[PostGIS] #5957: ST_GetFaceEdges return bigint in some cases
trac at osgeo.org
Mon Jul 28 00:53:18 PDT 2025
Reporter: Lars Aksel Opsahl | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.6.0
Component: topology | Version: master
Resolution: | Keywords:
Comment (by Lars Aksel Opsahl):
Here is a sample of the problem.
SELECT abs(t.edge) AS edge_id
FROM
topology.ST_GetFaceEdges('arstat_04_topo_72',582) As t(seq,edge);
edge_id
422
647
440
619
458
568
592
(7 rows)
cpu11.int.nibio.no postgres at rog_02=# create table test_5957 as (SELECT
FROM
topology.ST_GetFaceEdges('arstat_04_topo_72',582) As t(seq,edge));
SELECT 7
cpu11.int.nibio.no postgres at rog_02=# \d test_5957
Table "public.test_5957"
Column | Type | Collation | Nullable | Default
edge_id | bigint | | |
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5957#comment:1>
