[PostGIS] #5938: ST_Relate(geom, geom, pattern) inconsistent
trac at osgeo.org
Fri Jul 4 14:33:55 PDT 2025
Reporter: pramsey | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.5.4
Component: postgis | Version: 3.5.x
Keywords: |
When used in the context of multiple return records, returns different
results than in a single record return. Likely a caching issue. The relate
pattern does not show the same instability.
SELECT
c.name AS city_name,
s.name AS state_name,
ST_Relate(c.point, s.poly),
ST_Relate(c.point, s.poly, 'T*F**F***') AS matches_mask
FROM City c
CROSS JOIN State s;
city_name | state_name | st_relate | matches_mask
Houston | Kansas | FF0FFF212 | f
Lawrence | Kansas | 0FFFFF212 | f
SELECT
FROM City c
CROSS JOIN State s
WHERE c.name = 'Lawrence';
Lawrence | Kansas | 0FFFFF212 | t
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5938>
