[SCM] PostGIS branch master updated. 3.5.0-465-gda1095acf
Tue Jul 15 17:09:41 PDT 2025
the project "PostGIS".
       via  da1095acf25ae160557d4e32973f63d3f523c319 (commit)
      from  45dd053484484d914737e7649ffe10a2d50e5903 (commit)
revisions in full, below.
commit da1095acf25ae160557d4e32973f63d3f523c319
Author: Regina Obe <lr at pcorp.us>
Date:   Tue Jul 15 20:07:48 2025 -0400
    CI Winnie and Berrie64 changes
     * Fix postgisgui packaging exception on winnie
     * Have berrie64 now build with sfcgal master support.
       This is to allow her to do sfcgal garden tests and not fail
       because sfcgal is missing.
      Closes #5945 for PostGIS 3.6.0
diff --git a/ci/berrie64/configs.sh b/ci/berrie64/configs.sh
index 9b2e7aae8..bb83179a6 100644
--- a/ci/berrie64/configs.sh
+++ b/ci/berrie64/configs.sh
@@ -1,13 +1,16 @@
 export WORKSPACE=/home/jenkins/workspace
 export GEOS_VER=3.14.0
+export SFCGAL_VER=master
 export OS_BUILD=64
 export PG_VER=17
 export GEOS_PATH=${WORKSPACE}/geos/rel-${GEOS_VER}
+export SFCGAL_PATH=${WORKSPACE}/sfcgal/rel-sfcgal-${SFCGAL_VER}
 #export GEOS_PATH=~/geos/rel-${GEOS_VER}
 export PGPATH=${WORKSPACE}/pg/label/${label}/rel/pg${PG_VER}w${OS_BUILD}
-export PATH=${PGPATH}/bin:${PGPATH}/lib:${GEOS_PATH}/bin:${GEOS_PATH}/lib:${PATH}
-export PKG_CONFIG_PATH="${GEOS_PATH}/lib/pkgconfig"
+export PATH=${PGPATH}/bin:${PGPATH}/lib:${GEOS_PATH}/bin:${GEOS_PATH}/lib:${SFCGAL_PATH}/bin:${SFCGAL_PATH}/lib:${PATH}
+export PKG_CONFIG_PATH="${GEOS_PATH}/lib/pkgconfig:${SFCGAL_PATH}/lib/pkgconfig"
 export PGPORT=55434
 export PGDATA=$PGPATH/data_${PGPORT}
 export PGHOST=localhost
diff --git a/ci/berrie64/postgis_regress.sh b/ci/berrie64/postgis_regress.sh
index ed4620b63..730b15382 100644
--- a/ci/berrie64/postgis_regress.sh
+++ b/ci/berrie64/postgis_regress.sh
@@ -14,7 +14,9 @@ export CONFIG_FILE="$CUR_DIR/configs.sh"
 echo $PATH
 sh autogen.sh
-./configure --with-pgconfig=${PGPATH}/bin/pg_config --with-geosconfig=${GEOS_PATH}/bin/geos-config --with-library-minor-version --enable-lto --without-interrupt-tests --prefix=${PGPATH}
+./configure --with-pgconfig=${PGPATH}/bin/pg_config --with-geosconfig=${GEOS_PATH}/bin/geos-config --with-library-minor-version --enable-lto \
+    --with-sfcgal=${SFCGAL_PATH}/bin/sfcgal-config \
+    --without-interrupt-tests --prefix=${PGPATH}
 #make clean
 make
 export err_status=0
diff --git a/ci/winnie/package_postgis.sh b/ci/winnie/package_postgis.sh
index dc7f9680c..27fda2311 100644
--- a/ci/winnie/package_postgis.sh
+++ b/ci/winnie/package_postgis.sh
@@ -51,12 +51,6 @@ mkdir $outdir/lib
 mkdir $outdir/utils
-#pg 15 is shipping with newer ssl
-cp ${PGPATHEDB}/bin/libcrypto-3-x64.dll $outdir/bin/postgisgui
-cp ${PGPATHEDB}/bin/libssl-3-x64.dll $outdir/bin/postgisgui
 cp /c/ming${OS_BUILD}${GCC_TYPE}/mingw${OS_BUILD}/bin/libstdc++-6.dll $outdir/bin
 cp /c/ming${OS_BUILD}${GCC_TYPE}/mingw${OS_BUILD}/bin/libgcc*.dll $outdir/bin
@@ -65,6 +59,9 @@ if [ -n "${PROJECTS}/gtkw${OS_BUILD}${GCC_TYPE}" ]; then
 	mkdir $outdir/bin/postgisgui
 	mkdir $outdir/bin/postgisgui/share
 	mkdir $outdir/bin/postgisgui/lib
+	#pg 15 is shipping with newer ssl
+	cp ${PGPATHEDB}/bin/libcrypto-3-x64.dll $outdir/bin/postgisgui
+	cp ${PGPATHEDB}/bin/libssl-3-x64.dll $outdir/bin/postgisgui
 	cp -r ${PROJECTS}/gtkw${OS_BUILD}${GCC_TYPE}/bin/*.dll $outdir/bin/postgisgui
 	cp /c/ming${OS_BUILD}${GCC_TYPE}/mingw${OS_BUILD}/bin/libstdc++-6.dll $outdir/bin/postgisgui
 	cp /c/ming${OS_BUILD}${GCC_TYPE}/mingw${OS_BUILD}/bin/libgcc*.dll $outdir/bin/postgisgui
@@ -86,6 +83,9 @@ if [ -n "${PROJECTS}/gtkw${OS_BUILD}${GCC_TYPE}" ]; then
 	cp loader/shp2pgsql-gui.exe ${RELDIR}/${RELVERDIR}/bin/postgisgui
 	cp loader/.libs/shp2pgsql-gui.exe ${RELDIR}/${RELVERDIR}/bin/postgisgui
+	#shp2pgsql-gui now has dependency on geos (though in theory it shouldn't)
+	cp -p ${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}${GCC_TYPE}/bin/*.dll ${RELDIR}/${RELVERDIR}/bin/postgisgui
 fi;
 # proj
@@ -157,8 +157,6 @@ cp topology/loader/* ${RELDIR}/${RELVERDIR}/bin
 #cp liblwgeom/.libs/*.dll ${RELDIR}/${RELVERDIR}/bin/postgisgui
-#shp2pgsql-gui now has dependency on geos (though in theory it shouldn't)
-cp -p ${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}${GCC_TYPE}/bin/*.dll ${RELDIR}/${RELVERDIR}/bin/postgisgui
 cp spatial_ref_sys.sql ${RELDIR}/${RELVERDIR}/share/contrib/postgis-${POSTGIS_MINOR_VER}
 cp topology/topology.sql ${RELDIR}/${RELVERDIR}/share/contrib/postgis-${POSTGIS_MINOR_VER}
 #cp topology/topology_upgrade_*.sql ${RELDIR}/${RELVERDIR}/share/contrib/postgis-${POSTGIS_MINOR_VER}
Summary of changes:
 ci/berrie64/configs.sh         |  7 +++++--
 ci/berrie64/postgis_regress.sh |  4 +++-
 ci/winnie/package_postgis.sh   | 14 ++++++--------
 3 files changed, 14 insertions(+), 11 deletions(-)
hooks/post-receive
