[SCM] PostGIS branch stable-3.1 updated. 3.1.11-27-g835779081
Wed Jun 4 11:14:31 PDT 2025
the project "PostGIS".
The branch, stable-3.1 has been updated
       via  835779081be4d9228a427d3c3e4aad90cf14e12b (commit)
      from  7f7eed125ec1f953d1dc14e09eaedb170881e01f (commit)
revisions in full, below.
commit 835779081be4d9228a427d3c3e4aad90cf14e12b
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Wed Jun 4 11:13:30 2025 -0700
    Allow use of PCRE2 in address standardizer for packaging on
    systems with more modern libraries and compilers.
diff --git a/NEWS b/NEWS
index 39f3e3dfa..c07347e89 100644
--- a/NEWS
+++ b/NEWS
@@ -7,6 +7,7 @@ YYYY/MM/DD
  - #5876, Fix ST_AddPoint with empty point argument (Paul Ramsey)
  - #5818, GT-244 Fix CG_IsSolid function (Loïc Bartoletti)
  - #5885, Fix documentation about grid-based overlay operations (Sandro Santilli)
+ - PCRE2 support for more modern systems (Paul Ramsey)
 PostGIS 3.1.12
diff --git a/configure.ac b/configure.ac
index d6151e51f..12bd64900 100644
--- a/configure.ac
+++ b/configure.ac
@@ -1178,7 +1178,9 @@ AC_ARG_WITH([address-standardizer],
                     [Disable the address_standardizer extension])],
-HAVE_PCRE=no
+HAVE_PCRE1=no
+HAVE_PCRE2=no
+PCRE_SUPPORT="not found"
 ADDRESS_STANDARDIZER=""
 if test "x$with_address_standardizer" != "xno"; then
@@ -1197,42 +1199,74 @@ if test "x$with_address_standardizer" != "xno"; then
             AC_MSG_ERROR([you must specify a parameter to --with-pcredir, e.g. --with-pcredir=/path/to])
         else
             if test -d "$PCREDIR"; then
-                AC_MSG_RESULT([Using user-specified PCRE directory: $PCREDIR])
+                AC_MSG_CHECKING([for PCRE in $PCREDIR...])
-                AC_CHECK_FILE("$PCREDIR/include/pcre.h",
+                AC_CHECK_FILE("$PCREDIR/include/pcre2.h",
+                        PCRE_CPPFLAGS="-I$PCREDIR/include"
+                        PCRE_LDFLAGS="-L$PCREDIR/lib -lpcre2-8"
+                        HAVE_PCRE2=yes
+                        ADDRESS_STANDARDIZER="address_standardizer"
+                        AC_MSG_RESULT([found pcre2.h])
+                        AC_CHECK_FILE("$PCREDIR/include/pcre.h",
-                            PCRE_CPPFLAGS="-I$PCREDIR/include"
-                            PCRE_LDFLAGS="-L$PCREDIR/lib -lpcre"
-                            HAVE_PCRE=yes
-                            ADDRESS_STANDARDIZER="address_standardizer"
+	                          PCRE_LDFLAGS="-L$PCREDIR/lib -lpcre"
+	                          HAVE_PCRE1=yes
+                            AC_MSG_RESULT([found pcre.h])
-                        [AC_MSG_ERROR([Could not find header: pcre.h])])
+                            AC_MSG_RESULT([no])
+                            AC_MSG_ERROR(["Could not find PCRE header in $PCREDIR/include"])
             else
                 AC_MSG_ERROR([the --with-pcredir directory "$PCREDIR" cannot be found])
             fi
         fi
     elif test ! -z "$PKG_CONFIG"; then
-	PKG_CHECK_MODULES([PCRE], [libpcre], [
+        PKG_CHECK_MODULES([PCRE2], [libpcre2-8], [
+            PCRE_CPPFLAGS="$PCRE2_CFLAGS"
+            PCRE_LDFLAGS="$PCRE2_LIBS"
+            HAVE_PCRE2=yes
+            PKG_CHECK_MODULES([PCRE], [libpcre], [
                 PCRE_CPPFLAGS="$PCRE_CFLAGS"
                 PCRE_LDFLAGS="$PCRE_LIBS"
-                HAVE_PCRE=yes
+                HAVE_PCRE1=yes
-                HAVE_PCRE=no
+    fi
+    if test "x$HAVE_PCRE2" = "xyes"; then
+        PCRE_SUPPORT="Version 2"
+        PCRE_VERSION=2
+    elif test "x$HAVE_PCRE1" = "xyes"; then
+        PCRE_SUPPORT="Version 1"
+        PCRE_VERSION=1
+    else
+        ADDRESS_STANDARDIZER=""
+        PCRE_SUPPORT="not found"
+        PCRE_VERSION=0
+        AC_MSG_RESULT([ADDRESS_STANDARDIZER support: disabled])
     fi
     AC_SUBST([PCRE_CPPFLAGS])
     AC_SUBST([PCRE_LDFLAGS])
+    AC_SUBST([PCRE_VERSION])
 else
 fi
-AC_SUBST([HAVE_PCRE])
 AC_SUBST([ADDRESS_STANDARDIZER])
 CPPFLAGS="$PGSQL_CPPFLAGS $GEOS_CPPFLAGS $PROJ_CPPFLAGS $PROTOBUF_CPPFLAGS $XML2_CPPFLAGS $SFCGAL_CPPFLAGS $JSON_CPPFLAGS $PCRE_CPPFLAGS $CPPFLAGS"
@@ -1655,7 +1689,7 @@ if test "x$HAVE_PROTOBUF" = "xyes"; then
   AC_MSG_RESULT([  protobuf-c version:   ${PROTOC_VERSION}])
 fi
-AC_MSG_RESULT([  PCRE support:         ${HAVE_PCRE}])
+AC_MSG_RESULT([  PCRE support:         ${PCRE_SUPPORT}])
