[SCM] PostGIS branch master updated. 3.5.0-464-g45dd05348
Tue Jul 15 09:44:14 PDT 2025
the project "PostGIS".
       via  45dd053484484d914737e7649ffe10a2d50e5903 (commit)
      from  70c1d92368411ba51e87f6df0444817619742e82 (commit)
revisions in full, below.
commit 45dd053484484d914737e7649ffe10a2d50e5903
Author: Weblate <noreply at weblate.org>
Date:   Tue Jul 15 16:37:53 2025 +0000
    Update translation files
    Updated by "Update PO files to match POT (msgmerge)" hook in Weblate.
    Translation: postgis/PostGIS Manual
    Translate-URL: https://weblate.osgeo.org/projects/postgis/postgis-manual/
diff --git a/doc/po/da/postgis-manual.po b/doc/po/da/postgis-manual.po
index 2d7c26793..9f61235b2 100644
--- a/doc/po/da/postgis-manual.po
+++ b/doc/po/da/postgis-manual.po
@@ -4078,6 +4078,28 @@ msgid ""
 "tables, including indexes and TOAST data."
 msgstr ""
+#. Tag: refpurpose
+#, no-c-format
+msgid ""
+"Upgrades the specified topology to support large ids (int8) for topology and "
+"primitive ids."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Takes a topology name and upgrades it to support large ids (int8) for "
+"topology and primitive ids. The function upgrades the following: - face "
+"(face_id column from int4 to int8, face_id_seq from int4 to int8) - node "
+"(node_id column from int4 to int8, containing_face column from int4 to int8, "
+"node_id_seq from int4 to int8) - edge_data (edge_id column from int4 to "
+"int8, edge_data_edge_id_seq from int4 to int8, left_face and right_face "
+"columns from int4 to int8, start_node and end_node columns from int4 to "
+"int8, next_left_edge and next_right_edge columns from int4 to int8) - "
+"relation (topogeo_id column from int4 to int8, element_id from int4 to int8) "
+"- topology (useslargeids column set to true)"
+msgstr ""
 #. Tag: title
 #, no-c-format
 msgid "Topology Statistics Management"
@@ -4148,7 +4170,8 @@ msgstr ""
 #, no-c-format
 msgid ""
 "The <varname>srid</varname> is the <link linkend=\"spatial_ref_sys\">spatial "
-"reference system</link> SRID for the topology."
+"reference system</link> SRID for the topology. The SRID defaults to -1 "
+"(unknown) if not specified."
 msgstr ""
 #. Tag: para
@@ -4163,6 +4186,21 @@ msgstr ""
 msgid "<varname>hasz</varname> defaults to false if not specified."
 msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<varname>topoid</varname> optional explicit identifier (allows deterministic "
+"topology id assignment, needs to be unique)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<varname>useslargeids</varname> optional, defaults to false. If true, the "
+"topology will be created to support large ids (int8) for topology and "
+"primitive ids."
+msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -35137,12 +35175,12 @@ msgstr ""
 #. Tag: title
 #, no-c-format
-msgid "PostGIS 3.6.0alpha1"
+msgid "PostGIS 3.6.0beta1"
 msgstr ""
 #. Tag: para
 #, no-c-format
-msgid "2025/05/17"
+msgid "2025/07/xx"
 msgstr ""
 #. Tag: para
@@ -35153,6 +35191,26 @@ msgid ""
 "advantage of all SFCGAL features, SFCGAL 2.1+ is needed."
 msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "Many thanks to our translation teams, in particular:"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "Teramoto Ikuhiro (Japanese Team)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "Daniel Nylander (Swedish Team)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "Dapeng Wang, Zuo Chenwei from HighGo (Chinese Team)"
+msgstr ""
 #. Tag: title
 #, no-c-format
 msgid "Breaking Changes"
@@ -35173,6 +35231,33 @@ msgid ""
 "link>, remove constraint checking from geometry_columns view (Paul Ramsey)"
 msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<link xlink:href=\"https://trac.osgeo.org/postgis/ticket/3373\">#3373</"
+"link>, <link xlink:href=\"https://git.osgeo.org/gitea/postgis/postgis/"
+"pulls/255\">GT-255</link> [topology] Support for upgrading domains (Ayo "
+"Adesugba, U.S. Census Bureau)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<link xlink:href=\"https://git.osgeo.org/gitea/postgis/postgis/"
+"pulls/252\">GT-252</link>, ST_NumGeometries/ST_GeometryN treat TIN and "
+"PolyhedralSurface as unitary geometries, use ST_NumPatches/ST_PatchN for "
+"patch access (Loïc Bartoletti)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<link xlink:href=\"https://trac.osgeo.org/postgis/ticket/3110\">#3110</"
+"pulls/242\">GT-242</link> [topology] Support for bigint (Ayo Adesugba, U.S. "
+"Census Bureau)"
+msgstr ""
 #. Tag: title
 #, no-c-format
 msgid "New Features"
@@ -35233,8 +35318,9 @@ msgstr ""
 #, no-c-format
 msgid ""
 "<link xlink:href=\"https://trac.osgeo.org/postgis/ticket/5784\">#5784</"
-"link>, GT-223 Export circ_tree_distance_tree_internal for mobilitydb use "
-"(Maxime Schoemans)"
+"pulls/223\">GT-223</link> Export circ_tree_distance_tree_internal for "
+"mobilitydb use (Maxime Schoemans)"
 msgstr ""
 #. Tag: para
@@ -35261,6 +35347,18 @@ msgid ""
 "(Paul Ramsey)"
 msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Add ST_CoverageClean to edge match and gap remove polygonal coverages (Paul "
+"Ramsey) from GEOS 3.14 (Martin Davis)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "Add ST_ReclassExact to quickly remap values in raster (Paul Ramsey)"
+msgstr ""
 #. Tag: title
 #, no-c-format
 msgid "Reporting Problems"
diff --git a/doc/po/de/postgis-manual.po b/doc/po/de/postgis-manual.po
index 72cacbbfe..5727b6263 100644
--- a/doc/po/de/postgis-manual.po
+++ b/doc/po/de/postgis-manual.po
@@ -5457,6 +5457,28 @@ msgid ""
 msgstr ""
+#. Tag: refpurpose
+#, no-c-format
+msgid ""
+"primitive ids."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+msgstr ""
 #. Tag: title
 #, fuzzy, no-c-format
@@ -5546,13 +5568,12 @@ msgstr ""
 "gibt die ID der Topologie zurück."
