[SCM] PostGIS branch master updated. 3.5.0-359-g8e8f09f73
git at osgeo.org
git at osgeo.org
Mon Jun 2 22:11:14 PDT 2025
the project "PostGIS".
via 8e8f09f73cc86b3c3132aa18845ff68dbc5fa75d (commit)
via 997d9e89485e21635de7ea4d28c472e57e558573 (commit)
from 1ffe544650b6b69d1d3bf78cb341c6cd20aaa2f1 (commit)
revisions in full, below.
commit 8e8f09f73cc86b3c3132aa18845ff68dbc5fa75d
Author: Loïc Bartoletti <loic.bartoletti at oslandia.com>
Date: Tue Jun 3 06:29:21 2025 +0200
fix(SFCGAL): fix Extrude building and roof test
diff --git a/sfcgal/regress/extrudestraigthskeleton.sql b/sfcgal/regress/extrudestraigthskeleton.sql
index 4591993e9..434654a04 100644
--- a/sfcgal/regress/extrudestraigthskeleton.sql
+++ b/sfcgal/regress/extrudestraigthskeleton.sql
@@ -1,20 +1,41 @@
SELECT 'Extrude roof', ST_AsText(CG_ExtrudeStraightSkeleton('POLYGON (( 0 0, 5 0, 5 5, 4 5, 4 4, 0 4, 0 0 ), (1 1, 1 2,2 2, 2 1, 1 1))', 2.0));
-WITH version_info AS (
--- The result depends on the SFCGAL Version.
--- Prior to version 2.2, it contained extra patches.
- SELECT regexp_replace(postgis_full_version(), '.*SFCGAL="([^"]+)".*', '\1') AS sfcgal_version
-skeleton AS (
- SELECT ST_NumPatches(CG_ExtrudeStraightSkeleton('POLYGON (( 0 0, 5 0, 5 5, 4 5, 4 4, 0 4, 0 0 ), (1 1, 1 2,2 2, 2 1, 1 1))', 3.0, 2.0)) AS num_patches
-check_patches AS (
- SELECT
- sfcgal_version,
+WITH
+ version_info AS (
+ -- The result depends on the SFCGAL Version.
+ -- Prior to version 2.2, it contained extra patches.
+ SELECT
+ string_to_array(postgis_sfcgal_version (), '.')::INT[] AS sfcgal_version_array
+ skeleton AS (
+ SELECT
+ ST_NumPatches (
+ CG_ExtrudeStraightSkeleton (
+ 'POLYGON (( 0 0, 5 0, 5 5, 4 5, 4 4, 0 4, 0 0 ), (1 1, 1 2,2 2, 2 1, 1 1))',
+ 3.0,
+ 2.0
+ ) AS num_patches
+ check_patches AS (
+ SELECT
+ sfcgal_version_array,
num_patches,
- (sfcgal_version <= '2.1.0' AND num_patches = 49) OR
- (sfcgal_version > '2.1.0' AND num_patches = 39)
+ sfcgal_version_array <= ARRAY[2, 1, 0]
+ AND num_patches = 49
+ OR (
+ sfcgal_version_array > ARRAY[2, 1, 0]
+ AND num_patches = 39
) AS test_result
- FROM skeleton, version_info
-SELECT 'Extrude building and roof', num_patches FROM skeleton;
+ FROM
+ skeleton,
+ version_info
+SELECT
+ 'Extrude building and roof',
+ test_result
+FROM
+ check_patches;
commit 997d9e89485e21635de7ea4d28c472e57e558573
Author: Jean Felder <jean.felder at oslandia.com>
Date: Mon May 26 17:50:31 2025 +0200
sfcgal: Adapt CG_ExtrudeStraightSkeleton test to validity fix
The geometry returned was invalid because the bottom/base of the roof
was present. So, the geometry contained inner surface inside the
building (wall + roof).
The unit test is updated by counting the number of patches instead of
checking the result. This makes it easy to have a unit test which
works for all SFCGAL versions.
