[SCM] PostGIS branch master updated. 3.6.0beta1-10-ge0e19372b
git at osgeo.org
git at osgeo.org
Fri Jul 25 09:35:18 PDT 2025
the project "PostGIS".
via e0e19372b7aa15f0d0e1c68de1e33206d7548621 (commit)
from 18cfba216da44cabc6a4d661887b4ec90bd6c92b (commit)
revisions in full, below.
commit e0e19372b7aa15f0d0e1c68de1e33206d7548621
Author: Paul Ramsey <paul.ramsey at snowflake.com>
Date: Fri Jul 25 09:35:13 2025 -0700
Remove anticipatory ifdefs around internal pgSQL json support functions, which may or may not ever become public symbols we can rely upon. Closes #5934
diff --git a/postgis/lwgeom_out_geojson.c b/postgis/lwgeom_out_geojson.c
index 411f7c068..86f6b48c9 100644
--- a/postgis/lwgeom_out_geojson.c
+++ b/postgis/lwgeom_out_geojson.c
@@ -32,7 +32,6 @@
#include "lwgeom_log.h"
#include "liblwgeom.h"
-#if POSTGIS_PGSQL_VERSION < 200
typedef enum /* type categories for datum_to_json */
JSONTYPE_NULL, /* null, so we didn't bother to identify */
@@ -47,7 +46,6 @@ typedef enum /* type categories for datum_to_json */
JSONTYPE_CAST, /* something with an explicit cast to JSON */
JSONTYPE_OTHER /* all else */
} JsonTypeCategory;
-#endif
static void array_dim_to_json(StringInfo result, int dim, int ndims, int *dims,
Datum *vals, bool *nulls, int *valcount,
@@ -69,11 +67,9 @@ static void composite_to_json(Datum composite, StringInfo result,
static void datum_to_json(Datum val, bool is_null, StringInfo result,
JsonTypeCategory tcategory, Oid outfuncoid,
bool key_scalar);
static void json_categorize_type(Oid typoid,
JsonTypeCategory *tcategory,
Oid *outfuncoid);
-#endif
static char * postgis_JsonEncodeDateTime(char *buf, Datum value, Oid typid);
static int postgis_time2tm(TimeADT time, struct pg_tm *tm, fsec_t *fsec);
static int postgis_timetz2tm(TimeTzADT *time, struct pg_tm *tm, fsec_t *fsec, int *tzp);
@@ -283,7 +279,6 @@ composite_to_geojson(FunctionCallInfo fcinfo,
* output function OID. If the returned category is JSONTYPE_CAST, we
* return the OID of the type->JSON cast function instead.
static void
@@ -376,7 +371,7 @@ json_categorize_type(Oid typoid,
break;
-#endif
* Turn a Datum into JSON text, appending the string to "result".
Summary of changes:
postgis/lwgeom_out_geojson.c | 7 +------
1 file changed, 1 insertion(+), 6 deletions(-)
hooks/post-receive