 #. Tag: para
-#, fuzzy, no-c-format
+#, no-c-format
 msgid ""
 msgstr ""
-"Das <varname>srid</varname> ist das <link "
-"linkend=\"spatial_ref_sys\">Raumbezugssystem</link> SRID für die Topologie."
 #. Tag: para
@@ -5568,6 +5589,21 @@ msgstr ""
 msgstr "<varname>hasz</varname> ist standardmäßig false, wenn nicht angegeben."
+#. Tag: para
+#, no-c-format
+msgid ""
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"primitive ids."
+msgstr ""
 #. Tag: para
 msgid ""
@@ -45875,12 +45911,12 @@ msgstr "Anmerkungen zur Release"
 #. Tag: title
 #, no-c-format
 msgstr ""
 #. Tag: para
 #, no-c-format
-msgid "2025/05/17"
+msgid "2025/07/xx"
 msgstr ""
 #. Tag: para
@@ -45891,6 +45927,26 @@ msgid ""
 msgstr ""
+#. Tag: para
+#, fuzzy, no-c-format
+msgstr "Vielen Dank insbesondere an unsere Übersetzungsteams:"
+#. Tag: para
+msgstr "Teramoto Ikuhiro (Japanische Mannschaft)"
+#. Tag: para
+#, no-c-format
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgstr ""
 #. Tag: title
@@ -45911,6 +45967,33 @@ msgid ""
 msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Census Bureau)"
+msgstr ""
 #. Tag: title
 #, no-c-format
@@ -45971,8 +46054,9 @@ msgstr ""
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
@@ -45999,6 +46083,18 @@ msgid ""
 "(Paul Ramsey)"
 msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgstr ""
 #. Tag: title
 #, no-c-format
@@ -52512,6 +52608,16 @@ msgstr "2.5/3D-Unterstützung"
 msgid "Supports geography"
 msgstr "Unterstützt Geographie"
+#~ msgid ""
+#~ "The <varname>srid</varname> is the <link "
+#~ "linkend=\"spatial_ref_sys\">spatial reference system</link> SRID for the "
+#~ "topology."
+#~ msgstr ""
+#~ "Das <varname>srid</varname> ist das <link "
+#~ "linkend=\"spatial_ref_sys\">Raumbezugssystem</link> SRID für die "
+#~ "Topologie."
 #~ msgid ""
 #~ ", <xref linkend=\"ST_CoverageUnion\"/>, <xref "
@@ -52949,14 +53055,6 @@ msgstr "Unterstützt Geographie"
 #~ "<link xlink:href=\"http://blog.opengeo.org/2012/07/12/making-geography-"
 #~ "faster/\">Geografie schneller machen</link> für Details."
-#~ msgid "Many thanks to our translation teams, in particular:"
-#~ msgstr "Vielen Dank insbesondere an unsere Übersetzungsteams:"
-#~ msgid "Teramoto Ikuhiro (Japanese Team)"
-#~ msgstr "Teramoto Ikuhiro (Japanische Mannschaft)"
 #~ msgid "Vincent Bre (French Team)"
 #~ msgstr "Vincent Bre (Französische Mannschaft)"
diff --git a/doc/po/es/postgis-manual.po b/doc/po/es/postgis-manual.po
index 5137c8af8..efa67f8bb 100644
--- a/doc/po/es/postgis-manual.po
+++ b/doc/po/es/postgis-manual.po
@@ -4410,6 +4410,28 @@ msgid ""
 msgstr ""
+#. Tag: refpurpose
+#, no-c-format
+msgid ""
+"primitive ids."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+msgstr ""
 #. Tag: title
 #, no-c-format
@@ -4481,7 +4503,8 @@ msgstr ""
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
@@ -4496,6 +4519,21 @@ msgstr ""
 msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"primitive ids."
+msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -37276,12 +37314,12 @@ msgstr "Notas de la versión"
 #. Tag: title
 #, no-c-format
 msgstr ""
 #. Tag: para
 #, no-c-format
-msgid "2025/05/17"
+msgid "2025/07/xx"
 msgstr ""
 #. Tag: para
@@ -37292,6 +37330,26 @@ msgid ""
 msgstr ""
+#. Tag: para
+#, no-c-format
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgstr ""
 #. Tag: title
 #, no-c-format
@@ -37312,6 +37370,33 @@ msgid ""
 msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Census Bureau)"
+msgstr ""
 #. Tag: title
 #, no-c-format
@@ -37372,8 +37457,9 @@ msgstr ""
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
@@ -37400,6 +37486,18 @@ msgid ""
 "(Paul Ramsey)"
 msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgstr ""
 #. Tag: title
 #, no-c-format
diff --git a/doc/po/fr/postgis-manual.po b/doc/po/fr/postgis-manual.po
index 72dc7c1a5..d726b242e 100644
--- a/doc/po/fr/postgis-manual.po
+++ b/doc/po/fr/postgis-manual.po
@@ -5440,6 +5440,28 @@ msgid ""
 msgstr ""
+#. Tag: refpurpose
+#, no-c-format
+msgid ""
+"primitive ids."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+msgstr ""
 #. Tag: title
 #, no-c-format
@@ -5535,10 +5557,9 @@ msgstr ""
 #, no-c-format
 msgid ""
 msgstr ""
-"Le <varname>srid</varname> est le <link linkend=\"spatial_ref_sys\">système "
-"de référence spatiale</link> SRID pour la topologie."
 #. Tag: para
 #, no-c-format
@@ -5556,6 +5577,21 @@ msgstr ""
 "<varname>hasz</varname> La valeur par défaut est false si elle n'est pas "
 "spécifiée."
+#. Tag: para
+#, no-c-format
+msgid ""
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"primitive ids."
+msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -45863,12 +45899,12 @@ msgstr "Notes de version"
 #. Tag: title
 #, no-c-format
 msgstr ""
 #. Tag: para
 #, no-c-format
-msgid "2025/05/17"
+msgid "2025/07/xx"
 msgstr ""
 #. Tag: para
@@ -45879,6 +45915,26 @@ msgid ""
 msgstr ""
+#. Tag: para
+#, no-c-format
+msgstr "Un grand merci à nos équipes de traduction, en particulier :"
+#. Tag: para
+#, no-c-format
+msgstr "Teramoto Ikuhiro (Japanese Team)"
+#. Tag: para
+#, no-c-format
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgstr ""
 #. Tag: title
 #, no-c-format
@@ -45899,6 +45955,33 @@ msgid ""
 msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Census Bureau)"
+msgstr ""
 #. Tag: title
 #, no-c-format
@@ -45959,8 +46042,9 @@ msgstr ""
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
@@ -45987,6 +46071,18 @@ msgid ""
 "(Paul Ramsey)"
 msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgstr ""
 #. Tag: title
 #, no-c-format
@@ -52526,6 +52622,16 @@ msgstr "Support 2.5/3D"
 msgstr "Prise en charge du type geography"
+#, no-c-format
+#~ msgid ""
+#~ "topology."
+#~ msgstr ""
+#~ "Le <varname>srid</varname> est le <link "
+#~ "linkend=\"spatial_ref_sys\">système de référence spatiale</link> SRID "
+#~ "pour la topologie."
 #, no-c-format
 #~ msgid ""
@@ -52995,14 +53101,6 @@ msgstr "Prise en charge du type geography"
 #~ "Voir <link xlink:href=\"http://blog.opengeo.org/2012/07/12/making-"
 #~ "geography-faster/\">Making Geography faster</link> pour plus de détails."
-#, no-c-format
-#~ msgstr "Un grand merci à nos équipes de traduction, en particulier :"
-#, no-c-format
-#~ msgstr "Teramoto Ikuhiro (Japanese Team)"
 #, no-c-format
 #~ msgstr "Vincent Bre (French Team)"
diff --git a/doc/po/it_IT/postgis-manual.po b/doc/po/it_IT/postgis-manual.po
index 82bfcd905..a8b1732a0 100644
--- a/doc/po/it_IT/postgis-manual.po
+++ b/doc/po/it_IT/postgis-manual.po
@@ -4717,6 +4717,28 @@ msgid ""
 msgstr ""
+#. Tag: refpurpose
+#, no-c-format
+msgid ""
+"primitive ids."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+msgstr ""
 #. Tag: title
 #, no-c-format
@@ -4787,7 +4809,8 @@ msgstr ""
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
@@ -4802,6 +4825,21 @@ msgstr ""
 msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"primitive ids."
+msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -37835,12 +37873,12 @@ msgstr ""
 #. Tag: title
 #, no-c-format
 msgstr ""
 #. Tag: para
 #, no-c-format
-msgid "2025/05/17"
+msgid "2025/07/xx"
 msgstr ""
 #. Tag: para
@@ -37851,6 +37889,26 @@ msgid ""
 msgstr ""
+#. Tag: para
+#, no-c-format
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgstr ""
 #. Tag: title
 #, no-c-format
@@ -37871,6 +37929,33 @@ msgid ""
 msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Census Bureau)"
+msgstr ""
 #. Tag: title
 #, no-c-format
@@ -37931,8 +38016,9 @@ msgstr ""
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
@@ -37959,6 +38045,18 @@ msgid ""
 "(Paul Ramsey)"
 msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgstr ""
 #. Tag: title
 #, no-c-format
diff --git a/doc/po/ja/postgis-manual.po b/doc/po/ja/postgis-manual.po
index 6829c56ec..b6d00f05e 100644
--- a/doc/po/ja/postgis-manual.po
+++ b/doc/po/ja/postgis-manual.po
@@ -12,8 +12,8 @@ msgstr ""
 "POT-Creation-Date: 2025-05-18 00:48+0000\n"
 "PO-Revision-Date: 2025-07-15 09:47+0000\n"
 "Last-Translator: Teramoto Ikuhiro <teramoto.ikuhiro576 at naro.go.jp>\n"
-"Language-Team: Japanese <https://weblate.osgeo.org/projects/postgis/"
-"postgis-manual/ja/>\n"
+"Language-Team: Japanese <https://weblate.osgeo.org/projects/postgis/postgis-"
+"manual/ja/>\n"
 "Language: ja\n"
 "MIME-Version: 1.0\n"
 "Content-Type: text/plain; charset=UTF-8\n"
@@ -5176,6 +5176,28 @@ msgstr ""
 "トポロジ名から、そのトポロジのすべてのテーブルのディスク容量の総量を返しま"
 "す。インデックスとTOASTデータも含みます。"
+#. Tag: refpurpose
+#, no-c-format
+msgid ""
+"primitive ids."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+msgstr ""
 #. Tag: title
 #, no-c-format
@@ -5262,10 +5284,9 @@ msgstr ""
 #, no-c-format
 msgid ""
 msgstr ""
-"<varname>srid</varname>は、このトポロジの<link linkend=\"spatial_ref_sys\">空"
-"間参照系</link>のSRIDです。"
 #. Tag: para
 #, no-c-format
@@ -5281,6 +5302,21 @@ msgstr ""
 msgstr "<varname>hasz</varname>を指定しない場合のデフォルトはFALSEです。"
+#. Tag: para
+#, no-c-format
+msgid ""
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"primitive ids."
+msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -35774,8 +35810,8 @@ msgid ""
 msgstr ""
 "<varname>inputvalues</varname>配列と<varname>outputvalues</varname>配列によっ"
 "て定義される再分類処理を適用することで形成される新しいラスタを生成します。入"
-"力配列のピクセル値は対応する出力配列の値にマップされます。"
-"他のピクセル値は全て <varname>nodatavalue</varname>にマップされます。"
+"力配列のピクセル値は対応する出力配列の値にマップされます。他のピクセル値は全"
+"て <varname>nodatavalue</varname>にマップされます。"
 #. Tag: para
 #, no-c-format
@@ -35784,17 +35820,18 @@ msgid ""
 "<varname>pixeltype</varname> parameter. If no <varname>bandnumber</varname> "
 "is specified band 1 is assumed."
 msgstr ""
-"出力ピクセルタイプのデフォルトは浮動小数点数ですが、 <varname>pixeltype</varn"
-"ame>パラメータで指定できます。<varname>bandnumber</varname>を指定しな場合には"
-"、1番を仮定します。"
+"出力ピクセルタイプのデフォルトは浮動小数点数ですが、 <varname>pixeltype</"
+"varname>パラメータで指定できます。<varname>bandnumber</varname>を指定しな場合"
+"には、1番を仮定します。"
 #. Tag: para
 #, no-c-format
 msgid ""
 "The new raster will have the same georeference, width, and height as the "
 "original raster. Bands not designated are returned unchanged."
-msgstr "新しいラスターは元ラスターと同じジオリファレンス、同じ幅、同じ高さを持ちます"
-"。指定されていないバンドは変更されずに返ります。"
+msgstr ""
+"新しいラスターは元ラスターと同じジオリファレンス、同じ幅、同じ高さを持ちま"
+"す。指定されていないバンドは変更されずに返ります。"
 #. Tag: para
 #, no-c-format
@@ -43674,13 +43711,13 @@ msgstr "リリースノート"
 #. Tag: title
 #, no-c-format
-msgstr "PostGIS 3.6.0alpha1"
+msgstr ""
 #. Tag: para
 #, no-c-format
-msgid "2025/05/17"
-msgstr "2025/05/17"
+msgid "2025/07/xx"
+msgstr ""
 #. Tag: para
 #, no-c-format
@@ -43693,6 +43730,26 @@ msgstr ""
 "全ての機能を利用するには、GEOS 3.12以上が必要です。全てのSFCGAL機能を利用する"
 "には、SFCGAL 2.1以上が必要です。"
+#. Tag: para
+#, no-c-format
+msgstr "翻訳チームに感謝します、特に次の方々です:"
+#. Tag: para
+#, no-c-format
+msgstr "Teramoto Ikuhiroさん (日本語チーム)"
+#. Tag: para
+#, no-c-format
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgstr "HighGoのDapeng Wangさん、Zuo Chenweiさん (中国語チーム)"
 #. Tag: title
 #, no-c-format
@@ -43719,6 +43776,33 @@ msgstr ""
 "link>, geometry_columnsビューから制約条件チェックを外しました (Paul Ramseyさ"
 "ん)"
+#. Tag: para
+#, no-c-format
+msgid ""
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Census Bureau)"
+msgstr ""
 #. Tag: title
 #, no-c-format
@@ -43796,12 +43880,10 @@ msgstr ""
 #, no-c-format
 msgid ""
 msgstr ""
-"<link xlink:href=\"https://trac.osgeo.org/postgis/ticket/5784\">#5784</"
-"link>, GT-223 MobilityDB利用のためのcirc_tree_distance_tree_internalのエクス"
-"ポート (Maxime Schoemansさん)"
 #. Tag: para
 #, no-c-format
@@ -43835,6 +43917,18 @@ msgstr ""
 "PostgreSQL 18対応のため、割込処理でpqsignalの利用を削除するように変更しまし"
 "た (Paul Ramseyさん)"
+#. Tag: para
+#, no-c-format
+msgid ""
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgstr ""
 #. Tag: title
 #, no-c-format
@@ -49939,6 +50033,33 @@ msgstr "2.5次元/3次元対応"
 msgstr "ジオグラフィ対応"
+#, no-c-format
+#~ msgid ""
+#~ "topology."
