[SCM] PostGIS branch stable-3.5 updated. 3.5.3-6-g0dfd31806
git at osgeo.org
git at osgeo.org
Thu Jun 5 00:55:38 PDT 2025
the project "PostGIS".
The branch, stable-3.5 has been updated
via 0dfd3180662efcc60a063a931476bf797a5f205f (commit)
from 21bde1da74c410bd06bfc3e55b826a3f4cb6142a (commit)
revisions in full, below.
commit 0dfd3180662efcc60a063a931476bf797a5f205f
Author: Sandro Santilli <strk at kbt.io>
Date: Thu Jun 5 09:15:12 2025 +0200
Fix crash on TopoGeo_addLineString(empty)
References #5922 in 3.5 branch (3.5.4dev)
diff --git a/NEWS b/NEWS
index 77ffd44f3..4544d9ac0 100644
--- a/NEWS
+++ b/NEWS
@@ -7,6 +7,7 @@ PostgreSQL 12-18 required. GEOS 3.8+ required. Proj 6.1+ required.
- #5908, [topology] Fix crash in GetFaceContainingPoint (Sandro Santilli)
- #5907, [topology] Fix crash in TopoGeo_AddPolygon with EMPTY input (Sandro Santilli)
+- #5922, [topology] Fix crash in TopoGeo_AddLinestring with EMPTY input (Sandro Santilli)
PostGIS 3.5.3
diff --git a/liblwgeom/topo/lwgeom_topo.c b/liblwgeom/topo/lwgeom_topo.c
index ef244e628..feb818f93 100644
--- a/liblwgeom/topo/lwgeom_topo.c
+++ b/liblwgeom/topo/lwgeom_topo.c
@@ -7145,6 +7145,12 @@ _lwt_AddLine(LWT_TOPOLOGY* topo, LWLINE* line, double tol, int* nedges,
int input_was_closed = 0;
POINT4D originalStartPoint;
+ if ( lwline_is_empty(line) )
+ *nedges = 0;
+ return NULL;
if ( lwline_is_closed(line) )
input_was_closed = 1;
diff --git a/topology/postgis_topology.c b/topology/postgis_topology.c
index ae7521a29..7bd5dba48 100644
--- a/topology/postgis_topology.c
+++ b/topology/postgis_topology.c
@@ -5106,6 +5106,13 @@ Datum TopoGeo_AddLinestring(PG_FUNCTION_ARGS)
PG_RETURN_NULL();
+ /* Nothing to do if line is empty */
+ if ( lwline_is_empty(ln) )
+ lwgeom_free(lwgeom);
+ PG_FREE_IF_COPY(geom, 1);
+ PG_RETURN_NULL();
tol = PG_GETARG_FLOAT8(2);
if ( tol < 0 )
diff --git a/topology/test/regress/topogeo_addlinestring.sql b/topology/test/regress/topogeo_addlinestring.sql
index 79bdc4b84..1b35ba150 100644
--- a/topology/test/regress/topogeo_addlinestring.sql
+++ b/topology/test/regress/topogeo_addlinestring.sql
@@ -58,6 +58,7 @@ $$ LANGUAGE 'plpgsql';
SELECT 'invalid', TopoGeo_addLineString('city_data', 'SRID=4326;MULTILINESTRING((36 26, 38 30))');
SELECT 'invalid', TopoGeo_addLineString('city_data', 'SRID=4326;POINT(36 26)');
SELECT 'invalid', TopoGeo_addLineString('invalid', 'SRID=4326;LINESTRING(36 26, 0 0)');
+SELECT 'empty', TopoGeo_addLineString('city_data', 'SRID=4326;LINESTRING EMPTY');
-- Isolated edge in universal face
SELECT 'iso_uni', TopoGeo_addLineString('city_data', 'SRID=4326;LINESTRING(36 26, 38 30)');
diff --git a/topology/test/regress/topogeo_addlinestring_expected b/topology/test/regress/topogeo_addlinestring_expected
index 9b6efe509..6757356c1 100644
--- a/topology/test/regress/topogeo_addlinestring_expected
+++ b/topology/test/regress/topogeo_addlinestring_expected
@@ -3,6 +3,7 @@ max|edge|26
ERROR: Invalid geometry type (MULTILINESTRING) passed to TopoGeo_AddLinestring, expected LINESTRING
ERROR: Invalid geometry type (POINT) passed to TopoGeo_AddLinestring, expected LINESTRING
ERROR: No topology with name "invalid" in topology.topology
+empty|
iso_uni|27
iso_uni|N||POINT(36 26)
iso_uni|N||POINT(38 30)
Summary of changes:
NEWS | 1 +
liblwgeom/topo/lwgeom_topo.c | 6 ++++++
topology/postgis_topology.c | 7 +++++++
topology/test/regress/topogeo_addlinestring.sql | 1 +
topology/test/regress/topogeo_addlinestring_expected | 1 +
5 files changed, 16 insertions(+)
hooks/post-receive
