band_reclass: new band @ %p", band);
 	for (x = 0; x < width; x++) {
@@ -338,21 +231,7 @@ rt_band_reclass(
 			/* round the value for integers */
-				case PT_1BB:
-				case PT_2BUI:
-				case PT_4BUI:
-				case PT_8BSI:
-				case PT_8BUI:
-				case PT_16BSI:
-				case PT_16BUI:
-				case PT_32BSI:
-				case PT_32BUI:
-					nv = round(nv);
-					break;
-				default:
-					break;
+			nv = rt_band_reclass_round_integer(pixtype, nv);
 			RASTER_DEBUGF(4, "(%d, %d) ov: %f or: %f - %f nr: %f - %f nv: %f"
 				, x
@@ -378,6 +257,138 @@ rt_band_reclass(
 	return band;
+ * Pre-sorting the classpairs allows us to use bsearch
+ * on the array of classpairs in the pixel reclassification
+ * step later on.
+static int
+rt_classpair_cmp(const void *aptr, const void *bptr)
+	struct rt_classpair_t *a = (struct rt_classpair_t*)aptr;
+	struct rt_classpair_t *b = (struct rt_classpair_t*)bptr;
+	if (a->src < b->src) return -1;
+	else if (a->src > b->src) return 1;
+	else return 0;
+ * @param map : rt_reclassmap with src->dst mappings
+ * @param hasnodata : indicates if the user is supplying a nodata
+ * @param nodataval : user supplied nodata value for the new band
+rt_band
+rt_band_reclass_exact(
+	rt_band band = NULL;
+	uint32_t width = 0;
+	uint32_t height = 0;
+	int numval = 0;
+	int memsize = 0;
+	void *mem = NULL;
+	uint32_t src_hasnodata = 0;
+	rt_pixtype pixtype;
+	assert(NULL != srcband);
+	assert(NULL != map);
+	/* Validate that the map has consistent array lengths */
+	if (map->count == 0)
+		rterror("%s: reclassification map must contain at least one class pair", __func__);
+	/* Need a nodataval from somewhere */
+	src_hasnodata = rt_band_get_hasnodata_flag(srcband);
+	if (!(src_hasnodata || hasnodata))
+		rterror("%s: source band missing nodata value and nodata value not supplied", __func__);
+	* Use the nodata value of the input in the case where user
+	* does not supply a nodataval
+	if (!hasnodata && src_hasnodata) {
+		rt_band_get_nodata(srcband, &nodataval);
+		hasnodata = src_hasnodata;
+	/* size of memory block to allocate */
+	width = rt_band_get_width(srcband);
+	height = rt_band_get_height(srcband);
+	numval = width * height;
+	pixtype = map->dsttype;
+	memsize = rt_pixtype_size(pixtype) * numval;
+	mem = (int *) rtalloc(memsize);
+	if (!mem)
+		rterror("%s: Could not allocate memory for band", __func__);
+	band = rt_band_new_inline(width, height, pixtype, hasnodata, nodataval, mem);
+    if (! band) {
+        rterror("%s: Could not add band to raster. Aborting", __func__);
+        rtdealloc(mem);
+        return NULL;
+	rt_band_set_ownsdata_flag(band, 1); /* we own this data */
+	 * apply nodata as baseline value and then only
+	 * map in values that match our map
+	rt_band_init_value(band, nodataval);
+	 * Put the rt_classpairs in order of source value
+	 * so we can bsearch them
+	qsort(map->pairs, map->count, sizeof(struct rt_classpair_t), rt_classpair_cmp);
+	for (uint32_t x = 0; x < width; x++) {
+		for (uint32_t y = 0; y < height; y++) {
+			int isnodata;
+			double nv = nodataval;
+			struct rt_classpair_t query = {0.0, 0.0};
+			struct rt_classpair_t *rslt;
+			/* get pixel, skip on error */
+			if (rt_band_get_pixel(srcband, x, y, &query.src, &isnodata) != ES_NONE)
+				continue;
+			/* output was already initialized to nodataval */
+			if (isnodata)
+				continue;
+			 * Look for pixel value in map.
