[PostGIS] #5944: berrie 32-bit failing on regress coverage with new GEOS
trac at osgeo.org
Tue Jul 15 11:47:07 PDT 2025
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS GEOS
Component: postgis | Version: 3.5.x
Keywords: |
Given we don't much care about 32-bit, I would be concerned though if this
is a coding issue.
13:18:47 GEOS: 3.14.0dev-CAPI-1.20.0
13:18:47 PROJ: 7.2.1 NETWORK_ENABLED=OFF
URL_ENDPOINT=https://cdn.proj.org
USER_WRITABLE_DIRECTORY=/home/jenkins/.local/share/proj
DATABASE_PATH=/usr/share/proj/proj.db
13:18:47 GDAL: GDAL 3.2.2, released 2021/03/05
13:21:28 regress/core/coverage ..Died at ./regress/run_test.pl line 979.
13:21:28 failed (psql exited with an error: /tmp/pgis_reg/test_123_out)
13:21:28
13:21:28 psql:coverage.sql:24: server closed the connection unexpectedly
13:21:28 This probably means the server terminated abnormally
13:21:28 before or while processing the request.
13:21:28 psql:coverage.sql:24: error: connection to server was lost
13:21:28
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5944>