See: https://gitlab.com/sfcgal/SFCGAL/-/merge_requests/511
diff --git a/doc/reference_sfcgal.xml b/doc/reference_sfcgal.xml
index 8c9226fda..168a6c644 100644
--- a/doc/reference_sfcgal.xml
+++ b/doc/reference_sfcgal.xml
@@ -2111,7 +2111,7 @@ ST_GeomFromText('POLYHEDRALSURFACE Z( ((0 0 0, 0 0 1, 0 1 1, 0 1 0, 0 0 0)),
<title>Examples</title>
<para>
<programlisting>SELECT ST_AsText(CG_ExtrudeStraightSkeleton('POLYGON (( 0 0, 5 0, 5 5, 4 5, 4 4, 0 4, 0 0 ), (1 1, 1 2,2 2, 2 1, 1 1))', 3.0, 2.0));</programlisting>
- <screen>POLYHEDRALSURFACE Z (((0 0 0,0 4 0,4 4 0,4 5 0,5 5 0,5 0 0,0 0 0),(1 1 0,2 1 0,2 2 0,1 2 0,1 1 0)),((0 0 0,0 0 2,0 4 2,0 4 0,0 0 0)),((0 4 0,0 4 2,4 4 2,4 4 0,0 4 0)),((4 4 0,4 4 2,4 5 2,4 5 0,4 4 0)),((4 5 0,4 5 2,5 5 2,5 5 0,4 5 0)),((5 5 0,5 5 2,5 0 2,5 0 0,5 5 0)),((5 0 0,5 0 2,0 0 2,0 0 0,5 0 0)),((1 1 0,1 1 2,2 1 2,2 1 0,1 1 0)),((2 1 0,2 1 2,2 2 2,2 2 0,2 1 0)),((2 2 0,2 2 2,1 2 2,1 2 0,2 2 0)),((1 2 0,1 2 2,1 1 2,1 1 0,1 2 0)),((4 5 2,5 5 2,4 4 2,4 5 2)),((2 1 2,5 0 2,0 0 2,2 1 2)),((5 5 2,5 0 2,4 4 2,5 5 2)),((2 1 2,0 0 2,1 1 2,2 1 2)),((1 2 2,1 1 2,0 0 2,1 2 2)),((0 4 2,2 2 2,1 2 2,0 4 2)),((0 4 2,1 2 2,0 0 2,0 4 2)),((4 4 2,5 0 2,2 2 2,4 4 2)),((4 4 2,2 2 2,0 4 2,4 4 2)),((2 2 2,5 0 2,2 1 2,2 2 2)),((0.5 2.5 2.5,0 0 2,0.5 0.5 2.5,0.5 2.5 2.5)),((1 3 3,0 4 2,0.5 2.5 2.5,1 3 3)),((0.5 2.5 2.5,0 4 2,0 0 2,0.5 2.5 2.5)),((2.5 0.5 2.5,5 0 2,3.5 1.5 3.5,2.5 0.5 2.5)),((0 0 2,5 0 2,2.5 0.5 2.5,0 0 2)),((0.5 0.5 2.5,0 0 2,2.5 0.5 2.5,0.5 0.5 2.5)),((4.5 3.
5 2.5,5 5 2,4.5 4.5 2.5,4.5 3.5 2.5)),((3.5 2.5 3.5,3.5 1.5 3.5,4.5 3.5 2.5,3.5 2.5 3.5)),((4.5 3.5 2.5,5 0 2,5 5 2,4.5 3.5 2.5)),((3.5 1.5 3.5,5 0 2,4.5 3.5 2.5,3.5 1.5 3.5)),((5 5 2,4 5 2,4.5 4.5 2.5,5 5 2)),((4.5 4.5 2.5,4 4 2,4.5 3.5 2.5,4.5 4.5 2.5)),((4.5 4.5 2.5,4 5 2,4 4 2,4.5 4.5 2.5)),((3 3 3,0 4 2,1 3 3,3 3 3)),((3.5 2.5 3.5,4.5 3.5 2.5,3 3 3,3.5 