+			 * If not in map, skip, leaving the nodata value in place.
+			 * Otherwise continue and replace with new value
+			rslt = bsearch(&query, map->pairs, map->count, sizeof(struct rt_classpair_t), rt_classpair_cmp);
+			if (!rslt)
+				continue;
+			else
+				nv = rslt->dst;
+			/* round the new value for integer pixel types */
+			if (rt_band_set_pixel(band, x, y, nv, NULL) != ES_NONE) {
+				rterror("%s: Could not assign value to new band", __func__);
+				rt_band_destroy(band);
+				rtdealloc(mem);
+				return NULL;
+	return band;
 * rt_raster_iterator()
diff --git a/raster/rt_core/rt_raster.c b/raster/rt_core/rt_raster.c
index 5ef18357b..d98591a86 100644
--- a/raster/rt_core/rt_raster.c
+++ b/raster/rt_core/rt_raster.c
@@ -499,12 +499,6 @@ rt_raster_generate_new_band(
     int oldnumbands = 0;
     int numbands = 0;
     void * mem = NULL;
-    int i;
     assert(NULL != raster);
@@ -527,143 +521,27 @@ rt_raster_generate_new_band(
         return -1;
-    if (FLT_EQ(initialvalue, 0.0))
-        memset(mem, 0, datasize);
-    else {
-        switch (pixtype)
-            case PT_1BB:
-                uint8_t clamped_initval = rt_util_clamp_to_1BB(initialvalue);
-                break;
-            case PT_2BUI:
-                uint8_t clamped_initval = rt_util_clamp_to_2BUI(initialvalue);
-                break;
-            case PT_4BUI:
-                uint8_t clamped_initval = rt_util_clamp_to_4BUI(initialvalue);
-                break;
-            case PT_8BSI:
-                int8_t clamped_initval = rt_util_clamp_to_8BSI(initialvalue);
-                break;
-            case PT_8BUI:
-                uint8_t clamped_initval = rt_util_clamp_to_8BUI(initialvalue);
-                break;
-            case PT_16BSI:
-                int16_t clamped_initval = rt_util_clamp_to_16BSI(initialvalue);
-                break;
-            case PT_16BUI:
-                uint16_t clamped_initval = rt_util_clamp_to_16BUI(initialvalue);
-                break;
-            case PT_32BSI:
-                int32_t clamped_initval = rt_util_clamp_to_32BSI(initialvalue);
-                break;
-            case PT_32BUI:
-                uint32_t clamped_initval = rt_util_clamp_to_32BUI(initialvalue);
-                break;
-            case PT_32BF:
-                float *ptr = mem;
-                float clamped_initval = rt_util_clamp_to_32F(initialvalue);
-                break;
-            case PT_64BF:
-                    ptr[i] = initialvalue;
-                break;
-            default:
-                rterror("rt_raster_generate_new_band: Unknown pixeltype %d", pixtype);
-                rtdealloc(mem);
-                return -1;
-			initialvalue,
-			pixtype
     band = rt_band_new_inline(width, height, pixtype, hasnodata, nodatavalue, mem);
     if (! band) {
         rterror("rt_raster_generate_new_band: Could not add band to raster. Aborting");
         rtdealloc(mem);
         return -1;
-		rt_band_set_ownsdata_flag(band, 1); /* we DO own this data!!! */
-    index = rt_raster_add_band(raster, band, index);
