[PostGIS] #5938: ST_Relate(geom, geom, pattern) inconsistent
trac at osgeo.org
Fri Jul 4 21:00:28 PDT 2025
Reporter: pramsey | Owner: pramsey
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 3.5.4
Component: postgis | Version: 3.5.x
Resolution: fixed | Keywords:
Changes (by Paul Ramsey <pramsey@…>):
* resolution: => fixed
* status: new => closed
Comment:
In [changeset:"a4886d8581d307a132ac19a3f7c5052e6de65657/git" a4886d8/git]:
{{{#!CommitTicketReference repository="git"
revision="a4886d8581d307a132ac19a3f7c5052e6de65657"
Handle case in new GEOS prepared ST_Relate code where the
order of operands changes based on which operand is cachable,
requiring the inversion of the DE9IM matrix to match the
new order. Closes #5938
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5938#comment:3>
