[SCM] PostGIS branch stable-3.1 updated. 3.1.11-28-ge5d183bd0
Thu Jun 5 00:57:11 PDT 2025
the project "PostGIS".
The branch, stable-3.1 has been updated
       via  e5d183bd054c2ae6c85f9662fa7a8755045ab4ea (commit)
      from  835779081be4d9228a427d3c3e4aad90cf14e12b (commit)
revisions in full, below.
commit e5d183bd054c2ae6c85f9662fa7a8755045ab4ea
Author: Sandro Santilli <strk at kbt.io>
Date:   Thu Jun 5 09:15:12 2025 +0200
    Fix crash on TopoGeo_addLineString(empty)
    References #5922 in 3.1 branch (3.1.13dev)
diff --git a/NEWS b/NEWS
index c07347e89..df3e279d2 100644
--- a/NEWS
+++ b/NEWS
@@ -3,6 +3,7 @@ YYYY/MM/DD
 * Bug Fixes *
+ - #5922, [topology] Fix crash in TopoGeo_AddLinestring with EMPTY input (Sandro Santilli)
  - #5907, [topology] Fix crash in TopoGeo_AddPolygon with EMPTY input (Sandro Santilli)
  - #5876, Fix ST_AddPoint with empty point argument (Paul Ramsey)
  - #5818, GT-244 Fix CG_IsSolid function (Loïc Bartoletti)
diff --git a/liblwgeom/lwgeom_topo.c b/liblwgeom/lwgeom_topo.c
index f7bd9e481..e393dc971 100644
--- a/liblwgeom/lwgeom_topo.c
+++ b/liblwgeom/lwgeom_topo.c
@@ -5593,6 +5593,12 @@ _lwt_AddLine(LWT_TOPOLOGY* topo, LWLINE* line, double tol, int* nedges,
   uint64_t i;
   GBOX qbox;
+  if ( lwline_is_empty(line) )
+    *nedges = 0;
+    return NULL;
   *nedges = -1; /* error condition, by default */
   /* Get tolerance, if 0 was given */
diff --git a/topology/postgis_topology.c b/topology/postgis_topology.c
index 49630edfe..1cbe84cb7 100644
--- a/topology/postgis_topology.c
+++ b/topology/postgis_topology.c
@@ -4789,6 +4789,13 @@ Datum TopoGeo_AddLinestring(PG_FUNCTION_ARGS)
         PG_RETURN_NULL();
+    /* Nothing to do if line is empty */
+    if ( lwline_is_empty(ln) )
+      lwgeom_free(lwgeom);
+      PG_FREE_IF_COPY(geom, 1);
+      PG_RETURN_NULL();
     tol = PG_GETARG_FLOAT8(2);
     if ( tol < 0 )
diff --git a/topology/test/regress/topogeo_addlinestring.sql b/topology/test/regress/topogeo_addlinestring.sql
index 8edf9a243..48e619378 100644
--- a/topology/test/regress/topogeo_addlinestring.sql
+++ b/topology/test/regress/topogeo_addlinestring.sql
@@ -58,6 +58,7 @@ $$ LANGUAGE 'plpgsql';
 SELECT 'invalid', TopoGeo_addLineString('city_data', 'SRID=4326;MULTILINESTRING((36 26, 38 30))');
 SELECT 'invalid', TopoGeo_addLineString('city_data', 'SRID=4326;POINT(36 26)');
 SELECT 'invalid', TopoGeo_addLineString('invalid', 'SRID=4326;LINESTRING(36 26, 0 0)');
+SELECT 'empty', TopoGeo_addLineString('city_data', 'SRID=4326;LINESTRING EMPTY');
 -- Isolated edge in universal face
 SELECT 'iso_uni', TopoGeo_addLineString('city_data', 'SRID=4326;LINESTRING(36 26, 38 30)');
diff --git a/topology/test/regress/topogeo_addlinestring_expected b/topology/test/regress/topogeo_addlinestring_expected
index 973aaf35c..cfba38601 100644
--- a/topology/test/regress/topogeo_addlinestring_expected
+++ b/topology/test/regress/topogeo_addlinestring_expected
@@ -7,6 +7,7 @@ max|edge|26
 ERROR:  Invalid geometry type (MULTILINESTRING) passed to TopoGeo_AddLinestring, expected LINESTRING
 ERROR:  Invalid geometry type (POINT) passed to TopoGeo_AddLinestring, expected LINESTRING
 ERROR:  No topology with name "invalid" in topology.topology
+empty|
 iso_uni|27
 iso_uni|N||POINT(36 26)
 iso_uni|N||POINT(38 30)
Summary of changes:
 NEWS                                                 | 1 +
 liblwgeom/lwgeom_topo.c                              | 6 ++++++
 topology/postgis_topology.c                          | 7 +++++++
 topology/test/regress/topogeo_addlinestring.sql      | 1 +
 topology/test/regress/topogeo_addlinestring_expected | 1 +
 5 files changed, 16 insertions(+)
hooks/post-receive
