[SCM] PostGIS branch master updated. 3.5.0-366-ge004ebcdd
Wed Jun 4 12:44:32 PDT 2025
the project "PostGIS".
       via  e004ebcdd6f4fc08bc46661c10dd6dc6d46130e3 (commit)
      from  2934d7745e5b0d64007cdaa85739d7a01f452ed7 (commit)
revisions in full, below.
commit e004ebcdd6f4fc08bc46661c10dd6dc6d46130e3
Author: Regina Obe <lr at pcorp.us>
Date:   Wed Jun 4 15:25:59 2025 -0400
    Fix & last_release_version; xml entity in Swedish translation
diff --git a/doc/po/sv/postgis-manual.po b/doc/po/sv/postgis-manual.po
index 3ff665d27..daab625ef 100644
--- a/doc/po/sv/postgis-manual.po
+++ b/doc/po/sv/postgis-manual.po
@@ -9058,7 +9058,7 @@ msgid ""
 "Installing using `unpackaged` was removed in PostgreSQL 13, so you are "
 "advised to switch to an extension build before upgrading to PostgreSQL 13."
 msgstr ""
-"Om du installerade & last_release_version;, utan att använda vårt underbara "
+"Om du installerade &last_release_version;, utan att använda vårt underbara "
 "förlängningssystem, kan du ändra det till att vara förlängningsbaserat genom "
 "att köra kommandona nedan för att paketera funktionerna i deras respektive "
 "förlängning. Installation med `unpackaged` togs bort i PostgreSQL 13, så du "
Summary of changes:
 doc/po/sv/postgis-manual.po | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
hooks/post-receive