 AC_MSG_RESULT([  Perl:                 ${PERL}])
 AC_MSG_RESULT([  Wagyu:                ${HAVE_WAGYU}])
diff --git a/extensions/address_standardizer/Makefile.in b/extensions/address_standardizer/Makefile.in
index 3c64b47df..62ab3f60c 100644
--- a/extensions/address_standardizer/Makefile.in
+++ b/extensions/address_standardizer/Makefile.in
@@ -55,7 +55,8 @@ EXTRA_CLEAN = sql/
 DOCS = README.address_standardizer
-PG_CPPFLAGS = @CFLAGS@ @CPPFLAGS@
+PG_CPPFLAGS = @CFLAGS@ @CPPFLAGS@ -DPCRE_VERSION=@PCRE_VERSION@
 SHLIB_LINK = @SHLIB_LINK@ @PCRE_LDFLAGS@
 EXTRA_CLEAN = usps-st-city-name.txt mk-st-regexp mk-city-regex test_main
diff --git a/extensions/address_standardizer/parseaddress-api.c b/extensions/address_standardizer/parseaddress-api.c
index d5008c3f7..b426d39e5 100644
--- a/extensions/address_standardizer/parseaddress-api.c
+++ b/extensions/address_standardizer/parseaddress-api.c
@@ -20,7 +20,16 @@
 #include <string.h>
 #include <ctype.h>
 #include <stdio.h>
-#include <pcre.h>
+#if PCRE_VERSION <= 1
+# include <pcre.h>
+# define PARSE_CASELESS PCRE_CASELESS
+#else
+# define PCRE2_CODE_UNIT_WIDTH 8
+# include <pcre2.h>
+# define PARSE_CASELESS PCRE2_CASELESS
+#endif
 #include "parseaddress-api.h"
 #undef DEBUG
@@ -28,7 +37,7 @@
 #ifdef DEBUG
 #define DBG(format, arg...)                     \
-    elog(NOTICE, format , ## arg)
+	elog(NOTICE, format , ## arg)
 #else
 #define DBG(format, arg...) do { ; } while (0)
 #endif
@@ -39,72 +48,113 @@ char *clean_leading_punct(char *s);
 const char *get_state_regex(char *st)
-    int i;
-    int cmp;
+	int i;
+	int cmp;
 #include "parseaddress-stcities.h"
-    if (!st || strlen(st) != 2) return NULL;
+	if (!st || strlen(st) != 2) return NULL;
-    for (i=0; i<NUM_STATES; i++) {
-        cmp = strcmp(states[i], st);
-        if (cmp == 0)
-            return stcities[i];
-        else if (cmp > 0)
-            return NULL;
-    return NULL;
+	for (i=0; i<NUM_STATES; i++) {
+		cmp = strcmp(states[i], st);
+		if (cmp == 0)
+			return stcities[i];
+		else if (cmp > 0)
+			return NULL;
+	return NULL;
 int clean_trailing_punct(char *s)
-    size_t i;
-    int ret = 0;
+	size_t i;
+	int ret = 0;
-    i=strlen(s)-1;
-    while (ispunct(s[i]) || isspace(s[i])) {
-        if (s[i] == ',') ret = 1;
-        s[i--] = '\0';
-    return ret;
+	i=strlen(s)-1;
+	while (ispunct(s[i]) || isspace(s[i])) {
+		if (s[i] == ',') ret = 1;
+		s[i--] = '\0';
+	return ret;
-    size_t i;
+	size_t i;
-    for (i=0; i<strlen(s); i++)
-        if (!(ispunct(s[i]) || isspace(s[i])))
-            break;
+	for (i=0; i<strlen(s); i++)
+		if (!(ispunct(s[i]) || isspace(s[i])))
+			break;
-    return s + i;
+	return s + i;
 void strtoupper(char *s)
-    size_t i;
+	size_t i;
-        s[i] = toupper(s[i]);
+		s[i] = toupper(s[i]);
 int match(char *pattern, char *s, int *ovect, int options)
-    const char *error;
-    int erroffset;
-    pcre *re;
-    int rc;
+	const char *error;
+	int erroffset;
+	pcre *re;
+	int rc;
-    re = pcre_compile(pattern, options, &error, &erroffset, NULL);
-    if (!re) return -99;
+	re = pcre_compile(pattern, options, &error, &erroffset, NULL);
+	if (!re) return -99;
-    rc = pcre_exec(re, NULL, s, strlen(s), 0, 0, ovect, OVECCOUNT);
-    free(re);
+	rc = pcre_exec(re, NULL, s, strlen(s), 0, 0, ovect, OVECCOUNT);
+	free(re);
-    if (rc < 0) return rc;
-    else if (rc == 0) rc = OVECCOUNT/3;
+	if (rc < 0) return rc;
+	else if (rc == 0) rc = OVECPAIRS; // more matches than ovect can hold
-    return rc;
+	return rc;
+#else
+int match(char *pattern, char *s, int *ovect, int options)
+	int errorcode;
+	PCRE2_SIZE erroffset;
+	pcre2_code *re;
+	int rc;
+	pcre2_match_data *match_data;
+	PCRE2_SIZE *ovect2;
+	int i;
+	re = pcre2_compile((PCRE2_SPTR8)pattern, PCRE2_ZERO_TERMINATED, options, &errorcode, &erroffset, NULL);
+	match_data = pcre2_match_data_create(OVECPAIRS, NULL);
+	rc = pcre2_match(re, (PCRE2_SPTR8)s, strlen(s), 0, 0, match_data, NULL);
+	if (rc < 0) { // no match or error
+		pcre2_code_free(re);
+		pcre2_match_data_free(match_data);
+		return rc;
+	if (rc == 0) { // more matches than ovect can hold
+		rc = OVECPAIRS;
+	// copy the results out so we can free everything
+	// before returning
+	ovect2 = pcre2_get_ovector_pointer(match_data);
+	for (i = 0; i < rc; i++) {
+		ovect[2*i] = ovect2[2*i];
+		ovect[2*i + 1] = ovect2[2*i + 1];
+	return rc;
+#endif
