[PostGIS] #5940: bessie down since upgrade to 14.2
trac at osgeo.org
Tue Jul 8 21:30:23 PDT 2025
Reporter: robe | Owner: robe
Type: defect | Status: new
Priority: medium | Milestone: Website Management, Bots
Component: QA/buildbots | Version:
Keywords: |
Bessie is offline since I upgraded her to 14.2. I still need to do
another upgrade to 14.3 since 14.2 will be going away soon.
That said I suspect the issue is the java runtime probably got upgraded to
newer version than what debbie is running.
I need to upgrade debbie too since the java she is using will be EOL soon
and I also can't upgrade her jenkins install until java is upgraded cause
newest jenkins doesn't work with her current java.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5940>