-    numbands = rt_raster_get_num_bands(raster);
-    if (numbands == oldnumbands || index == -1) {
-        rterror("rt_raster_generate_new_band: Could not add band to raster. Aborting");
-        rt_band_destroy(band);
-		/* set isnodata if hasnodata = TRUE and initial value = nodatavalue */
-		if (hasnodata && FLT_EQ(initialvalue, nodatavalue))
-			rt_band_set_isnodata_flag(band, 1);
+	rt_band_init_value(band, initialvalue);
+	rt_band_set_ownsdata_flag(band, 1); /* we DO own this data!!! */
+	index = rt_raster_add_band(raster, band, index);
+	numbands = rt_raster_get_num_bands(raster);
+	if (numbands == oldnumbands || index == -1) {
+		rterror("rt_raster_generate_new_band: Could not add band to raster. Aborting");
+		return -1;
+	/* set isnodata if hasnodata = TRUE and initial value = nodatavalue */
+	if (hasnodata && FLT_EQ(initialvalue, nodatavalue))
+		rt_band_set_isnodata_flag(band, 1);
     return index;
diff --git a/raster/rt_pg/rtpg_mapalgebra.c b/raster/rt_pg/rtpg_mapalgebra.c
index d898c63af..c1cac17c3 100644
--- a/raster/rt_pg/rtpg_mapalgebra.c
+++ b/raster/rt_pg/rtpg_mapalgebra.c
@@ -59,6 +59,7 @@ Datum RASTER_clip(PG_FUNCTION_ARGS);
 /* reclassify specified bands of a raster */
 Datum RASTER_reclass(PG_FUNCTION_ARGS);
+Datum RASTER_reclass_exact(PG_FUNCTION_ARGS);
 /* apply colormap to specified band of a raster */
 Datum RASTER_colorMap(PG_FUNCTION_ARGS);
@@ -3998,6 +3999,143 @@ Datum RASTER_reclass(PG_FUNCTION_ARGS) {
 	PG_RETURN_POINTER(pgrtn);
+ * ST_ReclassExact(rast raster,
+ *    inputvalues float8[],
+ *    outputvalues float8[],
+ *    bandnumber integer DEFAULT 1,
+ *    outputpixeltype text DEFAULT '32BF',
+ *    nodatavalue float8 DEFAULT NULL
+ * 	) RETURNS raster
+PG_FUNCTION_INFO_V1(RASTER_reclass_exact);
+Datum RASTER_reclass_exact(PG_FUNCTION_ARGS) {
+	rt_pgraster *pgraster = NULL;
+	rt_pgraster *pgrtn = NULL;
+	rt_raster raster = NULL;
+	rt_band newband = NULL;
+	uint32_t bandnum = 0, numbands = 0;
+	ArrayType *arraysrc, *arraydst;
+	bool hasnodata = false;
+	double nodataval = 0.0;
+	text *pixeltype = NULL;
+	uint32_t szsrc, szdst;
+	ArrayIterator itersrc, iterdst;
+	Datum dsrc, ddst;
+	bool nullsrc, nulldst;
+	rt_reclassmap reclassmap;
+	rt_pixtype pixtypsrc, pixtypdst;
+	/* Check null on all arguments since function is not strict */
+	if (PG_ARGISNULL(0) || PG_ARGISNULL(1) || PG_ARGISNULL(2) || PG_ARGISNULL(3) || PG_ARGISNULL(4))
+		PG_RETURN_NULL();
+	/* Read SQL arguments */
+	pgraster = (rt_pgraster *) PG_DETOAST_DATUM(PG_GETARG_DATUM(0));
+	arraysrc = PG_GETARG_ARRAYTYPE_P(1);
+	arraydst = PG_GETARG_ARRAYTYPE_P(2);
+	bandnum = PG_GETARG_INT32(3); /* One-based band number */
+	pixeltype = PG_GETARG_TEXT_P(4);
+	if (!PG_ARGISNULL(5)) {
+		hasnodata = true;
+		nodataval = PG_GETARG_FLOAT8(5);
+	/* Check arrays have same size */
+	szsrc = ArrayGetNItems(ARR_NDIM(arraysrc), ARR_DIMS(arraysrc));
+	szdst = ArrayGetNItems(ARR_NDIM(arraydst), ARR_DIMS(arraydst));
+	if (szsrc !=  szdst)
+		elog(ERROR, "array lengths must be the same");
+	/* Read the raster */
+	raster = rt_raster_deserialize(pgraster, FALSE);
+	if (!raster) {