 #define RET_ERROR(a,e) if (!a) {*reterr = e; return NULL;}
@@ -113,412 +163,414 @@ ADDRESS *parseaddress(HHash *stH, char *s, int *reterr)
 #include "parseaddress-regex.h"
-    int ovect[OVECCOUNT];
-    char c;
-    char *stregx;
-    char *caregx;
-    char *state = NULL;
-    char *regx;
-    int mi;
-    size_t ui, uj;
-    int rc;
-    int comma = 0;
-    ADDRESS *ret;
+	int ovect[OVECCOUNT];
+	char c;
+	char *stregx;
+	char *caregx;
+	char *state = NULL;
+	char *regx;
+	int mi;
+	size_t ui, uj;
+	int rc;
+	int comma = 0;
+	ADDRESS *ret;
 #ifdef USE_HSEARCH
-    ENTRY e, *ep;
-    int err;
+	ENTRY e, *ep;
+	int err;
 #else
-    char *key;
-    char *val;
+	char *key;
+	char *val;
 #endif
-    ret = (ADDRESS *) palloc0(sizeof(ADDRESS));
+	(void)mi;
+	(void)comma;
+	ret = (ADDRESS *) palloc0(sizeof(ADDRESS));
-    /* check if we were passed a lat lon */
-    rc = match("^\\s*([-+]?\\d+(\\.\\d*)?)[\\,\\s]+([-+]?\\d+(\\.\\d*)?)\\s*$", s, ovect, 0);
-    if (rc >= 3) {
-        *(s+ovect[3]) = '\0';
-        ret->lat = strtod(s+ovect[2], NULL);
-        ret->lon = strtod(s+ovect[6], NULL);
-        return ret;
+	/* check if we were passed a lat lon */
+	rc = match("^\\s*([-+]?\\d+(\\.\\d*)?)[\\,\\s]+([-+]?\\d+(\\.\\d*)?)\\s*$", s, ovect, 0);
+	if (rc >= 3) {
+		*(s+ovect[3]) = '\0';
+		ret->lat = strtod(s+ovect[2], NULL);
+		ret->lon = strtod(s+ovect[6], NULL);
+		return ret;
-    /* clean the string of multiple white spaces and . */
+	/* clean the string of multiple white spaces and . */
-    for (ui=0, uj=0; ui<strlen(s); ui++) {
-        c = s[ui];
-        if (c == '.') c = s[ui] = ' ';
-        if (uj == 0 && isspace(c)) continue;
-        if (ui && isspace(c) && isspace(s[ui-1])) continue;
-        s[uj] = s[ui];
-        uj++;
-    if (isspace(s[uj-1])) uj--;
-    s[uj] = '\0';
+	for (ui=0, uj=0; ui<strlen(s); ui++) {
+		c = s[ui];
+		if (c == '.') c = s[ui] = ' ';
+		if (uj == 0 && isspace(c)) continue;
+		if (ui && isspace(c) && isspace(s[ui-1])) continue;
+		s[uj] = s[ui];
+		uj++;
+	if (isspace(s[uj-1])) uj--;
+	s[uj] = '\0';
-    /* clean trailing punctuation */
-    comma |= clean_trailing_punct(s);
+	/* clean trailing punctuation */
+	comma |= clean_trailing_punct(s);
-    /* assume country code is US */
+	/* assume country code is US */
-    ret->cc  = (char *) palloc0(3 * sizeof(char));
-    strcpy(ret->cc, "US");
+	ret->cc  = (char *) palloc0(3 * sizeof(char));
+	strcpy(ret->cc, "US");
-    /* get US zipcode components */
+	/* get US zipcode components */
-    rc = match("\\b(\\d{5})[-\\s]{0,1}?(\\d{0,4})?$", s, ovect, 0);
-    if (rc >= 2) {
-        ret->zip = (char *) palloc0((ovect[3]-ovect[2]+1) * sizeof(char));
-        strncpy(ret->zip, s+ovect[2], ovect[3]-ovect[2]);
-        if (rc >= 3) {
-            ret->zipplus = (char *) palloc0((ovect[5]-ovect[4]+1) * sizeof(char));
-            strncpy(ret->zipplus, s+ovect[4], ovect[5]-ovect[4]);
-        /* truncate the postalcode off the string */
-        *(s+ovect[0]) = '\0';
-        comma = 0;
-    /* get canada zipcode components */
-    else {
-        rc = match("\\b([a-z]\\d[a-z]\\s?\\d[a-z]\\d)$", s, ovect, PCRE_CASELESS);
-        if (rc >= 1) {
-            ret->zip = (char *) palloc0((ovect[1]-ovect[0]+1) * sizeof(char));
-            strncpy(ret->zip, s+ovect[0], ovect[1]-ovect[0]);
-            strcpy(ret->cc, "CA");
-            comma = 0;
+	rc = match("\\b(\\d{5})[-\\s]{0,1}?(\\d{0,4})?$", s, ovect, 0);
+	if (rc >= 2) {
+		ret->zip = (char *) palloc0((ovect[3]-ovect[2]+1) * sizeof(char));
+		strncpy(ret->zip, s+ovect[2], ovect[3]-ovect[2]);
+		if (rc >= 3) {
+			ret->zipplus = (char *) palloc0((ovect[5]-ovect[4]+1) * sizeof(char));
+			strncpy(ret->zipplus, s+ovect[4], ovect[5]-ovect[4]);
+		/* truncate the postalcode off the string */
+		*(s+ovect[0]) = '\0';
+		comma = 0;
+	/* get canada zipcode components */
+	else {
+		rc = match("\\b([a-z]\\d[a-z]\\s?\\d[a-z]\\d)$", s, ovect, PARSE_CASELESS);
+		if (rc >= 1) {
+			ret->zip = (char *) palloc0((ovect[1]-ovect[0]+1) * sizeof(char));
+			strncpy(ret->zip, s+ovect[0], ovect[1]-ovect[0]);
+			strcpy(ret->cc, "CA");
+			comma = 0;
-    /* get state components */
+	/* get state components */
-    caregx = "^(?-xism:(?i:(?=[abmnopqsy])(?:n[ltsu]|[am]b|[bq]c|on|pe|sk|yt)))$";