2.5 3.5)),((3 3 3,4 4 2,0 4 2,3 3 3)),((4.5 3.5 2.5,4 4 2,3 3 3,4.5 3.5 2.5)),((2 1 2,1 1 2,0.5 0.5 2.5,2 1 2)),((2.5 0.5 2.5,2 1 2,0.5 0.5 2.5,2.5 0.5 2.5)),((1 1 2,1 2 2,0.5 2.5 2.5,1 1 2)),((0.5 0.5 2.5,1 1 2,0.5 2.5 2.5,0.5 0.5 2.5)),((1 3 3,2 2 2,3 3 3,1 3 3)),((0.5 2.5 2.5,1 2 2,1 3 3,0.5 2.5 2.5)),((1 3 3,1 2 2,2 2 2,1 3 3)),((2 2 2,2 1 2,2.5 0.5 2.5,2 2 2)),((3.5 2.5 3.5,3 3 3,3.5 1.5 3.5,3.5 2.5 3.5)),((3.5 1.5 3.5,2 2 2,2.5 0.5 2.5,3.5 1.5 3.5)),((3 3 3,2 2 2,3.5 1.5 3.5,3 3 3)))</screen>
+ <screen>POLYHEDRALSURFACE Z (((0 0 0,0 4 0,4 4 0,4 5 0,5 5 0,5 0 0,0 0 0),(1 1 0,2 1 0,2 2 0,1 2 0,1 1 0)),((0 0 0,0 0 2,0 4 2,0 4 0,0 0 0)),((0 4 0,0 4 2,4 4 2,4 4 0,0 4 0)),((4 4 0,4 4 2,4 5 2,4 5 0,4 4 0)),((4 5 0,4 5 2,5 5 2,5 5 0,4 5 0)),((5 5 0,5 5 2,5 0 2,5 0 0,5 5 0)),((5 0 0,5 0 2,0 0 2,0 0 0,5 0 0)),((1 1 0,1 1 2,2 1 2,2 1 0,1 1 0)),((2 1 0,2 1 2,2 2 2,2 2 0,2 1 0)),((2 2 0,2 2 2,1 2 2,1 2 0,2 2 0)),((1 2 0,1 2 2,1 1 2,1 1 0,1 2 0)),((0.5 2.5 2.5,0 0 2,0.5 0.5 2.5,0.5 2.5 2.5)),((1 3 3,0 4 2,0.5 2.5 2.5,1 3 3)),((0.5 2.5 2.5,0 4 2,0 0 2,0.5 2.5 2.5)),((2.5 0.5 2.5,5 0 2,3.5 1.5 3.5,2.5 0.5 2.5)),((0 0 2,5 0 2,2.5 0.5 2.5,0 0 2)),((0.5 0.5 2.5,0 0 2,2.5 0.5 2.5,0.5 0.5 2.5)),((4.5 3.5 2.5,5 5 2,4.5 4.5 2.5,4.5 3.5 2.5)),((3.5 2.5 3.5,3.5 1.5 3.5,4.5 3.5 2.5,3.5 2.5 3.5)),((4.5 3.5 2.5,5 0 2,5 5 2,4.5 3.5 2.5)),((3.5 1.5 3.5,5 0 2,4.5 3.5 2.5,3.5 1.5 3.5)),((5 5 2,4 5 2,4.5 4.5 2.5,5 5 2)),((4.5 4.5 2.5,4 4 2,4.5 3.5 2.5,4.5 4.5 2.5)),((4.5 4.5 2.5,4 5 2,4 4
</para>
</refsection>
<refsection>
index c0b8df3c1..4591993e9 100644
@@ -1,2 +1,20 @@
-SELECT 'Extrude building and roof', ST_AsText(CG_ExtrudeStraightSkeleton('POLYGON (( 0 0, 5 0, 5 5, 4 5, 4 4, 0 4, 0 0 ), (1 1, 1 2,2 2, 2 1, 1 1))', 3.0, 2.0));
+WITH version_info AS (
+-- The result depends on the SFCGAL Version.
+-- Prior to version 2.2, it contained extra patches.
