[PostGIS] #5945: berrie64 failing on sfcgal cause sfcgal not installed
PostGIS trac at osgeo.org
Tue Jul 15 23:53:34 PDT 2025
  Reporter:  robe          |      Owner:  robe
      Type:  defect        |     Status:  closed
  Priority:  medium        |  Milestone:  Website Management, Bots
 Component:  QA/buildbots  |    Version:  3.5.x
Resolution:  fixed         |   Keywords:
Comment (by Regina Obe <lr@…>):
 In [changeset:"6fa083969d46eaa322e864ef1561e964513d67a3/git" 6fa0839/git]:
 {{{#!CommitTicketReference repository="git"
 revision="6fa083969d46eaa322e864ef1561e964513d67a3"
 Try to get berrie64 compile with SFCGAL
 Use GEOS 3.11 which is same as GDAL is compiled with
 To prevent GDAL-GEOS / GEOS conflict
 References  #5945
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5945#comment:3>