-    stregx = "\\b(?-xism:(?i:(?=[abcdfghiklmnopqrstuvwy])(?:a(?:l(?:a(?:bam|sk)a|berta)?|mer(?:ican)?\\ samoa|r(?:k(?:ansas)?|izona)?|[kszb])|s(?:a(?:moa|skatchewan)|outh\\ (?:carolin|dakot)a|\\ (?:carolin|dakot)a|[cdk])|c(?:a(?:lif(?:ornia)?)?|o(?:nn(?:ecticut)?|lorado)?|t)|d(?:e(?:la(?:ware)?)?|istrict\\ of\\ columbia|c)|f(?:l(?:(?:orid)?a)?|ederal\\ states\\ of\\ micronesia|m)|m(?:i(?:c(?:h(?:igan)?|ronesia)|nn(?:esota)?|ss(?:(?:issipp|our)i)?)?|a(?:r(?:shall(?:\\ is(?:l(?:and)?)?)?|yland)|ss(?:achusetts)?|ine|nitoba)?|o(?:nt(?:ana)?)?|[ehdnstpb])|g(?:u(?:am)?|(?:eorgi)?a)|h(?:awai)?i|i(?:d(?:aho)?|l(?:l(?:inois)?)?|n(?:d(?:iana)?)?|(?:ow)?a)|k(?:(?:ansa)?s|(?:entuck)?y)|l(?:a(?:bordor)?|ouisiana)|n(?:e(?:w(?:\\ (?:foundland(?:\\ and\\ labordor)?|hampshire|jersey|mexico|(?:yor|brunswic)k)|foundland)|(?:brask|vad)a)?|o(?:rth(?:\\ (?:mariana(?:\\ is(?:l(?:and)?)?)?|(?:carolin|dakot)a)|west\\ territor(?:ies|y))|va\\ scotia)|\\ (?:carolin|dakot)a|u(?:navut)?|[vhjmycdblsf]|w?t)|o(?:h(
 ?:io)?|k(?:lahoma)?|r(?:egon)?|n(?:t(?:ario)?)?)|p(?:a(?:lau)?|e(?:nn(?:sylvania)?|i)?|r(?:ince\\ edward\\ island)?|w|uerto\\ rico)|r(?:hode\\ island|i)|t(?:e(?:nn(?:essee)?|xas)|[nx])|ut(?:ah)?|v(?:i(?:rgin(?:\\ islands|ia))?|(?:ermon)?t|a)|w(?:a(?:sh(?:ington)?)?|i(?:sc(?:onsin)?)?|y(?:oming)?|(?:est)?\\ virginia|v)|b(?:ritish\\ columbia|c)|q(?:uebe)?c|y(?:ukon|t))))$";
+	caregx = "^(?-xism:(?i:(?=[abmnopqsy])(?:n[ltsu]|[am]b|[bq]c|on|pe|sk|yt)))$";
+	stregx = "\\b(?-xism:(?i:(?=[abcdfghiklmnopqrstuvwy])(?:a(?:l(?:a(?:bam|sk)a|berta)?|mer(?:ican)?\\ samoa|r(?:k(?:ansas)?|izona)?|[kszb])|s(?:a(?:moa|skatchewan)|outh\\ (?:carolin|dakot)a|\\ (?:carolin|dakot)a|[cdk])|c(?:a(?:lif(?:ornia)?)?|o(?:nn(?:ecticut)?|lorado)?|t)|d(?:e(?:la(?:ware)?)?|istrict\\ of\\ columbia|c)|f(?:l(?:(?:orid)?a)?|ederal\\ states\\ of\\ micronesia|m)|m(?:i(?:c(?:h(?:igan)?|ronesia)|nn(?:esota)?|ss(?:(?:issipp|our)i)?)?|a(?:r(?:shall(?:\\ is(?:l(?:and)?)?)?|yland)|ss(?:achusetts)?|ine|nitoba)?|o(?:nt(?:ana)?)?|[ehdnstpb])|g(?:u(?:am)?|(?:eorgi)?a)|h(?:awai)?i|i(?:d(?:aho)?|l(?:l(?:inois)?)?|n(?:d(?:iana)?)?|(?:ow)?a)|k(?:(?:ansa)?s|(?:entuck)?y)|l(?:a(?:bordor)?|ouisiana)|n(?:e(?:w(?:\\ (?:foundland(?:\\ and\\ labordor)?|hampshire|jersey|mexico|(?:yor|brunswic)k)|foundland)|(?:brask|vad)a)?|o(?:rth(?:\\ (?:mariana(?:\\ is(?:l(?:and)?)?)?|(?:carolin|dakot)a)|west\\ territor(?:ies|y))|va\\ scotia)|\\ (?:carolin|dakot)a|u(?:navut)?|[vhjmycdblsf]|w?t)|o(?:h(?:i
-    rc = match(stregx, s, ovect, PCRE_CASELESS);
-    if (rc > 0) {
-        state = (char *) palloc0((ovect[1]-ovect[0]+1) * sizeof(char));
-        strncpy(state, s+ovect[0], ovect[1]-ovect[0]);
+	rc = match(stregx, s, ovect, PARSE_CASELESS);
+	if (rc > 0) {
+		state = (char *) palloc0((ovect[1]-ovect[0]+1) * sizeof(char));
+		strncpy(state, s+ovect[0], ovect[1]-ovect[0]);
-        /* truncate the state/province off the string */
+		/* truncate the state/province off the string */
-        /* lookup state in hash and get abbreviation */
-        strtoupper(state);
+		/* lookup state in hash and get abbreviation */
+		strtoupper(state);
 #ifdef USE_HSEARCH
-        e.key = state;
-        err = hsearch_r(e, FIND, &ep, stH);
-        if (err) {
-            ret->st = (char *) palloc0(3 * sizeof(char));
-            strcpy(ret->st, ep->data);
+		e.key = state;
+		err = hsearch_r(e, FIND, &ep, stH);
+		if (err) {
+			ret->st = (char *) palloc0(3 * sizeof(char));
+			strcpy(ret->st, ep->data);
 #else
-        key = state;
-        val = (char *)hash_get(stH, key);
-        if (val) {
-            ret->st = pstrdup(val);
+		key = state;
+		val = (char *)hash_get(stH, key);
+		if (val) {
+			ret->st = pstrdup(val);
 #endif
-        else {
-            *reterr = 1002;
-            return NULL;
+		else {
+			*reterr = 1002;
+			return NULL;
-        /* check if it a Canadian Province */
-        rc = match(caregx, ret->st, ovect, PCRE_CASELESS);
-        if (rc > 0) {
-            // if (ret->cc) printf("  CC: %s\n", ret->cc);
-        comma = 0;
+		/* check if it a Canadian Province */
+		rc = match(caregx, ret->st, ovect, PARSE_CASELESS);
+		if (rc > 0) {
+			// if (ret->cc) printf("  CC: %s\n", ret->cc);
+		comma = 0;
-    /* get city components */
+	/* get city components */
-     * This part is ambiguous without punctuation after the street
-     * because we can have any of the following forms:
-     * num predir? prefixtype? street+ suffixtype? suffdir?,
-     *     ((north|south|east|west)? city)? state? zip?
