[PostGIS] #5943: Memory leak in handling GEOS GeometryFactory
trac at osgeo.org
Tue Jul 15 07:52:30 PDT 2025
Reporter: meganxma | Owner: pramsey
Type: defect | Status: new
Priority: low | Milestone: PostGIS 3.5.4
Component: postgis | Version: 3.5.x
Keywords: memory leak |
Running installcheck tests with ASAN showed that there are multiple memory
leaks in Postgis's handling of GEOS GeometryFactory.
I've created a patch file for the fixes:
{{{#!div style="font-size: 100%"
--- a/liblwgeom/lwgeom_geos.c 2025-01-07 10:09:06.000000000
+0000
+++ b/liblwgeom/lwgeom_geos.c 2025-01-07 10:07:11.000000000
+0000
@@ -723,7 +723,7 @@
g3 = GEOSIntersection(g1, g2);
- if (!g3) GEOS_FREE_AND_FAIL(g1);
+ if (!g3) GEOS_FREE_AND_FAIL(g1, g2);
GEOSSetSRID(g3, srid);
if (!(result = GEOS2LWGEOM(g3, is3d)))
GEOS_FREE_AND_FAIL(g1, g2, g3);
@@ -1145,7 +1145,7 @@
/* If no geometries are in result collection, return NULL
if (GEOSGetNumGeometries(g3) == 0)
- GEOS_FREE(g1);
+ GEOS_FREE(g1, g3);
return NULL;
--- a/postgis/lwgeom_geos_predicates.c 2025-07-10
19:51:54.478513150 +0000
+++ b/postgis/lwgeom_geos_predicates.c 2025-07-10
19:51:41.568325255 +0000
@@ -978,7 +978,11 @@
POSTGIS_DEBUGF(3, "%s", GEOSGeomToWKT(g2));
relate_str = GEOSRelateBoundaryNodeRule(g1, g2, bnr);
- if (!relate_str) HANDLE_GEOS_ERROR("GEOSRelate");
+ if (!relate_str) {
+ GEOSGeom_destroy(g1);
+ GEOSGeom_destroy(g2);
+ HANDLE_GEOS_ERROR("GEOSRelate");
result = cstring_to_text(relate_str);
GEOSFree(relate_str);
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5943>
