[SCM] PostGIS branch master updated. 3.5.0-443-gb077696e7
git at osgeo.org
git at osgeo.org
Thu Jul 10 14:06:02 PDT 2025
the project "PostGIS".
via b077696e7f0cad9361be3d43392a340d77365643 (commit)
from 1f78fc9da37ec4cfc1ccf8115a0f977aaeb7b1ae (commit)
revisions in full, below.
commit b077696e7f0cad9361be3d43392a340d77365643
Author: Paul Ramsey <paul.ramsey at snowflake.com>
Date: Thu Jul 10 14:04:50 2025 -0700
Update raster module to work with new GDT_Int8
pixel type in GDAL 3.7+.
https://trac.osgeo.org/postgis/ticket/5901
diff --git a/loader/cunit/Makefile.in b/loader/cunit/Makefile.in
index 33a115d0e..ab9e8d791 100644
--- a/loader/cunit/Makefile.in
+++ b/loader/cunit/Makefile.in
@@ -20,7 +20,7 @@ CFLAGS=@CFLAGS@
SHELL = @SHELL@
LIBTOOL = @LIBTOOL@
-CUNIT_LDFLAGS=@CUNIT_LDFLAGS@
+CUNIT_LDFLAGS=@CUNIT_LDFLAGS@ @GEOS_LDFLAGS@
CUNIT_CPPFLAGS = \
-I$(srcdir)/.. \
-I$(top_builddir)/liblwgeom \
diff --git a/raster/rt_core/rt_raster.c b/raster/rt_core/rt_raster.c
index d98591a86..99578fe87 100644
--- a/raster/rt_core/rt_raster.c
+++ b/raster/rt_core/rt_raster.c
@@ -1958,7 +1958,9 @@ rt_raster_to_gdal_mem(
For all pixel types other than PT_8BSI, set pointer to start of data
+#if POSTGIS_GDAL_VERSION < 30700
if (pt != PT_8BSI) {
+#endif
pVoid = rt_band_get_data(rtband);
RASTER_DEBUGF(4, "Band data is at pos %p", pVoid);
@@ -1989,12 +1991,12 @@ rt_raster_to_gdal_mem(
GDALClose(ds);
return 0;
- PT_8BSI is special as GDAL has no equivalent pixel type.
+ PT_8BSI is special as GDAL (prior to 3.7) has no equivalent pixel type.
Must convert 8BSI to 16BSI so create basic band
- else {
+ } else {
/* add band */
if (GDALAddBand(ds, gdal_pt, NULL) == CE_Failure) {
rterror("rt_raster_to_gdal_mem: Could not add GDAL raster band");
@@ -2004,6 +2006,7 @@ rt_raster_to_gdal_mem(
return 0;
+#endif
/* check band count */
if (GDALGetRasterCount(ds) != i + 1) {
@@ -2025,6 +2028,8 @@ rt_raster_to_gdal_mem(
return 0;
/* PT_8BSI requires manual setting of pixels */
if (pt == PT_8BSI) {
uint32_t nXBlocks, nYBlocks;
@@ -2120,6 +2125,7 @@ rt_raster_to_gdal_mem(
rtdealloc(values);
+#endif
/* Add nodata value for band */
if (rt_band_get_hasnodata_flag(rtband) != FALSE && excludeNodataValues[i]) {
diff --git a/raster/rt_core/rt_util.c b/raster/rt_core/rt_util.c
index 9c6a14a9b..e3e1f5415 100644
--- a/raster/rt_core/rt_util.c
+++ b/raster/rt_core/rt_util.c
@@ -129,6 +129,9 @@ rt_util_pixtype_to_gdal_datatype(rt_pixtype pt) {
case PT_8BUI:
return GDT_Byte;
case PT_8BSI:
+#if POSTGIS_GDAL_VERSION >= 30700
+ return GDT_Int8;
+#endif
case PT_16BSI:
return GDT_Int16;
case PT_16BUI:
@@ -160,6 +163,10 @@ rt_util_gdal_datatype_to_pixtype(GDALDataType gdt) {
switch (gdt) {
case GDT_Byte:
return PT_8BUI;
+ case GDT_Int8:
+ return PT_8BSI;
+#endif
case GDT_UInt16:
return PT_16BUI;
case GDT_Int16:
diff --git a/raster/scripts/python/pixval.py b/raster/scripts/python/pixval.py
index 0477a5019..644e1aec6 100755
--- a/raster/scripts/python/pixval.py
+++ b/raster/scripts/python/pixval.py
@@ -31,6 +31,7 @@ import sys
def pt2fmt(pt):
fmttypes = {
gdalc.GDT_Byte: 'B',
+ gdalc.GDT_Int8: 'B',
gdalc.GDT_Int16: 'h',
gdalc.GDT_UInt16: 'H',
gdalc.GDT_Int32: 'i',
diff --git a/raster/scripts/python/raster2pgsql.py b/raster/scripts/python/raster2pgsql.py
index c76b1d7e2..c6401f925 100755
--- a/raster/scripts/python/raster2pgsql.py
+++ b/raster/scripts/python/raster2pgsql.py
@@ -214,6 +214,7 @@ def gdt2pt(gdt):
"""Translate GDAL data type to WKT Raster pixel type."""