-     * and technically num can be of the form:
-     *   pn1? n1 pn2? n2? sn2?
-     * where
-     * pn1 is a prefix character
-     * n1  is a number
-     * pn2 is a prefix character
-     * n2  is a number
-     * sn2 is a suffix character
-     * and a trailing letter might be [NSEW] which predir can also be
-     * So it is ambigious whether a directional between street and city
-     * belongs to which component. Futher since the the street and the city
-     * are both just a string of arbitrary words, it is difficult if not
-     * impossible to determine if an give word belongs to sone side or the
-     * other.
-     * So for the best results users should include a comma after the street.
-     * The approach will be as follows:
-     *   1. look for a comma and assume this is the separator
-     *   2. if we can find a state specific regex try that
-     *   3. else loop through an array of possible regex patterns
-     *   4. fail and assume there is not city
+	 * This part is ambiguous without punctuation after the street
+	 * because we can have any of the following forms:
+	 * num predir? prefixtype? street+ suffixtype? suffdir?,
+	 *     ((north|south|east|west)? city)? state? zip?
+	 * and technically num can be of the form:
+	 *   pn1? n1 pn2? n2? sn2?
+	 * where
+	 * pn1 is a prefix character
+	 * n1  is a number
+	 * pn2 is a prefix character
+	 * n2  is a number
+	 * sn2 is a suffix character
+	 * and a trailing letter might be [NSEW] which predir can also be
+	 * So it is ambigious whether a directional between street and city
+	 * belongs to which component. Futher since the the street and the city
+	 * are both just a string of arbitrary words, it is difficult if not
+	 * impossible to determine if an give word belongs to sone side or the
+	 * other.
+	 * So for the best results users should include a comma after the street.
+	 * The approach will be as follows:
+	 *   1. look for a comma and assume this is the separator
+	 *   2. if we can find a state specific regex try that
+	 *   3. else loop through an array of possible regex patterns
+	 *   4. fail and assume there is not city
-    /* look for a comma */
-    DBG("parse_address: s=%s", s);
-    mi = 0;
+	/* look for a comma */
+	DBG("parse_address: s=%s", s);
+	mi = 0;
-    regx = "(?:,\\s*)([^,]+)$";
-    rc = match((char *)regx, s, ovect, 0);
-    if (rc <= 0) {
-        /* look for state specific regex */
-        mi++;
-        regx = (char *) get_state_regex(ret->st);
-        if (regx)
-    DBG("Checked for comma: %d", rc);
-    if (rc <= 0 && ret->st && strlen(ret->st)) {
-        mi++;
-        if (regx)
-    DBG("Checked for state-city: %d", rc);
-    if (rc <= 0) {
-        int i;
-        /* run through the regx's and see if we get a match */
-        for (i=0; i<nreg; i++) {
-            mi++;
-            rc = match((char *)t_regx[i], s, ovect, 0);
-            DBG("    rc=%d, i=%d", rc, i);
-            if (rc > 0) break;
-        DBG("rc=%d, i=%d", rc, i);
-    DBG("Checked regexs: %d, %d, %d", rc, ovect[2], ovect[3]);
-    if (rc > 0 && ovect[3]>ovect[2]) {
-        /* we have a match so process it */
-        ret->city = (char *) palloc0((ovect[3]-ovect[2]+1) * sizeof(char));
-        strncpy(ret->city, s+ovect[2], ovect[3]-ovect[2]);
-        *(s+ovect[2]) = '\0';
+	regx = "(?:,\\s*)([^,]+)$";
+	rc = match((char *)regx, s, ovect, 0);
+	if (rc <= 0) {
+		/* look for state specific regex */
+		mi++;
+		regx = (char *) get_state_regex(ret->st);
+		if (regx)
+	DBG("Checked for comma: %d", rc);
+	if (rc <= 0 && ret->st && strlen(ret->st)) {
+		mi++;
+		if (regx)
+	DBG("Checked for state-city: %d", rc);
+	if (rc <= 0) {
+		int i;
+		/* run through the regx's and see if we get a match */
+		for (i=0; i<nreg; i++) {
+			mi++;
+			rc = match((char *)t_regx[i], s, ovect, 0);
+			DBG("    rc=%d, i=%d", rc, i);
+			if (rc > 0) break;
+		DBG("rc=%d, i=%d", rc, i);
+	DBG("Checked regexs: %d, %d, %d", rc, ovect[2], ovect[3]);
+	if (rc > 0 && ovect[3]>ovect[2]) {
+		/* we have a match so process it */
+		ret->city = (char *) palloc0((ovect[3]-ovect[2]+1) * sizeof(char));
+		strncpy(ret->city, s+ovect[2], ovect[3]-ovect[2]);
+		*(s+ovect[2]) = '\0';
-    clean_trailing_punct(s);
+	clean_trailing_punct(s);
-    /* check for [@] that would indicate a intersection */
-    /* -- 2010-12-11 : per Nancy R. we are using @ to indicate an intersection
-       ampersand is used in both street names and landmarks so it is highly
-       ambiguous -- */
-    rc = match("^([^@]+)\\s*[@]\\s*([^@]+)$", s, ovect, 0);
-    if (rc > 0) {
-        s[ovect[3]] = '\0';
-        clean_trailing_punct(s+ovect[2]);
-        ret->street = pstrdup(s+ovect[2]);
+	/* check for [@] that would indicate a intersection */
+	/* -- 2010-12-11 : per Nancy R. we are using @ to indicate an intersection
+	   ampersand is used in both street names and landmarks so it is highly
+	   ambiguous -- */
+	rc = match("^([^@]+)\\s*[@]\\s*([^@]+)$", s, ovect, 0);
+	if (rc > 0) {
+		s[ovect[3]] = '\0';
+		clean_trailing_punct(s+ovect[2]);
+		ret->street = pstrdup(s+ovect[2]);
-        s[ovect[5]] = '\0';
-        clean_leading_punct(s+ovect[4]);
-        ret->street2 = pstrdup(s+ovect[4]);
-    else {
+		s[ovect[5]] = '\0';
+		clean_leading_punct(s+ovect[4]);
+		ret->street2 = pstrdup(s+ovect[4]);
+	else {