+ SELECT regexp_replace(postgis_full_version(), '.*SFCGAL="([^"]+)".*', '\1') AS sfcgal_version
+skeleton AS (
+ SELECT ST_NumPatches(CG_ExtrudeStraightSkeleton('POLYGON (( 0 0, 5 0, 5 5, 4 5, 4 4, 0 4, 0 0 ), (1 1, 1 2,2 2, 2 1, 1 1))', 3.0, 2.0)) AS num_patches
+check_patches AS (
+ SELECT
+ sfcgal_version,
+ num_patches,
+ (sfcgal_version <= '2.1.0' AND num_patches = 49) OR
+ (sfcgal_version > '2.1.0' AND num_patches = 39)
+ ) AS test_result
+ FROM skeleton, version_info
+SELECT 'Extrude building and roof', num_patches FROM skeleton;
diff --git a/sfcgal/regress/extrudestraigthskeleton_expected b/sfcgal/regress/extrudestraigthskeleton_expected
index 0b3805b35..840482c1d 100644
--- a/sfcgal/regress/extrudestraigthskeleton_expected
+++ b/sfcgal/regress/extrudestraigthskeleton_expected
@@ -1,2 +1,2 @@
Extrude roof|POLYHEDRALSURFACE Z (((4 5 0,5 5 0,4 4 0,4 5 0)),((2 1 0,5 0 0,0 0 0,2 1 0)),((5 5 0,5 0 0,4 4 0,5 5 0)),((2 1 0,0 0 0,1 1 0,2 1 0)),((1 2 0,1 1 0,0 0 0,1 2 0)),((0 4 0,2 2 0,1 2 0,0 4 0)),((0 4 0,1 2 0,0 0 0,0 4 0)),((4 4 0,5 0 0,2 2 0,4 4 0)),((4 4 0,2 2 0,0 4 0,4 4 0)),((2 2 0,5 0 0,2 1 0,2 2 0)),((0.5 2.5 0.5,0 0 0,0.5 0.5 0.5,0.5 2.5 0.5)),((1 3 1,0 4 0,0.5 2.5 0.5,1 3 1)),((0.5 2.5 0.5,0 4 0,0 0 0,0.5 2.5 0.5)),((2.5 0.5 0.5,5 0 0,3.5 1.5 1.5,2.5 0.5 0.5)),((0 0 0,5 0 0,2.5 0.5 0.5,0 0 0)),((0.5 0.5 0.5,0 0 0,2.5 0.5 0.5,0.5 0.5 0.5)),((4.5 3.5 0.5,5 5 0,4.5 4.5 0.5,4.5 3.5 0.5)),((3.5 2.5 1.5,3.5 1.5 1.5,4.5 3.5 0.5,3.5 2.5 1.5)),((4.5 3.5 0.5,5 0 0,5 5 0,4.5 3.5 0.5)),((3.5 1.5 1.5,5 0 0,4.5 3.5 0.5,3.5 1.5 1.5)),((5 5 0,4 5 0,4.5 4.5 0.5,5 5 0)),((4.5 4.5 0.5,4 4 0,4.5 3.5 0.5,4.5 4.5 0.5)),((4.5 4.5 0.5,4 5 0,4 4 0,4.5 4.5 0.5)),((3 3 1,0 4 0,1 3 1,3 3 1)),((3.5 2.5 1.5,4.5 3.5 0.5,3 3 1,3.5 2.5 1.5)),((3 3 1,4 4 0,0 4 0,3 3 1)),((4.5 3.5 0.5,4 4 0,3 3 1,4.5 3
.5 0.5)),((2 1 0,1 1 0,0.5 0.5 0.5,2 1 0)),((2.5 0.5 0.5,2 1 0,0.5 0.5 0.5,2.5 0.5 0.5)),((1 1 0,1 2 0,0.5 2.5 0.5,1 1 0)),((0.5 0.5 0.5,1 1 0,0.5 2.5 0.5,0.5 0.5 0.5)),((1 3 1,2 2 0,3 3 1,1 3 1)),((0.5 2.5 0.5,1 2 0,1 3 1,0.5 2.5 0.5)),((1 3 1,1 2 0,2 2 0,1 3 1)),((2 2 0,2 1 0,2.5 0.5 0.5,2 2 0)),((3.5 2.5 1.5,3 3 1,3.5 1.5 1.5,3.5 2.5 1.5)),((3.5 1.5 1.5,2 2 0,2.5 0.5 0.5,3.5 1.5 1.5)),((3 3 1,2 2 0,3.5 1.5 1.5,3 3 1)))
