[SCM] PostGIS branch master updated. 3.5.0-370-g9630344e4
git at osgeo.org
git at osgeo.org
Thu Jun 5 00:51:33 PDT 2025
the project "PostGIS".
via 9630344e480fb0dcb6e0e3e97269b26b0cf27a3a (commit)
from d3222fc117d4becd97c4185e3339c7a8eb03cbfa (commit)
revisions in full, below.
commit 9630344e480fb0dcb6e0e3e97269b26b0cf27a3a
Author: Sandro Santilli <strk at kbt.io>
Date: Thu Jun 5 09:15:12 2025 +0200
Fix crash on TopoGeo_addLineString(empty)
References #5922 in master branch (3.6.0dev)
diff --git a/liblwgeom/topo/lwgeom_topo.c b/liblwgeom/topo/lwgeom_topo.c
index 6d938d5b6..c1e09eb1a 100644
--- a/liblwgeom/topo/lwgeom_topo.c
+++ b/liblwgeom/topo/lwgeom_topo.c
@@ -7128,6 +7128,12 @@ _lwt_AddLine(LWT_TOPOLOGY* topo, LWLINE* line, double tol, int* nedges,
int input_was_closed = 0;
POINT4D originalStartPoint;
+ if ( lwline_is_empty(line) )
+ *nedges = 0;
+ return NULL;
if ( lwline_is_closed(line) )
input_was_closed = 1;
diff --git a/topology/postgis_topology.c b/topology/postgis_topology.c
index 01c8b98a2..4d13fbeb9 100644
--- a/topology/postgis_topology.c
+++ b/topology/postgis_topology.c
@@ -5105,6 +5105,13 @@ Datum TopoGeo_AddLinestring(PG_FUNCTION_ARGS)
PG_RETURN_NULL();
+ /* Nothing to do if line is empty */
+ if ( lwline_is_empty(ln) )
+ lwgeom_free(lwgeom);
+ PG_FREE_IF_COPY(geom, 1);
+ PG_RETURN_NULL();
tol = PG_GETARG_FLOAT8(2);
if ( tol < 0 )
diff --git a/topology/test/regress/topogeo_addlinestring.sql b/topology/test/regress/topogeo_addlinestring.sql
index 79bdc4b84..1b35ba150 100644
--- a/topology/test/regress/topogeo_addlinestring.sql
+++ b/topology/test/regress/topogeo_addlinestring.sql
@@ -58,6 +58,7 @@ $$ LANGUAGE 'plpgsql';
SELECT 'invalid', TopoGeo_addLineString('city_data', 'SRID=4326;MULTILINESTRING((36 26, 38 30))');
SELECT 'invalid', TopoGeo_addLineString('city_data', 'SRID=4326;POINT(36 26)');
SELECT 'invalid', TopoGeo_addLineString('invalid', 'SRID=4326;LINESTRING(36 26, 0 0)');
+SELECT 'empty', TopoGeo_addLineString('city_data', 'SRID=4326;LINESTRING EMPTY');
-- Isolated edge in universal face
SELECT 'iso_uni', TopoGeo_addLineString('city_data', 'SRID=4326;LINESTRING(36 26, 38 30)');
diff --git a/topology/test/regress/topogeo_addlinestring_expected b/topology/test/regress/topogeo_addlinestring_expected
index 9b6efe509..6757356c1 100644
--- a/topology/test/regress/topogeo_addlinestring_expected
+++ b/topology/test/regress/topogeo_addlinestring_expected
@@ -3,6 +3,7 @@ max|edge|26
ERROR: Invalid geometry type (MULTILINESTRING) passed to TopoGeo_AddLinestring, expected LINESTRING
ERROR: Invalid geometry type (POINT) passed to TopoGeo_AddLinestring, expected LINESTRING
ERROR: No topology with name "invalid" in topology.topology
+empty|
iso_uni|27
iso_uni|N||POINT(36 26)
iso_uni|N||POINT(38 30)
Summary of changes:
liblwgeom/topo/lwgeom_topo.c | 6 ++++++
topology/postgis_topology.c | 7 +++++++
topology/test/regress/topogeo_addlinestring.sql | 1 +
topology/test/regress/topogeo_addlinestring_expected | 1 +
4 files changed, 15 insertions(+)
hooks/post-receive
