[SCM] PostGIS branch master updated. 3.5.0-365-g2934d7745
Wed Jun 4 09:52:01 PDT 2025
the project "PostGIS".
       via  2934d7745e5b0d64007cdaa85739d7a01f452ed7 (commit)
      from  32385a5a30fb3fb3fc27da2ffb93c9c2e922db31 (commit)
revisions in full, below.
commit 2934d7745e5b0d64007cdaa85739d7a01f452ed7
Author: Regina Obe <lr at pcorp.us>
Date:   Wed Jun 4 12:51:24 2025 -0400
    Enable swedish testing on woodpecker
diff --git a/.woodpecker/docs.yml b/.woodpecker/docs.yml
index 40a4dc30e..8daaa0871 100644
--- a/.woodpecker/docs.yml
+++ b/.woodpecker/docs.yml
@@ -229,6 +229,17 @@ steps:
           include:
             - "doc/po/ro/*.po"
+  check-xml-sv:
+    image: *test_image
+    pull: true
+    commands:
+      - make -C build-docs/doc/po/sv local-check-xml
+    depends_on: prepare
+    when:
+       - path:
+          include:
+            - "doc/po/sv/*.po"
   check-xml-uk:
     image: *test_image
     pull: true
@@ -384,6 +395,17 @@ steps:
           include:
             - "doc/po/ro/*.po"
+  html-sv:
+    pull: true
+    commands:
+      - make -C build-docs/doc/po/sv local-html
+    depends_on: check-xml-sv
+    when:
+       - path:
+          include:
   html-uk:
     image: *test_image
     pull: true
@@ -539,6 +561,17 @@ steps:
           include:
             - "doc/po/ro/*.po"
+  cheatsheets-sv:
+    pull: true
+    commands:
+      - make -C build-docs/doc/po/sv local-cheatsheets
+    when:
+       - path:
+          include:
   cheatsheets-uk:
     image: *test_image
     pull: true
@@ -694,6 +727,17 @@ steps:
           include:
             - "doc/po/ro/*.po"
+  check-cheatsheets-sv:
+    pull: true
+    commands:
+      - make -C build-docs/doc/po/sv local-check-cheatsheets
+    depends_on: [ cheatsheets-sv, build-cheatsheets ]
+    when:
+       - path:
+          include:
   check-cheatsheets-uk:
     image: *test_image
     pull: true
@@ -849,6 +893,17 @@ steps:
           include:
             - "doc/po/ro/*.po"
+  pdf-sv:
+    pull: true
+    commands:
+      - make -C build-docs/doc/po/sv local-pdf
+    depends_on: [ build-images, check-xml-sv ]
+    when:
+       - path:
+          include:
   pdf-uk:
     image: *test_image
     pull: true
Summary of changes:
 .woodpecker/docs.yml | 55 ++++++++++++++++++++++++++++++++++++++++++++++++++++
 1 file changed, 55 insertions(+)
hooks/post-receive
