[SCM] PostGIS branch master updated. 3.5.0-356-ge95bdce70
git at osgeo.org
git at osgeo.org
Mon Jun 2 11:51:51 PDT 2025
the project "PostGIS".
via e95bdce703b9c512590da3c38d95c8156680c822 (commit)
from a238dd66e38f3b4e8744501eafeb0930db21683c (commit)
revisions in full, below.
commit e95bdce703b9c512590da3c38d95c8156680c822
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Mon Jun 2 11:51:37 2025 -0700
Flip parameters gapMaximumWidth and snappingDistance around.
diff --git a/doc/reference_coverage.xml b/doc/reference_coverage.xml
index cab673ff1..304d7c2e8 100644
--- a/doc/reference_coverage.xml
+++ b/doc/reference_coverage.xml
@@ -342,8 +342,8 @@ MULTIPOLYGON (((10 150, 80 190, 110 150, 140 80, 120 10, 10 10, 10 150), (50 60,
<title>Description</title>
<para>A window function which alters the edges of a polygonal coverage to ensure that none of the polygons overlap, that small gaps are snapped away, and that all shared edges are exactly identical. The result is a clean coverage that will pass validation tests like <xref linkend="ST_CoverageInvalidEdges"/></para>
- <para>The <parameter>snappingDistance</parameter> controls the node snapping step, when nearby vertices are snapped together. The default setting (-1) applies an automatic snapping distance based on an analysis of the input. Set to 0.0 to turn off all snapping.</para>
<para>The <parameter>gapMaximumWidth</parameter> controls the cleaning of gaps between polygons. Gaps smaller than this tolerance will be closed.</para>
+ <para>The <parameter>snappingDistance</parameter> controls the node snapping step, when nearby vertices are snapped together. The default setting (-1) applies an automatic snapping distance based on an analysis of the input. Set to 0.0 to turn off all snapping.</para>
<para>The <parameter>overlapMergeStrategy</parameter> controls the algorithm used to determine which neighboring polygons to merge overlapping areas into.</para>
<para><code>MERGE_LONGEST_BORDER</code> chooses polygon with longest common border</para>
<para><code>MERGE_MAX_AREA</code> chooses polygon with maximum area</para>
diff --git a/postgis/lwgeom_window.c b/postgis/lwgeom_window.c
index f431e4907..e53152631 100644
--- a/postgis/lwgeom_window.c
+++ b/postgis/lwgeom_window.c
@@ -724,10 +724,10 @@ coverage_window_calculation(PG_FUNCTION_ARGS, int mode)
GEOSCoverageCleanParams *params = NULL;
d = WinGetFuncArgCurrent(winobj, 1, &isnull);
- if (!isnull) snappingDistance = DatumGetFloat8(d);
+ if (!isnull) gapMaximumWidth = DatumGetFloat8(d);
d = WinGetFuncArgCurrent(winobj, 2, &isnull);
- if (!isnull) gapMaximumWidth = DatumGetFloat8(d);
+ if (!isnull) snappingDistance = DatumGetFloat8(d);
d = WinGetFuncArgCurrent(winobj, 3, &isnull);
// if (!isnull) overlapMergeStrategy = DatumGetInt32(d);
diff --git a/postgis/postgis.sql.in b/postgis/postgis.sql.in
index 64dcf343e..998ae2a73 100644
--- a/postgis/postgis.sql.in
+++ b/postgis/postgis.sql.in
@@ -4468,7 +4468,7 @@ CREATE OR REPLACE FUNCTION ST_CoverageInvalidEdges (geom geometry, tolerance flo
_COST_HIGH;
-- Availability: 3.6.0
-CREATE OR REPLACE FUNCTION ST_CoverageClean (geom geometry, snappingDistance float8 default -1.0, gapMaximumWidth float8 default 0.0, overlapMergeStrategy text default 'MERGE_LONGEST_BORDER')
+CREATE OR REPLACE FUNCTION ST_CoverageClean (geom geometry, gapMaximumWidth float8 default 0.0, snappingDistance float8 default -1.0, overlapMergeStrategy text default 'MERGE_LONGEST_BORDER')
RETURNS geometry
AS 'MODULE_PATHNAME', 'ST_CoverageClean'
LANGUAGE 'c' IMMUTABLE STRICT WINDOW PARALLEL SAFE
Summary of changes:
doc/reference_coverage.xml | 2 +-
postgis/lwgeom_window.c | 4 ++--
postgis/postgis.sql.in | 2 +-
3 files changed, 4 insertions(+), 4 deletions(-)
hooks/post-receive