+#~ msgstr ""
+#~ "<varname>srid</varname>は、このトポロジの<link "
+#~ "linkend=\"spatial_ref_sys\">空間参照系</link>のSRIDです。"
+#, no-c-format
+#~ msgid "PostGIS 3.6.0alpha1"
+#~ msgstr "PostGIS 3.6.0alpha1"
+#, no-c-format
+#~ msgid "2025/05/17"
+#~ msgstr "2025/05/17"
+#, no-c-format
+#~ msgid ""
+#~ "<link xlink:href=\"https://trac.osgeo.org/postgis/ticket/5784\">#5784</"
+#~ "link>, GT-223 Export circ_tree_distance_tree_internal for mobilitydb use "
+#~ "(Maxime Schoemans)"
+#~ msgstr ""
+#~ "link>, GT-223 MobilityDB利用のためのcirc_tree_distance_tree_internalのエク"
+#~ "スポート (Maxime Schoemansさん)"
 #, no-c-format
 #~ msgid ""
@@ -50413,18 +50534,6 @@ msgstr "ジオグラフィ対応"
 #~ "全ての機能を利用するにはGEOS 3.12以上が必要です。全てのSFCGAL機能を使用す"
 #~ "るにはSFCGAL 1.5.0以上が必要です。"
-#, no-c-format
-#~ msgstr "翻訳チームに感謝します、特に次の方々です:"
-#, no-c-format
-#~ msgid "Dapeng Wang, Zuo Chenwei from HighGo (Chinese Team)"
-#~ msgstr "HighGoのDapeng Wangさん、Zuo Chenweiさん (中国語チーム)"
-#, no-c-format
-#~ msgstr "Teramoto Ikuhiroさん (日本語チーム)"
 #, no-c-format
 #~ msgstr "Vincent Breさん (フランス語チーム)"
diff --git a/doc/po/ka/postgis-manual.po b/doc/po/ka/postgis-manual.po
index b78fd2da8..c1bd48685 100644
--- a/doc/po/ka/postgis-manual.po
+++ b/doc/po/ka/postgis-manual.po
@@ -4061,6 +4061,28 @@ msgid ""
 msgstr ""
+#. Tag: refpurpose
+#, no-c-format
+msgid ""
+"primitive ids."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+msgstr ""
 #. Tag: title
 #, no-c-format
@@ -4131,7 +4153,8 @@ msgstr ""
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
@@ -4146,6 +4169,21 @@ msgstr ""
 msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"primitive ids."
+msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -35120,12 +35158,12 @@ msgstr "გამოცემის შენიშვნები"
 #. Tag: title
 #, no-c-format
 msgstr ""
 #. Tag: para
 #, no-c-format
-msgid "2025/05/17"
+msgid "2025/07/xx"
 msgstr ""
 #. Tag: para
@@ -35136,6 +35174,26 @@ msgid ""
 msgstr ""
+#. Tag: para
+#, no-c-format
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgstr ""
 #. Tag: title
 #, no-c-format
@@ -35156,6 +35214,33 @@ msgid ""
 msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Census Bureau)"
+msgstr ""
 #. Tag: title
 #, no-c-format
@@ -35216,8 +35301,9 @@ msgstr ""
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
@@ -35244,6 +35330,18 @@ msgid ""
 "(Paul Ramsey)"
 msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgstr ""
 #. Tag: title
 #, no-c-format
diff --git a/doc/po/ko_KR/postgis-manual.po b/doc/po/ko_KR/postgis-manual.po
index 2746f3755..2e67392b5 100644
--- a/doc/po/ko_KR/postgis-manual.po
+++ b/doc/po/ko_KR/postgis-manual.po
@@ -4828,6 +4828,28 @@ msgid ""
 msgstr ""
+#. Tag: refpurpose
+#, no-c-format
+msgid ""
+"primitive ids."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+msgstr ""
 #. Tag: title
 #, no-c-format
@@ -4898,7 +4920,8 @@ msgstr ""
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
@@ -4913,6 +4936,21 @@ msgstr ""
 msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"primitive ids."
+msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -39614,12 +39652,12 @@ msgstr ""
 #. Tag: title
 #, no-c-format
 msgstr ""
 #. Tag: para
 #, no-c-format
-msgid "2025/05/17"
+msgid "2025/07/xx"
 msgstr ""
 #. Tag: para
@@ -39630,6 +39668,26 @@ msgid ""
 msgstr ""
+#. Tag: para
+#, no-c-format
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgstr ""
 #. Tag: title
 #, no-c-format
@@ -39650,6 +39708,33 @@ msgid ""
 msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Census Bureau)"
+msgstr ""
 #. Tag: title
 #, no-c-format
@@ -39710,8 +39795,9 @@ msgstr ""
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
@@ -39738,6 +39824,18 @@ msgid ""
 "(Paul Ramsey)"
 msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgstr ""
 #. Tag: title
 #, no-c-format
diff --git a/doc/po/pl/postgis-manual.po b/doc/po/pl/postgis-manual.po
index 5bfc6de43..9f356165e 100644
--- a/doc/po/pl/postgis-manual.po
+++ b/doc/po/pl/postgis-manual.po
@@ -4070,6 +4070,28 @@ msgid ""
 msgstr ""
+#. Tag: refpurpose
+#, no-c-format
+msgid ""
+"primitive ids."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+msgstr ""
 #. Tag: title
 #, no-c-format
@@ -4140,7 +4162,8 @@ msgstr ""
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
@@ -4155,6 +4178,21 @@ msgstr ""
 msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"primitive ids."
+msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -35314,12 +35352,12 @@ msgstr ""
 #. Tag: title
 #, no-c-format
 msgstr ""
 #. Tag: para
 #, no-c-format
-msgid "2025/05/17"
+msgid "2025/07/xx"
 msgstr ""
 #. Tag: para
@@ -35330,6 +35368,26 @@ msgid ""
 msgstr ""
+#. Tag: para
+#, no-c-format
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgstr ""
 #. Tag: title
 #, no-c-format
@@ -35350,6 +35408,33 @@ msgid ""
 msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Census Bureau)"
+msgstr ""
 #. Tag: title
 #, no-c-format
@@ -35410,8 +35495,9 @@ msgstr ""
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
@@ -35438,6 +35524,18 @@ msgid ""
 "(Paul Ramsey)"
 msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgstr ""
 #. Tag: title
 #, no-c-format
diff --git a/doc/po/pt_BR/postgis-manual.po b/doc/po/pt_BR/postgis-manual.po
index ba2e2118e..d97726517 100644
--- a/doc/po/pt_BR/postgis-manual.po
+++ b/doc/po/pt_BR/postgis-manual.po
@@ -4875,6 +4875,28 @@ msgid ""
 msgstr ""
+#. Tag: refpurpose
+#, no-c-format
+msgid ""
+"primitive ids."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+msgstr ""
 #. Tag: title
 #, no-c-format
@@ -4945,7 +4967,8 @@ msgstr ""
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
@@ -4960,6 +4983,21 @@ msgstr ""
 msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"primitive ids."
+msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -40028,12 +40066,12 @@ msgstr "Notas de Lançamento"
 #. Tag: title
 #, no-c-format
 msgstr ""
 #. Tag: para
 #, no-c-format
-msgid "2025/05/17"
+msgid "2025/07/xx"
 msgstr ""
 #. Tag: para
@@ -40044,6 +40082,26 @@ msgid ""
 msgstr ""
+#. Tag: para
+#, no-c-format
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgstr ""
 #. Tag: title
 #, no-c-format
@@ -40064,6 +40122,33 @@ msgid ""
 msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Census Bureau)"
+msgstr ""
 #. Tag: title
 #, no-c-format
@@ -40124,8 +40209,9 @@ msgstr ""
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
@@ -40152,6 +40238,18 @@ msgid ""
 "(Paul Ramsey)"
 msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgstr ""
 #. Tag: title
 #, no-c-format
diff --git a/doc/po/ro/postgis-manual.po b/doc/po/ro/postgis-manual.po
index 350b1114c..302c5bdd0 100644
--- a/doc/po/ro/postgis-manual.po
+++ b/doc/po/ro/postgis-manual.po
@@ -4096,6 +4096,28 @@ msgid ""
 msgstr ""
+#. Tag: refpurpose
+#, no-c-format
+msgid ""
+"primitive ids."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+msgstr ""
 #. Tag: title
 #, no-c-format
@@ -4166,7 +4188,8 @@ msgstr ""
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
@@ -4181,6 +4204,21 @@ msgstr ""
 msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"primitive ids."
+msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -35155,12 +35193,12 @@ msgstr ""
 #. Tag: title
 #, no-c-format
 msgstr ""
 #. Tag: para
 #, no-c-format
-msgid "2025/05/17"
+msgid "2025/07/xx"
 msgstr ""
 #. Tag: para
@@ -35171,6 +35209,26 @@ msgid ""
 msgstr ""
+#. Tag: para
+#, no-c-format
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgstr ""
 #. Tag: title
 #, no-c-format
@@ -35191,6 +35249,33 @@ msgid ""
 msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Census Bureau)"
+msgstr ""
 #. Tag: title
 #, no-c-format
@@ -35251,8 +35336,9 @@ msgstr ""
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
@@ -35279,6 +35365,18 @@ msgid ""
 "(Paul Ramsey)"
 msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgstr ""
 #. Tag: title
 #, no-c-format
diff --git a/doc/po/ru/postgis-manual.po b/doc/po/ru/postgis-manual.po
index 9772e1206..81663ca8d 100644
--- a/doc/po/ru/postgis-manual.po
+++ b/doc/po/ru/postgis-manual.po
@@ -4092,6 +4092,28 @@ msgid ""
 msgstr ""
+#. Tag: refpurpose
+#, no-c-format
+msgid ""
+"primitive ids."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+msgstr ""
 #. Tag: title
 #, no-c-format
@@ -4162,7 +4184,8 @@ msgstr ""
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
@@ -4177,6 +4200,21 @@ msgstr ""
 msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"primitive ids."
+msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -35172,12 +35210,12 @@ msgstr "Замечания к версии"
 #. Tag: title
 #, no-c-format
 msgstr ""
 #. Tag: para
 #, no-c-format
-msgid "2025/05/17"
+msgid "2025/07/xx"
 msgstr ""
 #. Tag: para
@@ -35188,6 +35226,26 @@ msgid ""
 msgstr ""
+#. Tag: para
+#, no-c-format
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgstr ""
 #. Tag: title
 #, no-c-format
@@ -35208,6 +35266,33 @@ msgid ""
 msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Census Bureau)"
+msgstr ""
 #. Tag: title
 #, no-c-format
@@ -35268,8 +35353,9 @@ msgstr ""
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
@@ -35296,6 +35382,18 @@ msgid ""
 "(Paul Ramsey)"
 msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgstr ""
 #. Tag: title
 #, no-c-format
diff --git a/doc/po/sv/postgis-manual.po b/doc/po/sv/postgis-manual.po
index 6e6ab59bc..8bd3ba666 100644
--- a/doc/po/sv/postgis-manual.po
+++ b/doc/po/sv/postgis-manual.po
@@ -7,8 +7,8 @@ msgstr ""
 "PO-Revision-Date: 2025-07-15 07:47+0000\n"
 "Last-Translator: Daniel Nylander <daniel at danielnylander.se>\n"
-"Language-Team: Swedish <https://weblate.osgeo.org/projects/postgis/"
-"postgis-manual/sv/>\n"
+"Language-Team: Swedish <https://weblate.osgeo.org/projects/postgis/postgis-"
+"manual/sv/>\n"
 "Language: sv\n"
@@ -5293,6 +5293,28 @@ msgstr ""
 "Tar ett topologinamn och ger det totala diskutrymmet som används av alla "
 "dess tabeller, inklusive index och TOAST-data."
+#. Tag: refpurpose
+#, no-c-format
+msgid ""
+"primitive ids."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+msgstr ""
 #. Tag: title
 #, no-c-format
@@ -5386,10 +5408,9 @@ msgstr ""
 #, no-c-format
 msgid ""
 msgstr ""
-"<varname>Srid</varname> är det <link linkend=\"spatial_ref_sys\">spatiala "
-"referenssystemets</link> SRID för topologin."
 #. Tag: para
 #, no-c-format
@@ -5405,6 +5426,21 @@ msgstr ""
 msgstr "<varname>hasz</varname> är som standard false om det inte anges."
+#. Tag: para
+#, no-c-format
+msgid ""
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"primitive ids."
+msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -44909,13 +44945,13 @@ msgstr "Anteckningar för release"
 #. Tag: title
 #, no-c-format
+msgstr ""
 #. Tag: para
 #, no-c-format
-msgid "2025/05/17"
+msgid "2025/07/xx"
+msgstr ""
 #. Tag: para
 #, no-c-format
@@ -44928,6 +44964,26 @@ msgstr ""
 "6.1+. För att dra nytta av alla funktioner behövs GEOS 3.12+. För att dra "
 "nytta av alla SFCGAL-funktioner behövs SFCGAL 2.1+."
+#. Tag: para
+#, no-c-format
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgstr ""
 #. Tag: title
 #, no-c-format
@@ -44953,6 +45009,33 @@ msgstr ""
 "<link xlink:href=\"https://trac.osgeo.org/postgis/ticket/5829\">#5829</"
 "link>, ta bort begränsningskontroll från geometry_columns-vyn (Paul Ramsey)"
+#. Tag: para
+#, no-c-format
+msgid ""
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Census Bureau)"
+msgstr ""
 #. Tag: title
 #, no-c-format
@@ -45029,12 +45112,10 @@ msgstr ""
 #, no-c-format
 msgid ""
 msgstr ""
-"link>, GT-223 Exportera circ_tree_distance_tree_internal för användning i "
-"mobilitydb (Maxime Schoemans)"
 #. Tag: para
 #, no-c-format
@@ -45070,6 +45151,18 @@ msgstr ""
 "link>, Ändra avbrottshantering för att ta bort användningen av pqsignal för "
 "att stödja PG 18 (Paul Ramsey)"
+#. Tag: para
+#, no-c-format
+msgid ""
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgstr ""
 #. Tag: title
 #, no-c-format
@@ -51375,6 +51468,33 @@ msgstr "2.5/3D-stöd"
 msgstr "Stödjer geografi"
+#, no-c-format
+#~ msgid ""
+#~ "topology."
+#~ msgstr ""
+#~ "<varname>Srid</varname> är det <link linkend=\"spatial_ref_sys\">spatiala "
+#~ "referenssystemets</link> SRID för topologin."
+#, no-c-format
+#, no-c-format
+#, no-c-format
+#~ msgid ""
+#~ msgstr ""
+#~ "link>, GT-223 Exportera circ_tree_distance_tree_internal för användning i "
+#~ "mobilitydb (Maxime Schoemans)"
 #, no-c-format
 #~ msgid ""
diff --git a/doc/po/uk/postgis-manual.po b/doc/po/uk/postgis-manual.po
index 2048f014b..12186fcfc 100644
--- a/doc/po/uk/postgis-manual.po
+++ b/doc/po/uk/postgis-manual.po
@@ -4063,6 +4063,28 @@ msgid ""
 msgstr ""
+#. Tag: refpurpose
+#, no-c-format
+msgid ""
+"primitive ids."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+msgstr ""
 #. Tag: title
 #, no-c-format
@@ -4133,7 +4155,8 @@ msgstr ""
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
@@ -4148,6 +4171,21 @@ msgstr ""
 msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"primitive ids."
+msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -35122,12 +35160,12 @@ msgstr ""
 #. Tag: title
 #, no-c-format
 msgstr ""
 #. Tag: para
 #, no-c-format
-msgid "2025/05/17"
+msgid "2025/07/xx"
 msgstr ""
 #. Tag: para
@@ -35138,6 +35176,26 @@ msgid ""
 msgstr ""
+#. Tag: para
+#, no-c-format
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgstr ""
 #. Tag: title
 #, no-c-format
@@ -35158,6 +35216,33 @@ msgid ""
 msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Census Bureau)"
+msgstr ""
 #. Tag: title
 #, no-c-format
@@ -35218,8 +35303,9 @@ msgstr ""
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
@@ -35246,6 +35332,18 @@ msgid ""
 "(Paul Ramsey)"
 msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgstr ""
 #. Tag: title
 #, no-c-format
diff --git a/doc/po/zh_Hans/postgis-manual.po b/doc/po/zh_Hans/postgis-manual.po
index 77bbfcd88..5b7a964b3 100644
--- a/doc/po/zh_Hans/postgis-manual.po
+++ b/doc/po/zh_Hans/postgis-manual.po
@@ -4849,6 +4849,28 @@ msgid ""
 msgstr ""
+#. Tag: refpurpose
+#, no-c-format
+msgid ""
+"primitive ids."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+msgstr ""
 #. Tag: title
 #, no-c-format
@@ -4929,10 +4951,9 @@ msgstr ""
 #, no-c-format
 msgid ""
 msgstr ""
-"<varname>srid</varname> 是拓扑的<link linkend=\"spatial_ref_sys\">空间参考系"
-"统</link> SRID。"
 #. Tag: para
 #, no-c-format
@@ -4946,6 +4967,21 @@ msgstr "容差<varname>精度</varname>以空间参考系的单位进行测量
 msgstr "如果未指定,<varname>hasz </varname>默认为 false。"
+#. Tag: para
+#, no-c-format
+msgid ""
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"primitive ids."
+msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -41222,12 +41258,12 @@ msgstr "发行说明"
 #. Tag: title
 #, no-c-format
 msgstr ""
 #. Tag: para
 #, no-c-format
-msgid "2025/05/17"
+msgid "2025/07/xx"
 msgstr ""
 #. Tag: para
@@ -41238,6 +41274,26 @@ msgid ""
 msgstr ""
+#. Tag: para
+#, no-c-format
+msgstr "非常感谢我们的翻译团队,特别是:"
+#. Tag: para
+#, no-c-format
+#. Tag: para
+#, no-c-format
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgstr ""
 #. Tag: title
 #, no-c-format
@@ -41258,6 +41314,33 @@ msgid ""
 msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Census Bureau)"
+msgstr ""
 #. Tag: title
 #, no-c-format
@@ -41318,8 +41401,9 @@ msgstr ""
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
@@ -41346,6 +41430,18 @@ msgid ""
 "(Paul Ramsey)"
 msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgstr ""
 #. Tag: title
 #, no-c-format
@@ -47074,6 +47170,15 @@ msgstr "2.5/3D 支持"
 msgstr "支持地理"
+#, no-c-format
+#~ msgid ""
+#~ "topology."
+#~ msgstr ""
+#~ "<varname>srid</varname> 是拓扑的<link linkend=\"spatial_ref_sys\">空间参考"
+#~ "系统</link> SRID。"
 #, no-c-format
 #~ msgid ""
@@ -47494,14 +47599,6 @@ msgstr "支持地理"
 #~ "href=\"http://blog.opengeo.org/2012/07/12/making-geography-faster/\">使地"
 #~ "理更快</link>。"
-#, no-c-format
-#~ msgstr "非常感谢我们的翻译团队,特别是:"
-#, no-c-format
 #, no-c-format
Summary of changes:
 doc/po/da/postgis-manual.po      | 108 ++++++++++++++++++++++--
 doc/po/de/postgis-manual.po      | 130 +++++++++++++++++++++++++----
 doc/po/es/postgis-manual.po      | 108 ++++++++++++++++++++++--
 doc/po/fr/postgis-manual.po      | 128 ++++++++++++++++++++++++----
 doc/po/it_IT/postgis-manual.po   | 108 ++++++++++++++++++++++--
 doc/po/ja/postgis-manual.po      | 175 +++++++++++++++++++++++++++++++--------
 doc/po/ka/postgis-manual.po      | 108 ++++++++++++++++++++++--
 doc/po/ko_KR/postgis-manual.po   | 108 ++++++++++++++++++++++--
 doc/po/pl/postgis-manual.po      | 108 ++++++++++++++++++++++--
 doc/po/pt_BR/postgis-manual.po   | 108 ++++++++++++++++++++++--
 doc/po/ro/postgis-manual.po      | 108 ++++++++++++++++++++++--
 doc/po/ru/postgis-manual.po      | 108 ++++++++++++++++++++++--
 doc/po/sv/postgis-manual.po      | 148 +++++++++++++++++++++++++++++----
 doc/po/uk/postgis-manual.po      | 108 ++++++++++++++++++++++--
 doc/po/zh_Hans/postgis-manual.po | 127 ++++++++++++++++++++++++----
 15 files changed, 1645 insertions(+), 143 deletions(-)
hooks/post-receive
