[PostGIS] #5938: ST_Relate(geom, geom, pattern) inconsistent
PostGIS trac at osgeo.org
Fri Jul 4 20:55:18 PDT 2025
  Reporter:  pramsey  |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  medium   |  Milestone:  PostGIS 3.5.4
 Component:  postgis  |    Version:  3.5.x
Resolution:           |   Keywords:
Description changed by pramsey:
Old description:
> When used in the context of multiple return records, returns different
> results than in a single record return. Likely a caching issue. The
> relate pattern does not show the same instability.
> SELECT
>  c.name AS city_name,
>  s.name AS state_name,
>  ST_Relate(c.point, s.poly),
>  ST_Relate(c.point, s.poly, 'T*F**F***') AS matches_mask
> FROM City c
> CROSS JOIN State s;
>  city_name | state_name | st_relate | matches_mask
>  Houston   | Kansas     | FF0FFF212 | f
>  Lawrence  | Kansas     | 0FFFFF212 | f
> SELECT
> FROM City c
> CROSS JOIN State s
> WHERE c.name = 'Lawrence';
>  Lawrence  | Kansas     | 0FFFFF212 | t
New description:
 https://lists.osgeo.org/pipermail/postgis-devel/2025-July/030578.html
 results than in a single record return. Likely a caching issue. The relate
 SELECT
 FROM City c
 CROSS JOIN State s;
 SELECT
 FROM City c
 CROSS JOIN State s
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5938#comment:2>