-        /* and the remainder must be the address components */
-        ret->address1 = pstrdup(clean_leading_punct(s));
+		/* and the remainder must be the address components */
+		ret->address1 = pstrdup(clean_leading_punct(s));
-        /* split the number off the street if it exists */
-        rc = match("^((?i)[nsew]?\\d+[-nsew]*\\d*[nsew]?\\b)", s, ovect, 0);
-        if (rc > 0) {
-            ret->num = (char *) palloc0((ovect[1]-ovect[0]+1) * sizeof(char));
-            strncpy(ret->num, s, ovect[1]-ovect[0]);
-            ret->street = pstrdup(clean_leading_punct(s+ovect[1]));
+		/* split the number off the street if it exists */
+		rc = match("^((?i)[nsew]?\\d+[-nsew]*\\d*[nsew]?\\b)", s, ovect, 0);
+		if (rc > 0) {
+			ret->num = (char *) palloc0((ovect[1]-ovect[0]+1) * sizeof(char));
+			strncpy(ret->num, s, ovect[1]-ovect[0]);
+			ret->street = pstrdup(clean_leading_punct(s+ovect[1]));
-    return ret;
+	return ret;
 int load_state_hash(HHash *stH)
-    char * words[][2] = {
-        {"ALABAMA"                      , "AL"},
-        {"ALASKA"                       , "AK"},
-        {"AMERICAN SAMOA"               , "AS"},
-        {"AMER SAMOA"                   , "AS"},
-        {"SAMOA"                        , "AS"},
-        {"ARIZONA"                      , "AZ"},
-        {"ARKANSAS"                     , "AR"},
-        {"ARK"                          , "AR"},
-        {"CALIFORNIA"                   , "CA"},
-        {"CALIF"                        , "CA"},
-        {"COLORADO"                     , "CO"},
-        {"CONNECTICUT"                  , "CT"},
-        {"CONN"                         , "CT"},
-        {"DELAWARE"                     , "DE"},
-        {"DELA"                         , "DE"},
-        {"DISTRICT OF COLUMBIA"         , "DC"},
-        {"FEDERAL STATES OF MICRONESIA" , "FM"},
-        {"MICRONESIA"                   , "FM"},
-        {"FLORIDA"                      , "FL"},
-        {"FLA"                          , "FL"},
-        {"GEORGIA"                      , "GA"},
-        {"GUAM"                         , "GU"},
-        {"HAWAII"                       , "HI"},
-        {"IDAHO"                        , "ID"},
-        {"ILLINOIS"                     , "IL"},
-        {"ILL"                          , "IL"},
-        {"INDIANA"                      , "IN"},
-        {"IND"                          , "IN"},
-        {"IOWA"                         , "IA"},
-        {"KANSAS"                       , "KS"},
-        {"KENTUCKY"                     , "KY"},
-        {"LOUISIANA"                    , "LA"},
-        {"MAINE"                        , "ME"},
-        {"MARSHALL ISLAND"              , "MH"},
-        {"MARSHALL ISL"                 , "MH"},
-        {"MARSHALL IS"                  , "MH"},
-        {"MARSHALL"                     , "MH"},
-        {"MARYLAND"                     , "MD"},
-        {"MASSACHUSETTS"                , "MA"},
-        {"MASS"                         , "MA"},
-        {"MICHIGAN"                     , "MI"},
-        {"MICH"                         , "MI"},
-        {"MINNESOTA"                    , "MN"},
-        {"MINN"                         , "MN"},
-        {"MISSISSIPPI"                  , "MS"},
-        {"MISS"                         , "MS"},
-        {"MISSOURI"                     , "MO"},
-        {"MONTANA"                      , "MT"},
-        {"MONT"                         , "MT"},
-        {"NEBRASKA"                     , "NE"},
-        {"NEVADA"                       , "NV"},
-        {"NEW HAMPSHIRE"                , "NH"},
-        {"NEW JERSEY"                   , "NJ"},
-        {"NEW MEXICO"                   , "NM"},
-        {"NEW YORK"                     , "NY"},
-        {"NORTH CAROLINA"               , "NC"},
-        {"N CAROLINA"                   , "NC"},
-        {"NORTH DAKOTA"                 , "ND"},
-        {"N DAKOTA"                     , "ND"},
-        {"NORTH MARIANA ISL"            , "MP"},
-        {"NORTH MARIANA IS"             , "MP"},
-        {"NORTH MARIANA"                , "MP"},
-        {"NORTH MARIANA ISLAND"         , "MP"},
-        {"OHIO"                         , "OH"},
-        {"OKLAHOMA"                     , "OK"},
-        {"OREGON"                       , "OR"},
-        {"PALAU"                        , "PW"},
-        {"PENNSYLVANIA"                 , "PA"},
-        {"PENN"                         , "PA"},
-        {"PUERTO RICO"                  , "PR"},
-        {"RHODE ISLAND"                 , "RI"},
-        {"SOUTH CAROLINA"               , "SC"},
-        {"S CAROLINA"                   , "SC"},
-        {"SOUTH DAKOTA"                 , "SD"},
-        {"S DAKOTA"                     , "SD"},
-        {"TENNESSEE"                    , "TN"},
-        {"TENN"                         , "TN"},
-        {"TEXAS"                        , "TX"},
-        {"UTAH"                         , "UT"},
-        {"VERMONT"                      , "VT"},
-        {"VIRGIN ISLANDS"               , "VI"},
-        {"VIRGINIA"                     , "VA"},
-        {"WASHINGTON"                   , "WA"},
-        {"WASH"                         , "WA"},
-        {"WEST VIRGINIA"                , "WV"},
-        {"W VIRGINIA"                   , "WV"},
-        {"WISCONSIN"                    , "WI"},
-        {"WISC"                         , "WI"},
