[PostGIS] #5955: ST_GetFaceGeometry eats our ram
PostGIS trac at osgeo.org
Fri Jul 25 11:09:19 PDT 2025
 Reporter:  latot     |      Owner:  strk
     Type:  defect    |     Status:  new
 Priority:  high      |  Milestone:  PostGIS 3.5.4
Component:  topology  |    Version:  3.5.x
 Keywords:            |
 Hi! we know from some time in some circunstances there was something off,
 what was missing is a reprex to find this.
 Here is! how to cause the whole session use all the ram:
 SELECT
         topology.createtopology (
                 'overflow',
                 0,
                 0
 SELECT TopoGeo_AddPolygon(
         'overflow',
         'POLYGON((0 0, 0 1, 1 1, 0 0))'::geometry,
         0
 DO $$
 DECLARE
  face GEOMETRY;
 BEGIN
         LOOP
                 face := (topology.ST_GetFaceGeometry('overflow', 1));
                 RAISE NOTICE 'run';
         END LOOP;
 END;
 With grayshde we did some tests, this is the most simple scenario, the ram
 will slowly increase, never being free....
 There is other circunstances, in some queries even running this function
 will not trigger this behavior, something closer that still would be good
 to keep an eye would be this scenario:
 DO $$
 DECLARE
  geom GEOMETRY;
  face GEOMETRY;
  inter GEOMETRY;
 BEGIN
         geom := 'SRID=0;POLYGON EMPTY'::GEOMETRY;
         LOOP
                 inter := ST_Intersection(geom, face);
                 RAISE NOTICE 'run';
         END LOOP;
 END;
 There is some very weird things with this, I hope with this simple cases
 we can finally start looking what happens behind.
 I have other complex queries that also needs some data to be executed,
 where any change causes to this do not happen.
 For the record:
 CREATE OR REPLACE FUNCTION dumppolygons (in_geom geometry) returns TABLE
 (path INT, geom geometry) language plpgsql AS $$
 BEGIN
         IF GeometryType(in_geom) <> 'MULTIPOLYGON' THEN
                 RAISE EXCEPTION 'geom is not a multipolygon';
         END IF;
         RETURN QUERY SELECT x.path[1], x.geom
                 FROM (SELECT (ST_Dump(in_geom)).*) x;
         IF NOT FOUND THEN
                 RAISE EXCEPTION 'No geometries!';
         END IF;
         RETURN;
 END;
 DO $$
 DECLARE
  a INT;
 BEGIN
 LOOP
 a := (
         WITH faces AS (
         SELECT
                 x.face,
                 topology.ST_GetFaceGeometry('manzana_urbana_topo',
 x.face[1]) geom
         FROM (
                 SELECT
 topology.GetTopoGeomElements('(1,1,190137,3)'::TopoGeometry) face
         ) x
         inter AS (
                 SELECT dp.path, faces.face, ST_Intersection(faces.geom,
 dp.geom) area
                 FROM faces,
 dumppolygons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
 dp
         SELECT COUNT(1) counter
         FROM (
                 SELECT
                 FROM inter
 RAISE NOTICE 'run';
 END LOOP;
 END;
 With this data:
 https://drive.google.com/file/d/14oF1eBqTVm01ETuXIfDugnK62g1NYxvB/view?usp=sharing
 What is weird here is... if you replace the function DumpPolygons with
 ST_Dump stops working, any change I tested there also make the reprex do
 not works.
 So now we have the simple example, and the complex one!
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5955>