+		PG_FREE_IF_COPY(pgraster, 0);
+		elog(ERROR, "%s: Could not deserialize raster", __func__);
+	/* Check that this raster has bands we can work with */
+	if (numbands < 1)
+		elog(ERROR, "Raster has no bands");
+	if (bandnum < 1 || bandnum > numbands)
+		elog(ERROR, "Invalid band index %d, input raster has %d bands. Band indexes are one-based.",
+		     bandnum, numbands);
+	/* Read the band */
+	band = rt_raster_get_band(raster, bandnum-1);
+	if (!band)
+		elog(ERROR, "Could not find raster band of index %d", bandnum);
+	/* Get array element types */
+	pixtypsrc = rt_band_get_pixtype(band);
+	pixtypdst = rt_pixtype_index_from_name(text_to_cstring(pixeltype));
+	if (pixtypdst == PT_END)
+		elog(ERROR, "Unknown output pixel type '%s'", text_to_cstring(pixeltype));
+	/* Error out on unreadable pixeltype */
+	if (pixtypsrc == PT_END)
+		elog(ERROR, "Unsupported pixtype");
+	/* Create the rt_reclassmap */
+	reclassmap = palloc(sizeof(struct rt_reclassmap_t));
+	reclassmap->count = 0;
+	reclassmap->srctype = pixtypsrc;
+	reclassmap->dsttype = pixtypdst;
+	reclassmap->pairs = palloc(sizeof(struct rt_classpair_t) * szdst);
+	if (!hasnodata)
+		nodataval = rt_pixtype_get_min_value(pixtypdst);
+	/* Build up rt_reclassmap.pairs from arrays */
+	itersrc = array_create_iterator(arraysrc, 0, NULL);
+	iterdst = array_create_iterator(arraydst, 0, NULL);
+	while(array_iterate(itersrc, &dsrc, &nullsrc) &&
+	      array_iterate(iterdst, &ddst, &nulldst))
+		double valsrc = nullsrc ? nodataval : (double)DatumGetFloat8(dsrc);
+		double valdst = nulldst ? nodataval : (double)DatumGetFloat8(ddst);
+		Assert(szdst > reclassmap->count);
+		reclassmap->pairs[reclassmap->count].src = valsrc;
+		reclassmap->pairs[reclassmap->count].dst = valdst;
+		reclassmap->count++;
+	array_free_iterator(itersrc);
+	array_free_iterator(iterdst);
+	/* Carry out reclassification */
+	newband = rt_band_reclass_exact(band, reclassmap, hasnodata, nodataval);
+	/* Clean up finished map */
+	pfree(reclassmap->pairs);
+	pfree(reclassmap);
+	if (!newband)
+		elog(ERROR, "Band reclassification failed");
+	/* replace old band with new band */
+	if (rt_raster_replace_band(raster, newband, bandnum-1) == NULL) {
+		rt_band_destroy(newband);
+		rt_raster_destroy(raster);
+		elog(ERROR, "Could not replace raster band of index %d with reclassified band", bandnum);
+	pgrtn = rt_raster_serialize(raster);
+	if (!pgrtn)
+		PG_RETURN_NULL();
+	SET_VARSIZE(pgrtn, pgrtn->size);
+	PG_RETURN_POINTER(pgrtn);
diff --git a/raster/rt_pg/rtpostgis.sql.in b/raster/rt_pg/rtpostgis.sql.in
index c4f897484..9760723d2 100644
--- a/raster/rt_pg/rtpostgis.sql.in
+++ b/raster/rt_pg/rtpostgis.sql.in
@@ -1325,6 +1325,16 @@ CREATE OR REPLACE FUNCTION _st_reclass(rast raster, VARIADIC reclassargset recla
 	AS 'MODULE_PATHNAME', 'RASTER_reclass'
 	LANGUAGE 'c' IMMUTABLE STRICT PARALLEL SAFE;
+CREATE OR REPLACE FUNCTION ST_ReclassExact(rast raster,
+	inputvalues float8[], outputvalues float8[],
+	bandnumber integer DEFAULT 1,
+	outputpixeltype text DEFAULT '32BF',
+	nodatavalue float8 DEFAULT NULL
+	RETURNS raster
