[SCM] PostGIS branch master updated. 3.5.0-364-g32385a5a3
Wed Jun 4 09:30:53 PDT 2025
the project "PostGIS".
       via  32385a5a30fb3fb3fc27da2ffb93c9c2e922db31 (commit)
      from  746fd6acd22c5ff9072464512299e8efd72f7348 (commit)
revisions in full, below.
commit 32385a5a30fb3fb3fc27da2ffb93c9c2e922db31
Author: Daniel Nylander <daniel at danielnylander.se>
Date:   Wed Jun 4 08:16:02 2025 +0000
    Translated PostGIS Manual using Weblate (Swedish)
    Currently translated at 100.0% (5807 of 5807 strings)
    Translation: postgis/PostGIS Manual
    Translate-URL: https://weblate.osgeo.org/projects/postgis/postgis-manual/sv/
diff --git a/doc/po/sv/postgis-manual.po b/doc/po/sv/postgis-manual.po
index 2f402abf1..3ff665d27 100644
--- a/doc/po/sv/postgis-manual.po
+++ b/doc/po/sv/postgis-manual.po
@@ -5,7 +5,7 @@ msgstr ""
 "Project-Id-Version: PACKAGE VERSION\n"
 "Report-Msgid-Bugs-To: https://bugs.kde.org\n"
 "POT-Creation-Date: 2025-05-18 00:48+0000\n"
-"PO-Revision-Date: 2025-06-04 07:32+0000\n"
+"PO-Revision-Date: 2025-06-04 09:47+0000\n"
 "Last-Translator: Daniel Nylander <daniel at danielnylander.se>\n"
 "Language-Team: Swedish <https://weblate.osgeo.org/projects/postgis/"
 "postgis-manual/sv/>\n"
@@ -392,8 +392,8 @@ msgid ""
 msgstr ""
 "Om du installerade PostGIS ursprungligen utan en angiven version kan du ofta "
 "hoppa över ominstallationen av postgis-tillägget innan du återställer "
-"eftersom säkerhetskopian bara har <code>CREATE EXTENSION post</code> gis och "
-"därmed plockar upp den senaste senaste versionen under återställningen."
+"eftersom säkerhetskopian bara har <code>CREATE EXTENSION postgis</code> och "
+"därmed plockar upp den senaste versionen under återställningen."
 #. Tag: para
 #, no-c-format
Summary of changes:
 doc/po/sv/postgis-manual.po | 6 +++---
 1 file changed, 3 insertions(+), 3 deletions(-)
hooks/post-receive
