[SCM] PostGIS branch master updated. 3.5.0-461-gf9406fae8
git at osgeo.org
git at osgeo.org
Tue Jul 15 02:47:44 PDT 2025
the project "PostGIS".
via f9406fae8081d2039a046e55b35db0f2eacb433d (commit)
from ff8eeb43b93dc7834a6618bdb231766cd6de1fa1 (commit)
revisions in full, below.
commit f9406fae8081d2039a046e55b35db0f2eacb433d
Author: Teramoto Ikuhiro <teramoto.ikuhiro576 at naro.go.jp>
Date: Tue Jul 15 08:18:35 2025 +0000
Translated PostGIS Manual using Weblate (Japanese)
Currently translated at 99.9% (5830 of 5833 strings)
Translation: postgis/PostGIS Manual
Translate-URL: https://weblate.osgeo.org/projects/postgis/postgis-manual/ja/
diff --git a/doc/po/ja/postgis-manual.po b/doc/po/ja/postgis-manual.po
index e67e4d040..6829c56ec 100644
--- a/doc/po/ja/postgis-manual.po
+++ b/doc/po/ja/postgis-manual.po
@@ -10,10 +10,10 @@ msgstr ""
"Project-Id-Version: postgis 3.5\n"
"Report-Msgid-Bugs-To: https://bugs.kde.org\n"
"POT-Creation-Date: 2025-05-18 00:48+0000\n"
-"PO-Revision-Date: 2025-07-14 10:47+0000\n"
+"PO-Revision-Date: 2025-07-15 09:47+0000\n"
"Last-Translator: Teramoto Ikuhiro <teramoto.ikuhiro576 at naro.go.jp>\n"
-"Language-Team: Japanese <https://weblate.osgeo.org/projects/postgis/postgis-"
-"manual/ja/>\n"
+"Language-Team: Japanese <https://weblate.osgeo.org/projects/postgis/"
+"postgis-manual/ja/>\n"
"Language: ja\n"
"MIME-Version: 1.0\n"
"Content-Type: text/plain; charset=UTF-8\n"
@@ -10187,7 +10187,7 @@ msgstr "Artur Zakirov"
#. Tag: member
#, no-c-format
msgid "Ayo Adesugba"
-msgstr ""
+msgstr "Ayo Adesugba"
#. Tag: member
#, no-c-format
@@ -10996,7 +10996,7 @@ msgstr "ラヴァル大学"
#. Tag: link
#, no-c-format
msgid "U.S. Census Bureau"
-msgstr ""
+msgstr "米国国勢調査局"
#. Tag: link
#, no-c-format
@@ -35754,15 +35754,17 @@ msgstr ""
"<xref linkend=\"RT_ST_Value\"/>"
#. Tag: refpurpose
-#, no-c-format
+#, fuzzy, no-c-format
msgid ""
"Creates a new raster composed of bands reclassified from original, using a "
"1:1 mapping from values in the original band to new values in the "
"destination band."
msgstr ""
+"元ラスターから再分類したバンドからなる新しいラスタを生成します。元ラスターの"
+"バンド内の値から生成されるラスターのバンド内の値に1:1マッピングを使います。"
#. Tag: para
-#, no-c-format
msgid ""
"Creates a new raster formed by applying a reclassification operation defined "
"by the <varname>inputvalues</varname> and <varname>outputvalues</varname> "
@@ -35770,6 +35772,10 @@ msgid ""
"corresponding value in the output array. All other pixel values are mapped "
"to the <varname>nodatavalue</varname>."
msgstr ""
+"<varname>inputvalues</varname>配列と<varname>outputvalues</varname>配列によっ"
+"て定義される再分類処理を適用することで形成される新しいラスタを生成します。入"
+"力配列のピクセル値は対応する出力配列の値にマップされます。"
+"他のピクセル値は全て <varname>nodatavalue</varname>にマップされます。"
#. Tag: para
#, no-c-format
@@ -35778,13 +35784,17 @@ msgid ""
"<varname>pixeltype</varname> parameter. If no <varname>bandnumber</varname> "
"is specified band 1 is assumed."
msgstr ""
+"出力ピクセルタイプのデフォルトは浮動小数点数ですが、 <varname>pixeltype</varn"
+"ame>パラメータで指定できます。<varname>bandnumber</varname>を指定しな場合には"
+"、1番を仮定します。"
#. Tag: para
#, no-c-format
msgid ""
"The new raster will have the same georeference, width, and height as the "
"original raster. Bands not designated are returned unchanged."
-msgstr ""
+msgstr "新しいラスターは元ラスターと同じジオリファレンス、同じ幅、同じ高さを持ちます"
+"。指定されていないバンドは変更されずに返ります。"
#. Tag: para
#, no-c-format
Summary of changes:
doc/po/ja/postgis-manual.po | 26 ++++++++++++++++++--------
1 file changed, 18 insertions(+), 8 deletions(-)
hooks/post-receive