+	AS 'MODULE_PATHNAME', 'RASTER_reclass_exact'
+	LANGUAGE 'c' IMMUTABLE PARALLEL SAFE;
 CREATE OR REPLACE FUNCTION st_reclass(rast raster, VARIADIC reclassargset reclassarg[])
 	RETURNS raster
 	AS $$
diff --git a/raster/test/regress/rt_reclassexact.sql b/raster/test/regress/rt_reclassexact.sql
new file mode 100644
index 000000000..8002b88bd
--- /dev/null
+++ b/raster/test/regress/rt_reclassexact.sql
@@ -0,0 +1,94 @@
+DROP TABLE IF EXISTS reclassexact;
+	id integer,
+	rast raster
+    ST_AddBand(
+    ARRAY[
+      ARRAY[1, 2],
+      ARRAY[3, 4]
+-- Reclass and resort input arrays
+WITH rc AS (
+    ) AS rast
+  FROM reclassexact
+  WHERE id = 1
+FROM rc;
+-- Reclass to a new pixel type
+WITH rc AS (
+    '32BF'               -- output raster pixtype
+    ) AS rast
+  FROM reclassexact
+  WHERE id = 1
+SELECT 'rce-2', (ST_DumpValues(rc.rast)).*
+FROM rc;
+-- Mismatched array sizes
+WITH rc AS (
+    ARRAY[4,3,2,1,0],      -- input map
+    ) AS rast
+  FROM reclassexact
+  WHERE id = 1
+SELECT 'err-1', (ST_DumpValues(rc.rast)).*
+FROM rc;
+-- Bogus pixel type
+WITH rc AS (
+    '32BFF'               -- output raster pixtype
+    ) AS rast
+  FROM reclassexact
+  WHERE id = 1
+SELECT 'err-2', (ST_DumpValues(rc.rast)).*
+FROM rc;
diff --git a/raster/test/regress/rt_reclassexact_expected b/raster/test/regress/rt_reclassexact_expected
index 000000000..691c3931a
--- /dev/null
+++ b/raster/test/regress/rt_reclassexact_expected
@@ -0,0 +1,5 @@
+NOTICE:  table "reclassexact" does not exist, skipping
+rce-1|1|{{11,12},{13,14}}
+rce-2|1|{{11,12},{13,14}}
+ERROR:  array lengths must be the same
+ERROR:  Unknown output pixel type '32BFF'
diff --git a/raster/test/regress/tests.mk b/raster/test/regress/tests.mk
index ac17fda9e..9d75e50e1 100644
--- a/raster/test/regress/tests.mk
+++ b/raster/test/regress/tests.mk
@@ -84,6 +84,7 @@ RASTER_TEST_UTILITY = \
 	$(top_srcdir)/raster/test/regress/rt_asjpeg \
 	$(top_srcdir)/raster/test/regress/rt_aspng \
 	$(top_srcdir)/raster/test/regress/rt_reclass \
+	$(top_srcdir)/raster/test/regress/rt_reclassexact \
 	$(top_srcdir)/raster/test/regress/rt_gdalwarp \
 	$(top_srcdir)/raster/test/regress/rt_gdalcontour \
 	$(top_srcdir)/raster/test/regress/rt_asraster \
Summary of changes:
 NEWS                                         |   2 +
 doc/reference_raster.xml                     | 123 ++++++++++-
 raster/rt_core/librtcore.h                   |  41 ++++
 raster/rt_core/rt_band.c                     | 152 +++++++++++++-
 raster/rt_core/rt_mapalgebra.c               | 297 ++++++++++++++-------------
 raster/rt_core/rt_raster.c                   | 150 ++------------
 raster/rt_pg/rtpg_mapalgebra.c               | 138 +++++++++++++
 raster/rt_pg/rtpostgis.sql.in                |  10 +
 raster/test/regress/rt_reclassexact.sql      |  94 +++++++++
 raster/test/regress/rt_reclassexact_expected |   5 +
 raster/test/regress/tests.mk                 |   1 +
 11 files changed, 727 insertions(+), 286 deletions(-)
 create mode 100644 raster/test/regress/rt_reclassexact.sql
 create mode 100644 raster/test/regress/rt_reclassexact_expected
hooks/post-receive
