[PostGIS] #5957: ST_GetFaceEdges return bigint in some cases
PostGIS trac at osgeo.org
Mon Jul 28 00:15:56 PDT 2025
 Reporter:  Lars Aksel Opsahl  |      Owner:  strk
     Type:  defect             |     Status:  new
 Priority:  medium             |  Milestone:  PostGIS 3.6.0
Component:  topology           |    Version:  master
 Keywords:                     |
 On this version
 PostgreSQL 16.4 (Ubuntu 16.4-1.pgdg22.04+1) on x86_64-pc-linux-gnu,
 compiled by gcc (Ubuntu 11.4.0-1ubuntu1~22.04) 11.4.0, 64-bit
 POSTGIS="3.6.0beta1 3.6.0beta1-10-ge0e19372b" [EXTENSION] PGSQL="160"
 GEOS="3.13.1-CAPI-1.19.2" PROJ="9.3.0 NETWORK_ENABLED=OFF
 URL_ENDPOINT=https://cdn.proj.org USER_WRITABLE_DIRECTORY=/tmp/proj
 DATABASE_PATH=/usr/local/share/proj/proj.db" (compiled against PROJ 9.3.0)
 LIBXML="2.9.13" LIBJSON="0.15" LIBPROTOBUF="1.3.3" WAGYU="0.5.0
 (Internal)" TOPOLOGY
 I got this error message in one case.
 NOTICE:  Failed to run ST_GetFaceEdges for face_id 462 in topo
 arstat_04_topo_72 state  : 42804  message: structure of query does not
 match function result type detail : Returned type bigint does not match
 expected type integer in column 1. hint   :  context: SQL statement "
                         SELECT abs(t.edge) AS edge_id
                         FROM
 topology.ST_GetFaceEdges('arstat_04_topo_72',462) As t(seq,edge);
 This is the code I called it from
 CREATE OR REPLACE FUNCTION topo_update.get_face_edges(_atopology varchar,
 _face_id int)
         RETURNS table(edge_id int)
         AS $$
 DECLARE
         -- holds dynamic sql to be able to use the same code for different
         command_string text;
         v_state text;
         v_msg text;
         v_detail text;
         v_hint text;
         v_context text;
         face_id_found boolean = false;
 BEGIN
         BEGIN
                 command_string = format($fmt$
                         FROM topology.ST_GetFaceEdges(%1$L,%2$s) As
 t(seq,edge);
                         $fmt$,
                                 _atopology,
                                 _face_id
                 RAISE NOTICE 'command_string %', command_string;
                 RETURN QUERY EXECUTE command_string;
         EXCEPTION WHEN OTHERS THEN
                 GET STACKED DIAGNOSTICS v_state = RETURNED_SQLSTATE, v_msg
 = MESSAGE_TEXT, v_detail = PG_EXCEPTION_DETAIL, v_hint =
 PG_EXCEPTION_HINT,
        v_context
 = PG_EXCEPTION_CONTEXT;
                 RAISE NOTICE 'Failed to run ST_GetFaceEdges for face_id %
 in topo % state  : %  message: % detail : % hint   : % context: %',
                 _face_id, _atopology, v_state, v_msg, v_detail, v_hint,
 v_context;
                 RETURN;
         END;
 END;
 LANGUAGE plpgsql
 STABLE;
 I am working on test case to reproduce this error, but so far I have only
 seen this error one time and have not been able to reproduce it so far.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5957>