-Extrude building and roof|POLYHEDRALSURFACE Z (((0 0 0,0 4 0,4 4 0,4 5 0,5 5 0,5 0 0,0 0 0),(1 1 0,2 1 0,2 2 0,1 2 0,1 1 0)),((0 0 0,0 0 2,0 4 2,0 4 0,0 0 0)),((0 4 0,0 4 2,4 4 2,4 4 0,0 4 0)),((4 4 0,4 4 2,4 5 2,4 5 0,4 4 0)),((4 5 0,4 5 2,5 5 2,5 5 0,4 5 0)),((5 5 0,5 5 2,5 0 2,5 0 0,5 5 0)),((5 0 0,5 0 2,0 0 2,0 0 0,5 0 0)),((1 1 0,1 1 2,2 1 2,2 1 0,1 1 0)),((2 1 0,2 1 2,2 2 2,2 2 0,2 1 0)),((2 2 0,2 2 2,1 2 2,1 2 0,2 2 0)),((1 2 0,1 2 2,1 1 2,1 1 0,1 2 0)),((4 5 2,5 5 2,4 4 2,4 5 2)),((2 1 2,5 0 2,0 0 2,2 1 2)),((5 5 2,5 0 2,4 4 2,5 5 2)),((2 1 2,0 0 2,1 1 2,2 1 2)),((1 2 2,1 1 2,0 0 2,1 2 2)),((0 4 2,2 2 2,1 2 2,0 4 2)),((0 4 2,1 2 2,0 0 2,0 4 2)),((4 4 2,5 0 2,2 2 2,4 4 2)),((4 4 2,2 2 2,0 4 2,4 4 2)),((2 2 2,5 0 2,2 1 2,2 2 2)),((0.5 2.5 2.5,0 0 2,0.5 0.5 2.5,0.5 2.5 2.5)),((1 3 3,0 4 2,0.5 2.5 2.5,1 3 3)),((0.5 2.5 2.5,0 4 2,0 0 2,0.5 2.5 2.5)),((2.5 0.5 2.5,5 0 2,3.5 1.5 3.5,2.5 0.5 2.5)),((0 0 2,5 0 2,2.5 0.5 2.5,0 0 2)),((0.5 0.5 2.5,0 0 2,2.5 0.5 2.5,0.5 0.5 2.5)),((4.5
3.5 2.5,5 5 2,4.5 4.5 2.5,4.5 3.5 2.5)),((3.5 2.5 3.5,3.5 1.5 3.5,4.5 3.5 2.5,3.5 2.5 3.5)),((4.5 3.5 2.5,5 0 2,5 5 2,4.5 3.5 2.5)),((3.5 1.5 3.5,5 0 2,4.5 3.5 2.5,3.5 1.5 3.5)),((5 5 2,4 5 2,4.5 4.5 2.5,5 5 2)),((4.5 4.5 2.5,4 4 2,4.5 3.5 2.5,4.5 4.5 2.5)),((4.5 4.5 2.5,4 5 2,4 4 2,4.5 4.5 2.5)),((3 3 3,0 4 2,1 3 3,3 3 3)),((3.5 2.5 3.5,4.5 3.5 2.5,3 3 3,3.5 2.5 3.5)),((3 3 3,4 4 2,0 4 2,3 3 3)),((4.5 3.5 2.5,4 4 2,3 3 3,4.5 3.5 2.5)),((2 1 2,1 1 2,0.5 0.5 2.5,2 1 2)),((2.5 0.5 2.5,2 1 2,0.5 0.5 2.5,2.5 0.5 2.5)),((1 1 2,1 2 2,0.5 2.5 2.5,1 1 2)),((0.5 0.5 2.5,1 1 2,0.5 2.5 2.5,0.5 0.5 2.5)),((1 3 3,2 2 2,3 3 3,1 3 3)),((0.5 2.5 2.5,1 2 2,1 3 3,0.5 2.5 2.5)),((1 3 3,1 2 2,2 2 2,1 3 3)),((2 2 2,2 1 2,2.5 0.5 2.5,2 2 2)),((3.5 2.5 3.5,3 3 3,3.5 1.5 3.5,3.5 2.5 3.5)),((3.5 1.5 3.5,2 2 2,2.5 0.5 2.5,3.5 1.5 3.5)),((3 3 3,2 2 2,3.5 1.5 3.5,3 3 3)))
+Extrude building and roof|t
Summary of changes:
doc/reference_sfcgal.xml | 2 +-
sfcgal/regress/extrudestraigthskeleton.sql | 41 ++++++++++++++++++++++++-
sfcgal/regress/extrudestraigthskeleton_expected | 2 +-
3 files changed, 42 insertions(+), 3 deletions(-)
hooks/post-receive
