[PostGIS] #5922: TopoGeo_AddLineString crash on empty
PostGIS trac at osgeo.org
Thu Jun 5 00:44:53 PDT 2025
  Reporter:  robe      |      Owner:  strk
      Type:  defect    |     Status:  new
  Priority:  critical  |  Milestone:  PostGIS 3.0.12
 Component:  topology  |    Version:  3.0.x
Resolution:            |   Keywords:
Changes (by strk):
 * milestone:  PostGIS 3.5.4 => PostGIS 3.0.12
 * version:  3.4.x => 3.0.x
Old description:
> SELECT CreateTopology('test', 4326);
> SELECT TopoGeo_AddLineString('test', ST_GeomFromText('LINESTRING
> EMPTY',4326), 20.1);
> Not sure how far back you want to patch this, I didn't check 3.5 and
> below
New description:
 Not sure how far back you want to patch this, I didn't check 3.5 and below
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5922#comment:1>