-        {"WYOMING"                      , "WY"},
-        {"ALBERTA"                      , "AB"},
-        {"BRITISH COLUMBIA"             , "BC"},
-        {"MANITOBA"                     , "MB"},
-        {"NEW BRUNSWICK"                , "NB"},
-        {"NEW FOUNDLAND AND LABORDOR"   , "NL"},
-        {"NEW FOUNDLAND"                , "NL"},
-        {"NEWFOUNDLAND"                 , "NL"},
-        {"LABORDOR"                     , "NL"},
-        {"NORTHWEST TERRITORIES"        , "NT"},
-        {"NORTHWEST TERRITORY"          , "NT"},
-        {"NWT"                          , "NT"},
-        {"NOVA SCOTIA"                  , "NS"},
-        {"NUNAVUT"                      , "NU"},
-        {"ONTARIO"                      , "ON"},
-        {"ONT"                          , "ON"},
-        {"PRINCE EDWARD ISLAND"         , "PE"},
-        {"PEI"                          , "PE"},
-        {"QUEBEC"                       , "QC"},
-        {"SASKATCHEWAN"                 , "SK"},
-        {"YUKON"                        , "YT"},
-        {"NF"                           , "NL"},
-        {NULL, NULL}
+	char * words[][2] = {
+		{"ALABAMA"                      , "AL"},
+		{"ALASKA"                       , "AK"},
+		{"AMERICAN SAMOA"               , "AS"},
+		{"AMER SAMOA"                   , "AS"},
+		{"SAMOA"                        , "AS"},
+		{"ARIZONA"                      , "AZ"},
+		{"ARKANSAS"                     , "AR"},
+		{"ARK"                          , "AR"},
+		{"CALIFORNIA"                   , "CA"},
+		{"CALIF"                        , "CA"},
+		{"COLORADO"                     , "CO"},
+		{"CONNECTICUT"                  , "CT"},
+		{"CONN"                         , "CT"},
+		{"DELAWARE"                     , "DE"},
+		{"DELA"                         , "DE"},
+		{"DISTRICT OF COLUMBIA"         , "DC"},
+		{"FEDERAL STATES OF MICRONESIA" , "FM"},
+		{"MICRONESIA"                   , "FM"},
+		{"FLORIDA"                      , "FL"},
+		{"FLA"                          , "FL"},
+		{"GEORGIA"                      , "GA"},
+		{"GUAM"                         , "GU"},
+		{"HAWAII"                       , "HI"},
+		{"IDAHO"                        , "ID"},
+		{"ILLINOIS"                     , "IL"},
+		{"ILL"                          , "IL"},
+		{"INDIANA"                      , "IN"},
+		{"IND"                          , "IN"},
+		{"IOWA"                         , "IA"},
+		{"KANSAS"                       , "KS"},
+		{"KENTUCKY"                     , "KY"},
+		{"LOUISIANA"                    , "LA"},
+		{"MAINE"                        , "ME"},
+		{"MARSHALL ISLAND"              , "MH"},
+		{"MARSHALL ISL"                 , "MH"},
+		{"MARSHALL IS"                  , "MH"},
+		{"MARSHALL"                     , "MH"},
+		{"MARYLAND"                     , "MD"},
+		{"MASSACHUSETTS"                , "MA"},
+		{"MASS"                         , "MA"},
+		{"MICHIGAN"                     , "MI"},
+		{"MICH"                         , "MI"},
+		{"MINNESOTA"                    , "MN"},
+		{"MINN"                         , "MN"},
+		{"MISSISSIPPI"                  , "MS"},
+		{"MISS"                         , "MS"},
+		{"MISSOURI"                     , "MO"},
+		{"MONTANA"                      , "MT"},
+		{"MONT"                         , "MT"},
+		{"NEBRASKA"                     , "NE"},
+		{"NEVADA"                       , "NV"},
+		{"NEW HAMPSHIRE"                , "NH"},
+		{"NEW JERSEY"                   , "NJ"},
+		{"NEW MEXICO"                   , "NM"},
+		{"NEW YORK"                     , "NY"},
+		{"NORTH CAROLINA"               , "NC"},
+		{"N CAROLINA"                   , "NC"},
+		{"NORTH DAKOTA"                 , "ND"},
+		{"N DAKOTA"                     , "ND"},
+		{"NORTH MARIANA ISL"            , "MP"},
+		{"NORTH MARIANA IS"             , "MP"},
+		{"NORTH MARIANA"                , "MP"},
+		{"NORTH MARIANA ISLAND"         , "MP"},
+		{"OHIO"                         , "OH"},
+		{"OKLAHOMA"                     , "OK"},
+		{"OREGON"                       , "OR"},
+		{"PALAU"                        , "PW"},
+		{"PENNSYLVANIA"                 , "PA"},
+		{"PENN"                         , "PA"},
+		{"PUERTO RICO"                  , "PR"},
+		{"RHODE ISLAND"                 , "RI"},
+		{"SOUTH CAROLINA"               , "SC"},
+		{"S CAROLINA"                   , "SC"},
+		{"SOUTH DAKOTA"                 , "SD"},
+		{"S DAKOTA"                     , "SD"},
+		{"TENNESSEE"                    , "TN"},
+		{"TENN"                         , "TN"},
+		{"TEXAS"                        , "TX"},
+		{"UTAH"                         , "UT"},
+		{"VERMONT"                      , "VT"},
+		{"VIRGIN ISLANDS"               , "VI"},
+		{"VIRGINIA"                     , "VA"},
+		{"WASHINGTON"                   , "WA"},
+		{"WASH"                         , "WA"},
+		{"WEST VIRGINIA"                , "WV"},
+		{"W VIRGINIA"                   , "WV"},
+		{"WISCONSIN"                    , "WI"},
+		{"WISC"                         , "WI"},
+		{"WYOMING"                      , "WY"},
+		{"ALBERTA"                      , "AB"},
+		{"BRITISH COLUMBIA"             , "BC"},
+		{"MANITOBA"                     , "MB"},
+		{"NEW BRUNSWICK"                , "NB"},
+		{"NEW FOUNDLAND AND LABORDOR"   , "NL"},
+		{"NEW FOUNDLAND"                , "NL"},
+		{"NEWFOUNDLAND"                 , "NL"},