pixtypes = {
gdalc.GDT_Byte : { 'name': 'PT_8BUI', 'id': 4 },
+ gdalc.GDT_Int8 : { 'name': 'PT_8BSI', 'id': 3 },
gdalc.GDT_Int16 : { 'name': 'PT_16BSI', 'id': 5 },
gdalc.GDT_UInt16 : { 'name': 'PT_16BUI', 'id': 6 },
gdalc.GDT_Int32 : { 'name': 'PT_32BSI', 'id': 7 },
diff --git a/raster/test/cunit/cu_gdal.c b/raster/test/cunit/cu_gdal.c
index d338dcf42..421bf93f3 100644
--- a/raster/test/cunit/cu_gdal.c
+++ b/raster/test/cunit/cu_gdal.c
@@ -384,7 +384,6 @@ static void test_gdal_to_raster() {
gdds = rt_raster_to_gdal_mem(raster, NULL, NULL, NULL, 0, &gddrv, &destroy);
CU_ASSERT(gddrv != NULL);
- CU_ASSERT_EQUAL(destroy, 0);
CU_ASSERT(gdds != NULL);
CU_ASSERT_EQUAL((uint32_t)GDALGetRasterXSize(gdds), width);
CU_ASSERT_EQUAL((uint32_t)GDALGetRasterYSize(gdds), height);
@@ -404,6 +403,10 @@ static void test_gdal_to_raster() {
+ if (destroy && gddrv) {
+ GDALDeregisterDriver(gddrv);
+ GDALDestroyDriver(gddrv);
GDALClose(gdds);
gdds = NULL;
gddrv = NULL;
@@ -430,7 +433,6 @@ static void test_gdal_to_raster() {
@@ -441,15 +443,27 @@ static void test_gdal_to_raster() {
band = rt_raster_get_band(rast, 0);
CU_ASSERT(band != NULL);
CU_ASSERT_EQUAL(rt_band_get_pixtype(band), PT_16BSI);
+#else
+ CU_ASSERT_EQUAL(rt_band_get_pixtype(band), PT_8BSI);
+#endif
for (x = 0; x < width; x++) {
for (y = 0; y < height; y++) {
rtn = rt_band_get_pixel(band, x, y, &value, NULL);
- CU_ASSERT_EQUAL(rtn, ES_NONE);
CU_ASSERT_DOUBLE_EQUAL(value, values[x][y], 1.);
+ CU_ASSERT_DOUBLE_EQUAL(value, values[x][y], DBL_EPSILON);
+#else
+ CU_ASSERT_EQUAL(rtn, ES_NONE);
+#endif
GDALClose(gdds);
gdds = NULL;
Summary of changes:
loader/cunit/Makefile.in | 2 +-
raster/rt_core/rt_raster.c | 12 +++++++++---
raster/rt_core/rt_util.c | 7 +++++++
raster/scripts/python/pixval.py | 1 +
raster/scripts/python/raster2pgsql.py | 1 +
raster/test/cunit/cu_gdal.c | 22 ++++++++++++++++++----
6 files changed, 37 insertions(+), 8 deletions(-)
hooks/post-receive