+		{"LABORDOR"                     , "NL"},
+		{"NORTHWEST TERRITORIES"        , "NT"},
+		{"NORTHWEST TERRITORY"          , "NT"},
+		{"NWT"                          , "NT"},
+		{"NOVA SCOTIA"                  , "NS"},
+		{"NUNAVUT"                      , "NU"},
+		{"ONTARIO"                      , "ON"},
+		{"ONT"                          , "ON"},
+		{"PRINCE EDWARD ISLAND"         , "PE"},
+		{"PEI"                          , "PE"},
+		{"QUEBEC"                       , "QC"},
+		{"SASKATCHEWAN"                 , "SK"},
+		{"YUKON"                        , "YT"},
+		{"NF"                           , "NL"},
+		{NULL, NULL}
 #ifdef USE_HSEARCH
-    ENTRY e, *ep;
-    int err;
+	ENTRY e, *ep;
+	int err;
 #else
-    char *key;
-    char *val;
+	char *key;
+	char *val;
 #endif
-    int i, cnt;
+	int i, cnt;
-    /* count the entries above */
-    cnt = 0;
-    while (words[cnt][0]) cnt++;
+	/* count the entries above */
+	cnt = 0;
+	while (words[cnt][0]) cnt++;
-    DBG("Words cnt=%d", cnt);
+	DBG("Words cnt=%d", cnt);
 #ifdef USE_HSEARCH
-    if (! hcreate_r(cnt*2, stH)) return 1001;
-    for (i=0; i<cnt; i++) {
-        e.key  = words[i][0];
-        e.data = words[i][1];
-        err = hsearch_r(e, ENTER, &ep, stH);
-        /* there should be no failures */
-        if (!err) return 1003;
-        e.key  = words[i][1];
+	if (! hcreate_r(cnt*2, stH)) return 1001;
+	for (i=0; i<cnt; i++) {
+		e.key  = words[i][0];
+		e.data = words[i][1];
+		err = hsearch_r(e, ENTER, &ep, stH);
+		/* there should be no failures */
+		if (!err) return 1003;
+		e.key  = words[i][1];
 #else
-    if (! stH ) return 1001;
-        //DBG("load_hash i=%d", i);
-        key = words[i][0];
-        val = words[i][1];
-        hash_set(stH, key, (void *)val);
-        key = words[i][1];
+	if (! stH ) return 1001;
+		//DBG("load_hash i=%d", i);
+		key = words[i][0];
+		val = words[i][1];
+		hash_set(stH, key, (void *)val);
+		key = words[i][1];
 #endif
-    return 0;
+	return 0;
 void free_state_hash(HHash *stH)
 //#if 0
 #ifdef USE_HSEARCH
-    if (stH) hdestroy_r(stH);
+	if (stH) hdestroy_r(stH);
 #else
-    if (stH) hash_free(stH);
+	if (stH) hash_free(stH);
 #endif
 //#endif
diff --git a/extensions/address_standardizer/parseaddress-api.h b/extensions/address_standardizer/parseaddress-api.h
index a3773a431..67af25571 100644
--- a/extensions/address_standardizer/parseaddress-api.h
+++ b/extensions/address_standardizer/parseaddress-api.h
@@ -20,7 +20,8 @@ THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLI
 #include "postgres.h"
-#define OVECCOUNT 30
+#define OVECPAIRS 10
+#define OVECCOUNT 3*OVECPAIRS
 #ifdef USE_HSEARCH
@@ -40,17 +41,17 @@ typedef hash_t HHash;
 #endif
 typedef struct address_struct {
-    char *num;
-    char *street;
-    char *street2;
-    char *address1;
-    char *city;
-    char *st;
-    char *zip;
-    char *zipplus;
-    char *cc;
-    double lat;
-    double lon;
+	char *num;
+	char *street;
+	char *street2;
+	char *address1;
+	char *city;
+	char *st;
+	char *zip;
+	char *zipplus;
+	char *cc;
+	double lat;
+	double lon;
 } ADDRESS;
 int clean_trailing_punct(char *s);
diff --git a/extensions/address_standardizer/std_pg_hash.c b/extensions/address_standardizer/std_pg_hash.c
index da2f18974..fbdf17ee4 100644
--- a/extensions/address_standardizer/std_pg_hash.c
+++ b/extensions/address_standardizer/std_pg_hash.c
@@ -623,6 +623,7 @@ static int load_lex(LEXICON *lex, char *tab)
     char *word;
     char *stdword;
     int token;
+    (void)total_tuples;
     DBG("start load_lex\n");
     SET_TIME(t1);
diff --git a/liblwgeom/lwgeom_topo.c b/liblwgeom/lwgeom_topo.c
index d0db04381..f7bd9e481 100644
--- a/liblwgeom/lwgeom_topo.c
+++ b/liblwgeom/lwgeom_topo.c
@@ -5677,6 +5677,7 @@ _lwt_AddLine(LWT_TOPOLOGY* topo, LWLINE* line, double tol, int* nedges,
         lwalloc(nearbycount * sizeof(LWGEOM *))
     int nn = 0;
+    (void)nn;
     for (i=0; i<numnodes; ++i)
       LWT_ISO_NODE *n = &(nodes[i]);
diff --git a/postgis/gserialized_estimate.c b/postgis/gserialized_estimate.c
index bf90432b4..8a1c8d9f5 100644
--- a/postgis/gserialized_estimate.c
+++ b/postgis/gserialized_estimate.c
@@ -727,6 +727,8 @@ nd_box_ratio(const ND_BOX *b1, const ND_BOX *b2, int ndims)
 	double vol2 = 1.0;
 	double vol1 = 1.0;
+	(void)vol1;
 	for ( d = 0 ; d < ndims; d++ )
 		if ( b1->max[d] <= b2->min[d] || b1->min[d] >= b2->max[d] )
@@ -1414,6 +1416,8 @@ compute_gserialized_stats_mode(VacAttrStats *stats, AnalyzeAttrFetchFunc fetchfu
 	int stats_slot;                     /* What slot is this data going into? (2D vs ND) */
 	int stats_kind;                     /* And this is what? (2D vs ND) */
+	(void)total_sample_volume;
 	/* Initialize sum and stddev */
 	nd_box_init(&sum);
 	nd_box_init(&stddev);
Summary of changes:
 NEWS                                               |   1 +
 configure.ac                                       |  66 +-
 extensions/address_standardizer/Makefile.in        |   3 +-
 extensions/address_standardizer/parseaddress-api.c | 890 +++++++++++----------
 extensions/address_standardizer/parseaddress-api.h |  25 +-
 extensions/address_standardizer/std_pg_hash.c      |   1 +
 liblwgeom/lwgeom_topo.c                            |   1 +
 postgis/gserialized_estimate.c                     |   4 +
 8 files changed, 543 insertions(+), 448 deletions(-)
hooks/post-receive
